Question about Nokia 7610
While i am pressing menu button nothing show by phone
  • 902 Answers
Do a factory reset thats probably your only option. also you can try doing it by dialing #7370#
let me know if htis works asap
Posted on Mar 18, 2011
The Samsung galaxy s2 menu button was working fine before and now the button does nothing when you press it. I only had the phone for two weeks and the button just stopped working.
David, As this is a new phone, just released, you must make use of the warranty clause. Do not do anything yourself as the warranty will become null and void. Please show it to the Service Centre of Samsung.
Jul 03, 2011 | Cell Phones
The ringer is tuened off on my GE cordless phone how do I tuen it back on?
  • Press the "Menu" button on the handset. This button is also the "Star" (*) button.
  • Press the right "Volume" button to browse through the menu. When the display shows "Setup HS," press the "Menu" button again.
  • Press the right "Volume" button until you see "Ring Volume." Press the "Menu" button to enter the ringer menu.
  • Press the left and righ "Volume" button to turn up or down the ringer volume. The default volume level is "L3." Press the "Menu" button to save your change.
  • Oct 17, 2010 | Uniden Cordless Phone
    When click bb button my options buttom doesn work
    If you are at the home screen and the phone is unlocked, press the "blackberry" key, next to the green answer button. The on screen menu should show "options". If you click on this, nothing happens? If it does pop up with the next window, the row adjustments are in the middle of this screen under "Set Homescreen Layout". Once you have selected this, be sure to press the blackberry button again and save your selection.
    Hope this helps!
    May 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
    Set call rings
    From the manual:
    1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
    2. Press mute/menu OK button to enter the menu. SET RINGER LEVEL 5 shows in the display.
    3. Use the CALLER ID-VOLUME ( 6 or 5) button to scroll to your selection. LEVEL 5 is the default setting.
    4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
    Apr 26, 2009 | General Electric 28811FE2 Twin Cordless...
    I have a awa micro dect phone my son picked it up and started playing with it this morning. god knows how he did it but has put it on babymode so everything i press dials out. i have no idea how to take it...
    press menu button(shows baby call).press ok button(shows on).press up button(shows off).press menu button to go back to standby; cheers Rossco
    Apr 22, 2009 | Lands Phones
    Sidekick lx
    while your on the privacy lock you press the call button 2 times, then the emergency call shows up , once that shows up yu press the menu button (the top left button w. tha 3 lines) while holding shift & Q .
    & a message pops up saying if you want to reset to factory settings n yu juss press reset & it takes outt tha code n all tha things in the sidekick ..
    your welcome :]
    May 05, 2008 | T-Mobile Sidekick® 3 Cellular Phone
    "secret menu" doesnt work.
    Sounds like you are doing it right, but just to make sure:
    1. Press (but do not hold) the menu button.
    2. Press (but do not hold) the "0" button. This should bring up a "Service Menu" box with 6 question marks.
    3. Press the "0" key 6 times.
    As far as I know, this is the only way to get into the service menu.
    Feb 25, 2008 | LG VX8300 Cellular Phone
    Validation
    I would assume this could have been a product that was returned to the company that you purchased it from. Follow these instructions. 1. 1. Disconnect power from the base by pulling the plug out of the back of the unit. 2. Press and hold the Page button and while holding the Page button reconnect the power. 3. Continue to hold the Page button until the charge/in use light flashes rapidly. 4. Release the Page button. 5. Press and release the page button on the base once. All handsets are de-registered and HANDSET NEEDS REGISTRATION shows in the display. Then From the Handset Setup Menu: 1. Press the caller ID-volume ( 6 or 5) button to scroll to the REGISTRATION sub-menu. 2. Press the mute/program button to enter the menu. REGISTRATION 1YES 42NO - - -shows in the display. The default setting is 2NO. 3. Use the touch-tone pad to select 1 for YES or 2 for NO. Or use the caller ID-volume ( 6 or 5) button to scroll to 1YES or 2NO. 4. If you select YES, press the mute/program button. HOLD BASE PAGE FOR 5 SECONDS, THEN PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.) 5. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number. You may now rename your handset. (Refer to Step 3 & 4 of Handset Name Section) NOTE: IF you are re-registering the handset through the handset menu; to rename your handset you must go to the Handset Name Section and start from the beginning step. I understand that you have tried the registation process. Sometimes with electronics, you have to start from ground 0, before it will work correct again. If there are further questions or comments, please post here. Please rate this solutn through fix-it. Thank you
    Jun 22, 2007 | GE 28111 Cordless Phone
    Blank LCD on the camera
    The camera turns on but the screen stays blank and I press any button and do not do anything no zoom no nothing and I press the menu button but neither nothing shows up just the blank screen
    Jan 16, 2007 | HP Photosmart 620 Digital Camera
    Nokia 7610 Logo
    15 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
