Question about Joytech NEO Se Advanced Controller for Xbox 360
The controller does not turn on when plugged into my xbox 360, it blinks when i hold the 360 button, but it does not turn on
My Xbox 360 controller appears to be having some issues: i turned the xbox on, and it is immediay prompting me to download an update from Xbox Live, however, I cannot get my controller connected to get rid...
There is a connect button on the controller as well. See this site or follow the instructions below. http://support.xbox.com/en-us/pages/xbox-360/get-started/console/connecting-game-controllers.aspx
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  3. Press and release the connect button on the console.
  4. Within 20 seconds, press and release the connect button on the controller.
  5. When the lights surrounding the power button on the console stop flashing, the controller is connected.
Jun 30, 2011 | Microsoft Xbox 360 Controller
All 4 lights keep on blinking on my controller
You may need to "Sync" the controller to your Xbox console.
1) Press the sync button on your Xbox 360. The green lights on the Xbox will swirl.
2) Press the small white button on the controller (between the bumper buttons).
After a few seconds, the position 1 green LED should light up on the controller.
Apr 05, 2011 | Microsoft Xbox 360 Controller
The lights keep blinking but nothing is happening. It wont connect to the console. What should I do?
It's possible the xbox 360 controller isn't connected to the xbox 360. Turn the xbox 360 on by pressing the power button, and wait until it reaches the dash board. Then press the controller syncing button on the xbox 360 itself and wait until the xbox 360's ring lights start to spin around. Then press and hold the synch button on the controller (located near the charge port) and the controller should synch up with the xbox 360.
Mar 28, 2011 | Microsoft Xbox 360 Controller
No video have sound when using component connection on my xbox 360 hdmi ok. help
Your resolution settings on the xbox are too high for your currently used cables or tv. To reset your console's resolution follow these steps: To reset Xbox 360 console display settings
  1. If there is a disc in the console, remove it.
  2. Turn off the console.
  3. Turn on the console by using your controller (its best to have the controller plugged into the console rather than just using the wireless). To do this, press and hold the controller's Xbox Guide button until your console turns on.
  4. While the console is starting, press and hold the Y button and pull the right trigger at the same time. Continue holding the buttons when you see the Xbox 360 logo.
  5. The console will restart and you will see the Xbox 360 logo again.
    The console's display settings are now reset to the defaults.
Mar 12, 2011 | Microsoft Xbox 360 Console
I just got a refurbished xbox 360 elite and when i turn the wireless controller on it doesn't connect. It just keeps blinking. How do i get it to connect?
To begin, turn on your xbox 360. On the top of the wireless controller, to the right of the LB button there is a small white button. Hold this, and the lights near the xbox button will spin in a circle. On the front of your xbox 360, there is a button to right of the memory card slot. Press this button and the lights on the front of the xbox will spin. After a few seconds, the controller should synch with the xbox. If this does not work, make sure that the lights are spinning in circles at the same time.
Please let me know if you need any more help
Jun 13, 2010 | Microsoft Xbox 360 Console
How do you turn on an xbox 360?
Simply press the big button that has green lights around in front of your console
Apr 21, 2010 | Microsoft Xbox 360 Console
My controller and xbox wont connect
To connect the controller to your Xbox 360 console, follow these steps:
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 28, 2009 | Microsoft Xbox 360 Wireless Controller
My controller turns on and it just shows a green circle
try pressing the circle button on top of your controller right next to where you plug in your play and charge cable and you should see a little white button hold it and there is another one on your xbox right next to the second memory card slot. Press and hold that one to till both your xbox and controller start blinking and your controller should be fine
Aug 02, 2009 | Microsoft Xbox 360 Wireless Controller
Xbox controller not working only has two lights on game pad
There should be a sync button right on the top of the back of the Xbox 360 controller. While the system is on. Power on the controller. Hold down the sync button on the controller, and then press and hold the sync button on the Xbox 360 console. Wait for a few seconds until the Xbox 360 controller lights stop blinking. Then test out the controller. Any comments of questions, post them by clicking on the add more details link inside of this question that you've asked.
Nov 16, 2007 | Microsoft Xbox 360 Controller
Joytech NEO Se Advanced Controller for Xbox 360 Logo
43 people viewed this question
Top Joytech Video Game Consoles & Games Experts
James Wishart
Are you a Joytech Video Game Console and Game Expert? Answer questions, earn points and help others
