Question about Inverter Heating & Cooling
I have an ar-ry3 problem. it turns on and the lights light up, the flaps open but nothing else, the fan doesn't seem to work at all and the unit outside makes noise intermittently. the flaps used to open up to the last position used but they seem to open up completely now. i live in a rented property but my landlords always off around the world, hard to get a hold of and basically leaves us to it. it had alot of use last winter(new zealand) but near to none over summer, now it's heading into winter again and buggered if i'm paying for a tech.
GE Spacemaker XL1800 JVM1850CH01 vent fan won't turn on
Unplug for about 5 minutes and allow to reset. If the problem persist, you might want to try replacing the control panel (the one that have all the numbers and timers). Good Luck!
Jan 13, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
The heating is not working at all on my fujitsu air conditioner
Should have an heating element inside...that one I think is broken or can be also the thermostat..
Jul 12, 2013 | Dishwashers
I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
Jul 21, 2012 | Ovens
The unit will not turn on after trying the pushing the power button. The green light on the reset button shows that it is on but on the display not lights are on. I tried to inplug and wait and plug the...
You need to bypass the on/off switch by jumping it, thereby taking the switch out of the circuit. If it works you have a bad switch. If it doesn't you have a power to the switch problem. Do you have a multimeter and a wiring diagram for this unit?
Aug 02, 2011 | LG Heating & Cooling
HOW DO I SET THE TIME on Fujitsu AR-RY3
Right above the 'CLOCK ADJUST' there is a small hole, you need to push a ballpoint pen or something into that hole, to allow you to set the clock using the - and + buttons next to it. Then press the pen into that hole again in order to finalize the time.
Dec 09, 2010 | Fujitsu 36CS Air Conditioner
The freezer section of my fridge freezer side by side has broken down and will not freeze. The fridge side seems fine. Is it worth getting repaired? Prior to this I often heard like a clicking/ tapping...
So your refrigerator section is cooling fine ? When the compressor motor is running and you open your freezer, is the fan running ? You might need a simple fan replacement - The most costly repairs to a refrigerator is usually the compressor - as long as your compressor is running and you have cooling, the other most common problems are control board faults, evap fans, defrost timers, all of which can be fixed.
Is your freezer iced up when this happened - turning the refrigerator off and unplugging it, try removing the back panel of your freezer and locate the fan - look for anything obstructing the blades - maybe ice or other......otherwise you may need this serviced.
Is it worth it ? It depends - how much did you nitially pay for this ? How long have you had it ? How much are estimated costs for the repair - if the problem is one thing needing replaced and doesn't cost you a lot of money, yes it is worth it.
Aug 17, 2009 | Whirlpool GS6NBEXR Side by Side...
Heating & Cooling Logo
Top Inverter Heating & Cooling Experts
MightyMikeJr
jeff5may32
Are you an Inverter Heating and Cooling Expert? Answer questions, earn points and help others
