Question about HP DESIGNJET T770 Printer
My hp t770 have this error 59.2:00 after repalcing formatter board plz help me
    Genius:
  • 1,089 Answers
A 59.2:00 error says that a reused part has been installed.
If you paid for a NEW formatter get your money back and shop somewhere else.
If you paid for a repaired/reconditioned part, it won't work.
You need a NEW formatter.
Posted on Mar 19, 2011
No solution it is not formatter or hdd. plss give the really solution
Posted on Oct 21, 2011
HP Laser Jet 9050dn error
Either you do not have enough memory installed for the complexity of the document you are printing or the memory you have has failed. Removed any memory from the formatter and try rebooting printer. some of the memory is built into the formatter so if it has failed them the formatter will need to be repalced.
Jul 20, 2016 | HP Office Equipment & Supplies
P3015 hp lasser printer 49.4C01 error proper solution
Sounds like a bad formatter. I would try a firmware upgrade first and if unsuccessful, would replace the formatter. These formatters are infamous for failure.
Feb 22, 2015 | HP RB1-3015 LaserJet 4L Laser Scanner...
How i can cancel the purge tube process in hp t770 plotter?
Here is a service manual that might help you.
http://www.partsnow.com/docs/service-manuals/hp-designjet-t770-t1200-service-manual.pdf
May 24, 2014 | HP DESIGNJET T770 Printer
Already change star wheel motor and formatter still error 59.2
Starwheel lift error--: you've done the right thing by replacing the lift motor but the question remains as to whether the plotter has had its firmware updated as part of the starwheel lift error is that the lift motor is engaging when it shouldnt, with the starwheel replacement kit there was a usb donlge supplied within the kit , this contains the updated firmware which needs installing when the lift mech is changed
if you have allready updated the fimware and are still seeing this error then the issue must be related to the lift motor and you may need to replace it again,
Sep 18, 2013 | HP DESIGNJET T770 Printer
79:03 error code t770
my ploter problrm t610 printer ready but carriage left side stucking and error showing on display 79:04 than replaced 3 no print head but not tready ploter why? i have replaced tralling cable .timing belt; formatter card , encoder strip , carriage block with carriage pcb but same problem .pls shuotout my issu.
Feb 11, 2012 | HP DESIGNJET T770 Printer
Error 45.1.03 for t770
switch off the machine, remove paper and spindle of both roll & 2, close the roll covers, switch on the machine wait until ready mode appears, select load media, select roll 1. Load spindle in in the bank, verify properly seated or not, insert paper to load wait to printer perform load media..if successfully loaded issue closed..:Other services are not advisable to users only professionals can resolve the issue..
Feb 01, 2012 | HP DESIGNJET T770 Printer
My HP Laserjet 4100 was plugged into a circuit for which the breaker tripped when an electric heater was plugged into it. Now it won't work and displays Error 49.4C02. I've turned it off and back on, but...
Thank you for contacting FixYa with your printer inquiry.
49.XX errors are communications errors. They usually are generated by electric interference to network connectivity or memory.
Actions:
  1. Clear all print jobs from the queues. If you have a lot of computers this is sometimes a quest.
  2. Re-start the printer and see if the error clears.
  3. Plug the printers power cord directly into an outlet and bypass the power strip/surge unit.
  4. Remove the Jet Direct (Network Card) and restart, then power down re-install and try again.
  5. Power Down and remove the formatter. Reseat DIMM's, re-install formatter board and try again.
  6. If error still pops up do a cold reset.
  7. If error still exists we may have to replace the formatter. Try formatter from 2nd unit prior.
  8. If you can install formatter in another printer and error follows we have the problem source.
I would try eBay or various vender's for your best deal on formatters if it's failed. HP made a ton of these printers. Formatter Board Part Number - C4169-60001. wz_gy7n1w_yc47r8o3mqb7mj4gfbnepczmqjlgwhi3vo1xoqkwn6lz_yemgm1lgeaghpyevyhuzxvimk4fdwuoblwawrivwtmhkebfopeekfv7wzkrpuctuxzoqpcngv87ecnuruzmgaejctdchnlxdnu2xoubwlr_arroebippyuw-pm7avnmdthiycrrbb-el0uije
Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 23, 2011 | HP LaserJet 4100 Printer
Getting error code 49.5507 on a HP3005n What does this error mean. Thank you
Firmware error. Turn off and on. The formatter is probably bad. If the printer was manufactured after March of 08, it has an extended warranty for 1 year on formatter board only. CALL HP and demand warranty service on formatter board. KNOWN PROBLEM.
Jan 11, 2010 | HP LaserJet P3005n Printer
HP DESIGNJET T770 Printer Logo
1,065 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
