Question about Bosch 24 in. SGV43A03 Built-In Dishwasher
Machine cannot finish cycle and is stuck in pumping out mode. Only tiny amount of water in drain basin at bottom, no excessive water. Was set at 10pm, still attempting to drain 8am! Has no diagnostic dials or manual over rides so continues on whether door is open or closed, even if I switch off and on again. Possible related issue, recently finish at end of washes has been "grainy", far from perfect, surfaces slightly sandy feeling.
    Top Expert:
  • Bosch Master
  • 78,257 Answers
More then likely the control panel or basin float is defective.
Posted on Jun 26, 2017
SOURCE: Bosch sgv53e13gb Integrated dishwasher - wont start a new cycle!?
Thanks for the input Dicky...I think my dad will be onto the place of purchase first thing tomorrow!!
Posted on Jul 13, 2008
Macmarkus
  • 2605 Answers
SOURCE: Bosch dishwasher model SHV6803UC/12 - washing
Welcome to FixYa.
I`ll start by letting you know there are many things which can manifest in the manner you`re describing...or even how one interprets what you`re describing.
Having said that are you referring to water in the tub or in fact the "pan" also known as overfill basin ?
**before performing any repairs please turn off the power to the dishwasher...safety first**
In either case I would instruct you to start by checking the drain hose where it is connecting to your home plumbing...i.e. under sink or into food disposer/garberator. for kinks or obstructions.
Also remove the filter assembly and check for food or soap deposits clogging the sump assembly.
**ultimately it may in fact be a faulty drain pump not pumping the adequate volume of water for the time allowed...but I certainly would check the drain first**
That is by far and away the most common cause behind the problem you are describing...based on my understanding as I mentioned.
Let me know if indeed this was helpful or not and we can move forward from here.
Either way thank you for choosing FixYa today. I`ll watch for your reply.
Regards,
Macmarkus :)
Posted on Sep 22, 2010
Macmarkus
  • 2605 Answers
SOURCE: gets to the end of the cycle (1 minute left on
Welcome to FixYa.
Based on your description
I'd say the issue actually with the control...unfortunately. The "1" being displayed is actually an error code associated with a heating fault.
Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described. **B/S/H/ also issued a recall on certain models between 1999 - 2006 depending on the model & serial number, you can check with yours but you'll need the serial number too. The issue was directly related to the heating circuit (specifically the heat relay on the control) Here`s the link if you want to see for yourself **
http://microsites.boschappliances.com/safetyrecall/dishwasher/
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be contacting Bosch re: the recall or calling in an authorized bosch service tech. if that is an option for you and your budget however, If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
This ones new, but it's where to look...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...or takes a long time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Nov 25, 2010
heatman101
  • 43501 Answers
SOURCE: My daughter put the wrong
You need to find the bottle of white vinegar or cooking oil, if you have one...that will cut the suds and get you working again...
Check this out...
http://www.acmehowto.com/howto/appliance/dishwasher/wrongsoap.php
wrong soap
or this
heatman101
Posted on Dec 01, 2010
caroldon
  • 17130 Answers
SOURCE: after cycle completed, opened door and found water
Possible that the drain pump needs a closer look , clean and check if the pump is working. If there is voltage to the pump during the drian then the pump is faulty.
The second issue if the inlet chocking , check the inlet filter , check the flow to inlet. remove the valve if there is voltage and no flow if not the program controller needs a check.
I shall give you a link which might assist you with some helpful tips.
http://www.scribd.com/doc/36710129/Bosch-Dishwasher-Multi-Model-Test-Programs
Posted on Jan 20, 2011
Machine stuck in drain mode, & will not register in other cycles....turning machine off does not reset cycle?
Washers are computer and they must finish the program you last started. So with that being said the washer is trying to finish the cycle you start before it can move on. If it keeps draining there must be a clog in the pump. The water may be below the inner clothes basket so you can't see it. The washer knows it is not all drained out so it keeps trying. A model number would be helpful.
Mar 15, 2015 | Washing Machines
I can't open the washer door. There is excess water lying in the drum from the last cycle which did not drain properly
You need to clear out the drain pump. if you should be able to access the pump from the front bottom by unscrewing and removing the filter. If not then you will need to tilt the machine back as far as you can so you can access the underneath. You will see the small drain pump. Have a basin ready to catch any water that comes out when remove the pump which is only held in by 1 or 2 screws and twisted out or pulled out. If it is clear then try removing the pipe that goes from the pump to the base of the tub. Hope this helps
Mar 02, 2011 | Kenmore Elite 45986 Front Load Washer
Washer does not spin. Tried to start cycle over
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Jul 26, 2010 | LG Washing Machines
Water in the bottom of the tube the drain hose is fin no kinkys or clog is there a internal filter in side the washer
It's normal for there to be about a hoseful of water left in the sump at the bottom of the machine after the cycle is over - it happens because the drain pump only works on water, so is never able to blow the last slug of water through the hose. Once the pump stops, this water runs back into the machine.
The sump is designed to be big enough to hold this amount of water without the level rising high enough to come back into the main cabinet, but in some machines you can see to the bottom if you look in the right place.
The installation instructions for the dishwasher will have had lots to say about size and position of the standpipe the drain hose goes into. Failure to follow these can increase the amount of water that runs back at the end of a cycle, so that might be worth a quick look if you think the quantities are excessive.
A.
May 01, 2010 | Dishwashers
An excessive amount of water is coming out under my washing machine at the end of the wash cycle when draining. My email is mnussbaumcfp@gmail.com. the machine is only 2 yrs old.
the drain pump is probably cracked!! or the drain hose is lose or broken to the pump from the bottom of the pump! you will need to put the machine on it's side to check the pump and hose from the bottom of the machine where it hooks to the motor shaft
Jan 24, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Dishwasher maytag 945 awq
Door gasket or sealOver time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Nov 08, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Kenmore Clothes Washer
HI There I will help you
I am looking for the answer please be stand by.
Aug 30, 2008 | Kenmore 24032\24036 Top Load Washer
Fisher and Paykel dd605 The flood switch has tripped and is showing "F1 with spanner" on the display turned of for 24 hr still there pumps just running . this problem happened aftr my son put cloths...
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin. If a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
TURN OFF POWER TO MACHINE
Remove the front panel by removing two "pins". There is one on each side of the drawer, and they are at the bottom and circular with a recessed tab - like an inverted slotted screw.
You just pull the tabs straight out. After that you pull the front down and out.
Drawer is removed by depressing the tab on each side and sliding the support guide back.
Use a towel to remove excess water pooling, then a hair dryer to speed up the evaporation process of the remaining water.
Regards
Richard
The FixYa Team
Jun 14, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and paykel dd-603ss
There are three possible scenarios; 1. Defective lid motor(s)...Each drawer has two lid motors that pull the lid tight to the drawer when the cycle is started. (this was very common on early models) 2. Something too tall was placed in the drawer preventing the lid from closing completely. OR 3. (only seen this once) the drain hose developed a crack causing water to leak only when draining. Hope this helps....
Jun 06, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bosch 24 in. SGV43A03 Built-In Dishwasher Logo
46 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
