Question about Kenwood Audio Players & Recorders
I have new belt and needle for kenwood 38r turntable how to install them
  • 734 Answers
Belt is easy, Just remove the base, and change the belt.
Needle change is done by cartridge change. remove the old cartridge and insert the new one with the new needle.
Posted on Mar 18, 2011
I have two problems. One: Does the Kenwood KD34R Turntable does it need a system cord? Two: I have a Kenwood KD491/492F turntable, it drags. It has a new belt. Please help. Thank you.
just had that problem when i replaced my belt on a pioneer pl600 turns out there was residue from the old belt on the drive pulley making the belt ride on the edge of the pulley instead of in the groove there is also two adjuster screws under the turntable that u took off to replace the belt with these u can adjust the speed manually was told that by a repair person from vintage electronics great place online for help
Sep 29, 2013 | Kenwood Audio Players & Recorders
Kenwood P9 linear turntable belt....
If you cannot obtain one from Kenwood, you can search the internet for a source
Mar 06, 2013 | Audio Players & Recorders
I need a kenwood P28 turntable belt drive.
If a belt cannot be obtained from Kenwood, a computer search for turntable belts will turn up several sources
Sep 24, 2012 | Audio Players & Recorders
I need to fit the replacement turntable belt on my Kenwood stack system record player
Hi, we have all Kenwood belts in stock. What model do you have. Cheers John. Styluscity@gmail.com
Aug 09, 2011 | Kenwood Audio Players & Recorders
Kenwood Trio Turntable belt broken.
I have them listed as item 250423608612 on Ebay .. softwaredivision
Feb 07, 2010 | Audio Players & Recorders
I,m trying to replace my kenwood KD 47F turntable V68 catridge & N68 needle stylus with an Audio technica set due to non availibility of N68 stylus in my home country- singapore. Audio technica...
hi, any cartridge are posible in every turntable as long the needle is available...the wiring is the same the position ,, but the only thing that im not sure is the sensetivity of the needle ..some are not good but some is compatible..u
Jun 30, 2009 | Kenwood KD-291RC Turntable
How do i put turntable belt back on?
you must first get the platter off [the bit that you put the record on ]
this will prise off with equal pressure on both sides but remove the rubber mat on the platter first [it might have a little clip on the centre spindle if so just get a screwdriver and push the clip off ] then just jiggle the platter with your hands until it frees , when off you should see a small round disc thats connected to the motor that turns the platter via a rubber belt , you just connect the new belt around this and then connect the other end to the platter very fiddly , not being familiar with kenwood turntables i could be totally wrong here and the belt might go to another pulley in which case you might need more than one belt , your best bet is to get the platter off and let me know what it looks like
May 23, 2009 | Kenwood Audio Players & Recorders
My KD-291RC has power but my turntable wont turn. I touch the needle and I can hear its on and when I move the arm towards the record or set it on it it will not turn. Help?
Your turntable is belt-driven, it's likely that the belt just fell off. The belt lives under the turntable. On my turntable (a totally different model) the turntable lifts off.
Apr 13, 2009 | Kenwood KD-291RC Turntable
Turntable starts playing record middle 1st song
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
Jan 24, 2009 | Kenwood KD-291RC Turntable
Fixing a Kenwood KD 491F turntable
The reason why the audio is low, is that todays receivers do not have a phono input, and these types of inputs are differant then the ones of today. You will need whats called a phono preamp, and one should still be available from Radio shack. Or you can go here to find out more about them: http://www.phonopreamps.com/ To reseat the belt, take off the rubber mat on the turntabe disc. Install the belt around the inside ridge, there should be a couple of holes on the platter disc. Install the patter back onto the center spindle. Turn the platter around till you see the motor pully through one of the holes in the platter. Take the belt that is around the turntable platter, and pull it over to the motor pulley. Good Luck
Jun 15, 2007 | Kenwood KD-291RC Turntable
343 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
