Question about BigAnt Office Messenger
BigAnt often hangs on my machine even it hangs the system and i can't shut it down through Task manager. But when i unplug lan cable system gets ok and then i can exit bigant. I am using windows server 2003
How to restart a pro line Intel sv.701
If you have Windows
Left-click START or the round blue Windows icon at bottom left of screen.
Or press the Windows key at bottom row of keyboard.
Left-click the white right-arrow symbol next to "Shut down".
This drops down a choice menu.
Left-click "Restart".
Now sit back and watch the magic happen.
Otherwise to shut down click the Shut down bar in Start window.
Or in case the PC freezes / hangs press "Power" button.
If an application hangs, stopping your computer, you can also try close down the app in "Task Manager".
Press Ctrl+Alt+Del
Wait until the Task Manager options window pops up on screen.
Left-click "Start task Manager"
Left-click "Applications"
Shut down the app then exit TM.
Reboot to refresh memory.
Dec 04, 2017 | Intel Computers & Internet
Why does my ethernet not work properly?
In order to decide wheather it is a HW or a SW fault, try to boot another operating system, eg. some one-CD Linux testing distribution. In case it is a SW problem:
- try to instal Asus update (utilities):
ASUS Update V7.17.17 for Windows XP 32bit/XP 64bit/Vista 32bit/Vista 64bit/7 32bit/7 64bit from:
http://www.asus.com/Motherboards/M2NSLI_Deluxe/HelpDesk_Download/
- try to set in BIOS: POST Check LAN Cable: ENABLE (for both LANs). Any error message?
- try to switch off one of LANs: Onboard 1st(2nd) nVidia LAN: DISABLED. Does the other LAN work?
The last step could be testing different version of BIOS...
The easiest way to get LAN ready could be installing PCI LAN card...
May 12, 2014 | Computers & Internet
My acer 5745 laptop get hang while charging.why?
Hi, Do this, Let the battery charge over night and see how it performs in the morning. It could be the battery is on it's way out. Replace with a new one soon. There is another battery a smaller one that keeps the clock and some programs running even when it is turned off.. But that should be ok.
You could try shutting down some programs when you work. Click on task manager and see how many program are running. But do not shut down system programs if you do, you may get into more trouble. Good luck.
Sep 19, 2011 | Computers & Internet
My sysytem wont get shut down. any trouble shout for that?
Usually it is a software program that hangs which causes this problem. Check your task manager by hitting cntrl+alt+del if using windows and see what is not shutting down. Once you have the offemding software isolated you can shut it down manually and then check the settings for that software. Hope this helps.
Sep 17, 2009 | Intel DG31PR Motherboard
Displays sys error session manager initialization terminated unexpectedly status of 0xc00026c (0x00000000 0x00000000)
smss.exe is the process that manages sessions in Windows Computer. This is the session manager subsystem, which is responsible for starting the user session. This process is initiated by the main system thread and is responsible for various activities, including launching the Winlogon and Win32 (Csrss.exe) processes, and setting system variables. After it has launched these processes, it waits for either Winlogon or Csrss to end. If this happens normally, the system shuts down; if it happens unexpectedly, smss.exe causes the system to stop responding (hang).
In this case, I suggest that you start the "smss.exe" process manually from the Task Manager. You can press the "Ctrl+Shift+Esc" together to display the Task Manger window. Then, click on the Applications tab then the "new task" tab located at the bottom. In the New task dialog box, please type "smss.exe" and click OK.
However, you can also perform System Restore to restore the Windows System files to the time when it operated normally. Performing System restore will not delete any saved data however, all the installed programs after the selected restored point will be unistalled and require to reinstall them.
Jul 11, 2009 | Computers & Internet
Ourmicrosoft word 2007 did not get to access
When an application hangs like that, there are a couple of options you have to shut down the system. The safest is to open the task manager, if you have mouse control, by right clicking on the task bar and choosing task manager. In the menu bar across the top of the task manager you'll see an option to shut down the computer, which if chosen will probably prompt you to end the program that's hanging. There's also an applications tab, which will allow you to select the problem program and end the task, which will sometimes enable you to free up the system without shutting down. This option should be used judiciously, however, and only when you have already tried other conventional means to end a program from within the program app itself. If you can't access task manager from the taskbar, you can also press ctrl + alt + del at the same time, and the task manager windows should come up...
Finally, you have the option to perform a hard shutdown by holding the start button down until the system closes itself down. This should only be used in dire circumstances, when you've given the system a chance to finish whatever it's processing and other means aren't working. A shutdown like this doesn't give the system a chance to save its settings and you risk losing your work and otherwise confusing the workings of things, so it's best to save this for when all else fails.
Once you get the system to start normally, you can use the built-in windows event viewer to look at what warnings or errors were encountered when the system froze up, and try to diagnose the cause and correct the problem....
If there's a problem with file corruption, for example, this may be found and or corrected by running checkdisk on the system...etc.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Fin
Jul 02, 2009 | Microsoft Office Word 2007 Full Version...
Network connection prompt error 6: handle is invalid
Hi glamredhel, Norton has removed the virus or Trojan & if you have windows system restore turned on the virus or Trojan will return once the system has re-booted. Open windows device manager & shut off system restore. Re-boot your system & re-scan your system with Norton. In your case Norton did not give you instructions on how to remove the virus. (Norton did that for you).
Once completed check windows update service for a possible update for your LAN. Asus does not have a separate LAN driver listed on Asus web site. The LAN driver is part of the chipset drivers. Remove your modem from the system & any software you installed with it. (If any). Restart your system. (If the system seems fine-good. Shut down the system & re-install your modem & any software. When completed do another windows restart. See if the modem functions (If your modem is either a cable or DSL reset it.
Shut down the system.
Located on the back of the cable modem or DSL modem you will find a tiny re-set button. Unplug the power cord from the modem. Take a pen & press the reset button for 10 seconds. Re-connect the power cord & boot the system. Check for internet connection.
The above are just a few item you should try.
Good luck glamredhel!
Post your findings.
Mike
Mar 23, 2009 | ASUS M2N-MX Motherboard
Laptop does not shutdown it hangs while shutdowning what is solution why does it happen
Hi
You need to remove the battery and then place it back , it will surely work .
You can also download easy shutdown from this link
http://www.tucows.com/preview/337660
Thanks
Rylee
Jan 08, 2009 | Acer Aspire 5315 Notebook
Computer will not shut down
I have not switched to Vista, but I would try starting the Task Manager (right click on the task bar and select task manager). Then I would select the Processes tab and start killing processes to see if you can track down which one is causing your problem. Assuming you can narrow this problem down to a single process you'll at least have a fighting chance at solving fixing this.
Good luck.
Nov 19, 2007 | Acer Aspire L100 PC Desktop
AOL Hourglass
Download and install "Registry Mechanic" then do the updates prior to running it and removing anything for the first time. This will get rid of all your current Registry errors.
Try AOL again.
If AOL is still not working...
Un-install AOL.
Shut down completely for at lest 30 seconds, then restart.
Then do a search for all AOL files and folders with the options "Search system folders", "Search hidden files and folders" and "Search subfolders" checked. Delete all of those found.
Restart then run Registry Mechanic again.
Shutdown restart.
Reinstall AOL.
Sep 11, 2007 | Computers & Internet
Computers & Internet Logo
101 people viewed this question
Top BigAnt Office Messenger Computers & Internet Experts
David Payne
David Payne
Are you a BigAnt Office Messenger Computer and Internet Expert? Answer questions, earn points and help others
