We have a washing machine Elextolux WT38 - 9CGX50211214 It does not work and it show the error C8. can you tele what it is?
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine code BUT JUST IN CASE I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 18, 2011
HOW TO RESOLVE C8 ERROR IN RICOH SP 111 PRINTER
Ricoh SP 111 with C8 Error:
The C8 is a fuser error. As a safety feature, the machine will be disabled (to prevent fire and what not.. )
The service manual says that SC542 is caused by a too low fuser temperature, after 5 readings.
Since the hot roller was 5°C below the reload
(operating) temperature the fusing thermistor is deformed or out of position or full of gunk (toner residue). Or there may be a piece of paper between the sensor and the hot roller.
The fusing lamp harness can also bee loose, broken or defective.
The fusing unit can be defective
After servicing the machine to solve the problem, the service
technician must execute a "Fuser SC Reset". Otherwise, the machine
will continue to issue this SC code and cannot be operated.
Executing Fuser SC Reset
1. After correcting the problem, open Smart Organizing Monitor.
2. Enter the service mode to display the Service Mode screen.
3. On the Service Mode screen, click [Fuser SC Reset]. This releases the fatal fusing error
which locks the machine.
4. Select "On" for Fuser SC Detect. This setting shuts down the machine if three successive
paper jams occur in the fusing unit.
Jul 27, 2017 | Ricoh Office Equipment & Supplies
My washer machine hitachi nw -d8gx code c8 what going on?
C8 indicates that the lid cannot be locked.
Is the lid closed?
Are there any foreign objects in the lock?
Check that the lid is completely closed.
Check that there are no foreign objects in the lock.
Link to users manual.
http://www.hitachi-th.com/hitachi_new/Download/SF-140SV_EN.pdf
Aug 03, 2014 | Washing Machines
Replaced drain pump and control board in cabrio washer, still does not work
Go back to the shop and ask them to explain why the diagnostic routine stops at C8 and reads error F72. No doubt they will blame it all on something else but you could get headed for a cure.
Apr 16, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Show my printer on display C8 on Ricoh SP 100Su
Fusing Reload Temperature Error (Fatal Error)
Fusing thermistor deformed or out of position ? Fusing lamp harness loose, broken, defective ? Fusing unit defective ? After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.- Carl
Aug 02, 2013 | Ricoh Aficio SP 100SU e Laser...
How to solution of FUSER TEMP.
my rocoh printer SP 100su show on lcd panal C8 error code . power on .
May 17, 2012 | Ricoh Aficio Sp 1000sf All-In-One Laser...
What exactly is the error code c8
I think error code C8 is #13
Check following links to see if they have information:
Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
Manual shows error 05 or 13:
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Feb 22, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
New Richmond tankless water heater C8 error
It has to do with air quality, lack of sufficient air, or lack of venting or dirty air filter.
Sep 01, 2009 | Rheem Tankless Hot Water Heater...
What does fault code c8 mean on an AEG Lavamat 76669
a C8 warning means the (Thermister) temperature sensing device has shorted or is open circuit, this replaces the old-fashioned thermostat that they used to fit. the water in your m/c could either stay cold or boil.
Jul 07, 2009 | Washing Machines
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
