Question about HP 6530b Notebook
The screen is on, but the login page and desktop won't appear. i tried the various scans and there was an error with the hard drive.
  • 784 Answers
Hawe you tried with another hard drive?
Posted on Mar 18, 2011
My dell inspiron 545S won't load. gives me error #25
It' most likely that your hard disk drive is defective. Try to boot from a CD\DVD disc, if it does, you have a problem with your hard drive.
Feb 15, 2013 | Dell Inspiron 545 (884116037743) PC...
Tip
How to maintain your hard drive and check for bad sectors and errors
  1. Go to the Start Menu and choose My Computer
  2. Right click on the drive you want to check. I always check C: drive as it is my main drive.
  3. Choose Properties from the drop down menu.
  4. Click on the Tools tab
  5. Here you can press check now to scan your hard disc for errors.
  6. A box will appear with some choices. Choose to let Windows fix errors automatically.
  7. Then press start.
  8. When it is finished scanning a report will appear.
on May 16, 2010 | Computers & Internet
Alarm sounds on switch on and remains, dell screen appears as usual but stays longer, then bar at botton fills up but slower, then black screen with prompt in top left corner. Windows 7 ultimate will not...
Remove and reseat your ram. This should cancel out the alarm sound. If it still won't boot, you may have a dying hard drive. There should be some numbers illuminated on the outside of the case when there's an error. Search this number combination. If 3 and 4 are illuminated, search "Dell 34 error code." 34 for instance, is usually RAM not seated/installed.
Also, follow what the prompt says. If it's disc repair, try it, but know that you'll probably need to exchange your hard drive. Also, try the dell diagnostic, hitting F5 when you power on.
Nov 10, 2012 | Dell XPS 420 PC Desktop
I have a Dell 2400 Desktop that all of a sudden won't access the login screen. It powers on then the hard drive makes noise with the green lights blinking but it then says press F1 to continue but
First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Nov 05, 2012 | Computers & Internet
Playstation problem
that sounds like a corrupted hard drive...not 100% sure. u can try formatting your hard drive.
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
Smartdisk 80gb has power connection, but data (Mac)
scan the your computer and smartdisk for viruses
the problem you are mentioning about the desktop icons could be due to viruses
also run chkdsk utility on the smart drive after virus scan
Jul 12, 2009 | FireLite (USBFLB80) Hard Drive
Dell optiplex gx270 serious error!
it might be due to your new hard drive, plz check the ram also
Jun 22, 2009 | Dell OptiPlex GX270 PC Desktop
Bad_pool_header
Microsoft doesn't seem to have any information on XP having this error. But here's the general consensus after a little investigation:
1. Boot into safe mode by pressing the F8 key repetitively right after you turn on your PC until you see the safe mode screen.
2. Click Start >> Run. A Run window will appear.
3. Type "services.msc" in the Open field and then click OK. A "Services" window will open.
4. Find "Indexing Service" and double click on it. A "Indexing Service Properties" window will open.
5. Find the "Startup type" dropdown menu and select "Disabled", click "OK", and close the "Services" window.
6. Double click "My Computer" on your desktop. If it isn't there, then go to Start >> My Computer.
7. Find your hard drive, usually labeled "Local Disk (C:)", right-click on it and select "Properties". A dialog box will open.
8. Select the "Tools" tab.
9. In the upper third of the dialog box you'll see an area zoned "Error-checking". Click the button "Check Now". A new dialog box will open.
10. Check off the boxes "Automatically fix file system errors" and "Scan for and attempt recovery of bad sectors", then click "Start". You may be prompted to restart the computer. If this is the case, go ahead and restart.
Windows will check the hard drive for errors and run a surface scan. This may take a while depending on how big your hard drive is. Once it is finished, you'll arrive at your normal login screen. If Windows went ahead and ran the scan in safe mode without requiring a reboot then, once it is finished, go ahead and reboot the computer. Once at the login screen, go ahead and login. You shouldn't have the error any longer. If you do, be sure to report back here with details. The less details you provide, the less I can help.
Mar 21, 2009 | Microsoft Windows XP Professional SP2 for...
Replacing the battery on dell e510 - floppy disk drive not present
Replacing a laptop battery should not make a drive all of a sudden not appear.
You will have to enter the BIOS of the computer by hitting the required key stated at the first screen when Turning on the computer (usual located at the very bottom, it's almost always F2 or Tab or Delete)
Once in the BIOS the very first screen visible to you should tell you the drives hooked up to the machine VIA IDE or SATA. See if your HDD is located there.
Jun 19, 2008 | Dell Dimension E510 PC Desktop
HP 6530b Notebook Logo
41 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
