I appeal to you in a Grundig T 51-640 OIRT type device connection. The Act enabled the children because something may not be enough volume to a low (low) level be displayed in the dialog bar is moved to the lower left corner of the screen. Internet forums were advised that the device in the power switch on it and switched I hold the button and the service mode menu, choose the hotel but this did not help because I can not get the service menu, because when I turn in vain to hold the first It must write a 4- , Menu -> OK, just start the IMAGE MENU Appear where only light, contrast, color settings I can handle, other do not have access
SOURCE: Volume and menu does not display
I had this problem on my Aquos (LC-46D62U). It was NOT a hardware problem. I recommend turning off the television. Next unplug the television for 5 to 10 seconds. This resets something for the television. Plug it back in and turn on the television. You should now be able to get your volume and other on-screen displays.
Posted on Feb 18, 2008
SOURCE: black screen,no picture just a sound.not even menu bar displays
I had this same issue a year ago and I have it again. I was told it is the light. The company sent me a new one I installed it easily. Worked fine I am not sure why mine died so fast
Posted on Jan 03, 2008
SOURCE: 52 INCH sharp aquos lcd REMOTE NOT WORKING
Make sure your remote lock is set to off.
Posted on Apr 22, 2009
satavlad
  • 405 Answers
SOURCE: no picture
If model of your TV is LC19SB25U, TV powers up, TV has back light,but on picture or menu, The problem is the part called main unit.
Posted on Oct 24, 2009
  • 63 Answers
SOURCE: I get sound on my tv but no picture. not even volume bar or menu
check to see if there is an image on the screen by putting a light close to it if ther is an image replace the backlight inverter
Posted on Jul 09, 2010
How can I check out all the places my children been looking at on the wifi on the Internet
You have a Comcast box. You can set up parental controls for both viewing to TV and the Internet. Comcast can instruct you about how to do that. It may entail use of a PIN code at some point. Here are some pages related to that:
https://www.pgsd.org/cms/lib07/PA01916597/Centricity/Domain/46/Set%20Up%20Comcast%20Internet%20Parental%20Controls.pdf
Constant Guard Parental Controls
If you think your children are not savvy enough to erase the history of where they have been, you are mistaken. There is software that permits monitoring of devices but I have no idea how many devices are involved. It seems far easier to employ parental controls although that will always provide the prospect of tension between the adults if they have to enable or disable parental controls when they want to watch something. Use of any of this is a parental decision. Such is the digital age.
Sep 22, 2017 | Internet Computers & Internet
I have a Grundig TV model: GU22WDVD10, my sound has randomly stopped working when connected to my ps4 but works connected to my Xbox? I have tried different HDMI cables and still no sound
does the tv have audio in if yes try this,,,,use your tv instead of headphone ,,,, For the PlayStation 4, you can just use a regular set of 3.5mm headphones to hear game audio through the port on the DualShock 4. To do so, from the PS menu, go to Settings > Devices > Audio Devices > output to Headphones > With yourheadphones plugged in select "All Audio" as opposed to "Chat Audio You can also adjust the volume from Audio Devices > Volume Control (Headphones) - tv. this may work
May 17, 2016 | Grundig Televison & Video
Can I connect my digital receiver to my grundig ghc 1000 home theater? And how I can make the connection?
That depends on the make and model of the radio, and the available inputs on the GHC1000. Does your radio have a line output socket? If not, you can generally use the headphone socket to source a signal. Then all you'll need is a cable with a 3.5mm stereo plug on one end and two x RCA plugs at the other - easily available at low cost from an electronics store. The RCA plugs go to a free line input on the Grundig amplifier and the 3.5 mm plug goes into the radio's headphone socket. HOWEVER some radios require a DC return path to detect that there is something plugged into the socket. You Grundig cannot provide this, and if your radio needs it, this method will not work. So hopefully your radio will not need it.....
By the way, you will have to experiment with the volume setting on the radio if you decide to try connecting it this way and find that it does work. Set too low there will be insufficient audio to run the Home Theater at reasonable volume, too high and you'll get distorted sound. Trial and error is the way to go, but start with the Grundig's volume control set to a low level and the radio's volume control set about half way - to protect your speakers from potential damage if you accidentally drive them too loud
Oct 08, 2013 | Audio Players & Recorders
Children code
You're asking about how to release the child lock, I assumes and posts this solution. If you wish to get more details, check this site. http://electronicshelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Aug 31, 2013 | Grundig Televison & Video
Microphone not working when using skype
You just have to enable it in volume control ..(just engage the sound settings in control panel and you will find the point where you have to enable the mic and its volume ..or double click on the icon for volume in the tray system on task bar ...and in the volume control tab ..select options and in there select the mic or the pink rear entry ..and enable it ..)
Another thing to do ..is open skype ..and look in the settings or preferences..and make a call set-up ..or something like that ...basically you run a check for devices ...Im not sure how its called..I know its called like that in yahoo ..but on skype may be called check devices ..or check sound..and video ..and during that it will check them one by one ..and also enable if needed..
Dec 01, 2011 | Acer Aspire 5735 Notebook
Grundig GDP-6124 DVD Player has no sound
I have grundig 6124 and cant get standby off :(
May 30, 2010 | Televison & Video
We have a Grundig S350DL radio that was my father's. There is no manual. FM works great. Can't get AM. Radio turns off on its own!! Any suggestions?
The problem you are having may be due to some configuration settings (such as a timer). Not dtecting the AM signal, may be due to interference from power lines. To improve AM reception (if there is something to improve) one should rotate the radio to orient the internal ferrite antenna. Using the radio close to a window can improve reception.
To enable you to diagnose the problems that may be due to some configuration setting I give you the link to the radio's manual.
Hope it helps.
Nov 08, 2009 | Grundig S350 AM/FM/SW Radio
How to unlock a grundig t63-640?
Swich off tv from main swicher. Press i on remote control and hold it. Swicn on the tv from main swicher. On the screen should appear a service menu. Under decoder level with volume button from remote change from off to on. The same is with hotel mode for volume control. Exit the service menu by presing i on remote control and have a nice day!
Dec 27, 2007 | Grundig GF70-600 TV
Stereo volume doesn't effect Aux input volume
in a car stereo system, when you select line input, it usually assumes the device you are connecting has its own volume control. if you really want to use your cars volume knob, an FM transmitter might do the trick.
Nov 03, 2007 | Jensen MP7610 CD Player
Televison & Video Logo
Top Televison & Video Experts
