Question about HP Color LaserJet 2600n Printer
Hp 2600 n
My hp2600 n model is printing light i have checked the tonner with another printer & its working fine i have cleaned all the mirrors but still same problem
Hi, I've a problem with a 1600 color printer, it only prints Black & Cayan and does not print the other two (Yellow & Magenta) would be a great help if someone can advise me on the solution to this problem. This is the first time I've picked-up this model for repairs. (All four cartridges are brand new and original) and it gives the same problem on the previous cartridges too!
Pls. help!
Thanks & rgds,
Posted on Dec 18, 2008
PC communicates with my HP laserjet 1020 but paper does not seem to pull through and wont print and orange fault light flashes then stays on
nothibg to warry about it just check tonner if its ok then do the servicing and also see for the paper jam chek may be ther e inside paper was jamed yeterday
Jun 07, 2012 | HP LaserJet 1020 Printer
Printer HP Color Laserjet 2605dn printer is not giving the color prints correctly. The colors are very fade, only black color is fine, rest all color combination are very light.
Your problem have only one solution - open laser/scaner Assembly carefully and clean all mirrors inside whit dry cloth. Dirty mirrors is the most frequently problem for 1600/2600 series
If you dont know how to do that just visit HP service
Mar 31, 2011 | HP Color LaserJet 2600n Printer
HP 2605dn printing pale on magenta
This is likley to be the common problem (with this model of printer) of the laser unit having dirty lenes and/or mirrors.
Typically the magenta is the first colour to deteriorate.
To rectify this problem there's a fair bit of dismantling to be done in order to get the laser unit out.
Then you can open the laser unit up and clean the lenses and mirrors CAREFULLY. You don't want to scratch the surface silvered mirrors, or disturb the alignment of any of the optical components.
You'll see the same problem and solution for HP1600, HP2600, and Canon LBP5000, as they all use the same laser unit.
Feb 09, 2010 | HP LaserJet 2605dn Printer
HP LJ 2600 "dirty" printing
If the toner cartridges are "refills" that might explain some of your print quality issues. Unfortunately, HP only has 2 replacement parts for that model, the fuser and the ETB (Transfer belt) both would require a technician to replace. Check the transfer belt of any tears or punctures. Careful not to touch it, oils from your skin can cause quality issues as well. If at all possible replace all the toners with ones that were working fine.
Jul 31, 2009 | HP Color LaserJet 2600n Printer
Canon LBP5000 lack of Red (magenta)
Searched on web for same problem on HP2600 printer and found a sight that explained how to fix it. It is caused by the mirrors getting dirty. Magenta is the first one affected because it is on the bottom and points upwards. Requires printer to be pulled apart and mirrors cleaned. takes about 1 to 2 hours. HP2600 printer seems to be the same as Canon LBP5000.
Jul 07, 2009 | Canon Office Equipment & Supplies
On hp 2600 colour printer
May 07, 2009 | HP Color LaserJet 2600n Printer
How do i strip hp 2600 to clean mirrors
Here's a PDF file on how to fix weak magenta color due to dirty mirrors on the 2600N.... the PDF shows in detail how to disassemble the printer to access the mirrors and how to clean them...
the PDF file is in the second post (Razmat)... click the "attachment" button
Good luck
May 06, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600 megnta not printing
thanks alot u solutions.iam very happy for giving me this knowledge.faisal
Aug 17, 2008 | HP Color LaserJet 2600n Printer
Magenta print out very light
This is caused by dust in the scanner assembly. There's a fan right by the magenta laser scanner that blows dust and particulate matter in the air directly on that laser scanner.
Requiring its removal and careful cleaning of all lenses and mirrors. Unfortunately, this is not covered in the service manual. Getting the laser/scanner out is not too bad: Start by removing the printer covers, the rear plate, and the plate on which the DC controller and formatter mount. Remove the four laser/scanner unit corner screws and the single screw for its cover. Be careful to remove the small shutter spring on the cover before removing the cover. Use a strong flashlight to carefully examine the copper-colored mirrors for dust. Use dry cotton swabs to carefully clean all dust from the mirrors and the lenses. Blow dirt and dust from the inside of the scanner box. You will notice that the bottom mirror, facing up, is the one with the most dust.
Jul 23, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
148 people viewed this question
Ben Johnson
