Question about Linksys WRT110 Wireless Router
Hi, I have a linkysy wrt 110 wireless router. I would like to secure it because at the moment it for some reason has become unsecure. Any help wuld be appreciate
    Problem Solver:
  • 6 Answers
If your router was connected to your computer at one time... This is a healthy starting point.
Be careful with this you can do lots of damage if you aren't exactly certain about what you are doing.
Step A. Type the following link into your browser
http://192.168.1.1/Wireless_Basic.asp
Step B. The active X on the system will ask you for the user name. type: admin (small characters)
Step C. The active X also prompts for a password. type: admin (same as above using small character sets)
Upon successful completion, you will be in your advanced settings menu.
You will see several tabs on this GUI.
Step D. Select the wireless tab and its' sub-tab "wireless security"
These are your security settings. Set them as you choose and save the changes.
BE CAUTIONED: This menu by itself can be dangerous... THERE EXISTS THE STRONG POSSIBILITY FOR DAMAGE, IF YOU CHANGE OTHER SETTING IN DIFFERENT MENUS!
I hope that helps. :)
The other way is to remove the drivers off of the system. Pull the secondaries out of the register. And then re-install the device (following the manufacturers directions).
Posted on Mar 18, 2011
    President:
  • 1,768 Answers
Here is the Linksys/Cisco site download and how to site secure your router.
http://homesupport.cisco.com/en-us/wireless/lbc/WRT110/download
I just need help setting up a password for the wireless? It is unsecured at the moment?
Login to your router using your webbrowser.
Most likely its 192.168.0.1 (check the bottom of your router)
In control panel look for security or wpa-wep.
There you can set a own key you want.
GOOD LUCK
I've you need help doing this, i will be able to help you remotely.
Contact me by email:
djskywalker@live.nl
Jun 18, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a linksys wrt 150n router. i've connected my imac wirelessly, but cannot get my pc-laptop to connect. what am i doing wrong? yes, it is secured with a password.
hi parkerjunkma,
be sure you detected the wrt..then the SSID and Security Encryption should be matched..the SSID will definitely detected so the Password should be entered.
mastergani
Dec 28, 2010 | Linksys Wireless-N WRT150N Router
How do i make my linksys router secure as at the moment it is unsecured
It depends what you mean by secure. If it is just acces to the router settings then add an adminstrator password. If it is wireless security you are refering to then goto you wireless settings and choose WPA2 as i find it more secure however you can choose any you would like.
Oct 23, 2010 | Linksys Computers & Internet
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
Sep 15, 2010 | Linksys WRT160N Wireless Router
Secure network becomes unsecure all of a sudden
Sounds like the battery that backs up this router's "firmware" and "programmable" memory settings may be going bad. Then again, it may not have a battery that does this. Perhaps the little reset button on the back is jammed in?
Feb 27, 2009 | Linksys Wireless-G WRT54G Router
My laptop can't find my wireless router
the best would be trying to upgrading your router to a new firmware like tomato or dd-wrt which has much better features and your wireless device would start working.
www.dd-wrt.com that is the one i use and its fantastic.
Dec 29, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I need to set up a security password for my router at the moment i have a unsecured network?
Open an internet window type in your router's ip address and hit go, this will take you into your router's configuration. In there you should see a wireless section in which will be security, you can secure your network there (use WPA or WPA2 it's the most secure). When you have set this you will need to enter your password to all the wireless devices connected to your network.
If you google your routers make and setting up security, you should find a step by step guide.
Hope this helps
May 24, 2008 | Computers & Internet
Lynksis wrt150n .. setting
Log in to your router and select the wireless tab. Then click on wireless security. Set your security mode, encryption type and create a key that will be needed to connect to the router wirelessly. Administration tab should be right next to status tab.
May 14, 2008 | Linksys Wireless-N WRT150N Router
Linksys WRT110 Wireless Router Logo
120 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
