Question about Zanussi Washing Machines
The machine has turned itself off. I have changed the fuse etc but can't get any response. No lights are on and can't even turn the dial. Thanks
    Brigadier General:
  • 6,277 Answers
Sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB. I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Mar 18, 2011
How do I reset my servis washing machine 1500 A+A if it wont do it itself?
Un-plug the machine from AC mains wall socket, and re-plug it back after an hour; or so. If you do this over-night will be better. The internal electronic control circuit will reset itself.
Nov 29, 2014 | Washing Machines
Maching starts without using foot peddle
"Ghost sewing" sometimes occurs when the wires inside the foot are making contact before the pedal is even used. There is sometimes a "dial" on the bottom of the foot pedal (usually accessed through a small hole with a miniature flat bit screw driver) that can be fine tuned for responsiveness. If the dial is labeled + or -, turn the dial toward the minus to reduce the responsiveness of the pedal, (should be counterclockwise) and if it is not labeled just try quarter turns until the pedal operates as is should. If there is no adjustment, you may have to open and repair or replace the pedal.
Apr 09, 2014 | Simplicity Fashion Pro SW2145 Mechanical...
Candy CDB 854: Just installed, spin tested briefly. Now just lights and no function.
Turn the power back on, go through the instruction book to start the machine up. If its still not right, call the Service Agent. Its brand new and will be covered by warranty.
Apr 26, 2017 | Computers & Internet
The dial on my machine is not moving around by itself cycles still work if I turn the dial
The dial is driven by a synchronous motor which seems to have failed. You might be able to replace the motor itself, otherwise the whole timer will have to be changed.
Mar 07, 2011 | Hoover Washing Machines
New sleep sheep will not work even when batteries are changed. Gift received a few months ago. How can we get the sound box to work?
Do you have both the volume dial turned on and a sound selected? In order for the Sleep Sheep to work, you have to turn the volume dial on (you'll hear it click) and then select one of the four sounds by pressing one of the buttons. If you just turn the volume on by itself, no sound will come out until you pick one.
Dec 19, 2010 | Cloud B Sleep Sheep Plush Sound Machine
The key isnt starting the car
Absolutely. Could also be that the smart key has a dead battery or has been compromised by moisture, etc.
Can you still lock & unlock the car with the smart key? If so, the battery is not dead, and you should look next at the ignition itself. Is there any response when you put the key in? Can you turn it? Are there signs that your battery is drained (dim/no lights work, etc)? If you are getting no response when you put the key in and you can turn it, and it still works to unlock your car and you can verify that you have battery power, start by checking your fuses. The ignition and starter fuses would be the first to check.
Nov 07, 2009 | 2004 Mercedes-Benz C32 AMG
Can't change flash settings to Sony Cybershot DSC-H10 camera
Glad ur problem solved !
kindly rate my response WELL in system
Regards
Zohail
May 28, 2009 | Sony Cybershot DSC-H3 Digital Camera
Lights flash alternating between red lights and green lights
The EEprom (memory of the machine) has crash. Needs to be re-programmed or substituted.
May 18, 2009 | Krups Orchestro 889 Espresso Machine
When the machine is switch on from the main socket and than on from the machine on /off switch, it trip the whole house fuse box.I have change the 13amp.plug fuse, I cannot locate where the machine...
hi..It is next to the switch where you turn on.Open the
casing that stores the motor etc.Should be able to locate
it there,usually hidden inside a capsule.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Exercise & Fitness
WASHER will not respond or Turn ON
Lg wash machine do not normally have fuses. 90%chance the board is blown. Trace the power to the board. if there is power, boarb is faulty. there should always be am indicating light of a sort when power is applied even if you had other problems.
Apr 09, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
51 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
