Question about Sony STR-DA80ES Receiver
Can I find the remote for the Sony STR DA-80ES? I am being offered one without the remote and I believe that Setup of speakers, etc is not fully possible without the remote. Is that true? Thanks in advance Javed Shakoor
    Brigadier General:
  • 8,546 Answers
That is true.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DA80ES-Receivers-manual/id/930dj592/t/2/
A substitute for the RM-P501 is available for $48 plus shipping...
http://remotes.com/remotes/servlet/rs?a=gmi&smodel=STRDA80ES&brand_pn=SONY_STRDA80ES&mode=large&uuid=A13004461623871
Posted on Mar 18, 2011
No sound on coax audio input from HDTV
Check your settings on your tv. You may have to turn off the internal tv speakers in the setup menu in order to get any audio output from the jacks on the back.
Dec 20, 2012 | Sony STR-DE835 Receiver
I have a sony STR-DH510 receiver and the speaker set that goes with the DAV-BC 150. i hooked up the speakers but i couldn't get the sub to output any sound. is there anything i can do to get it to work?
Hello ,you will want to go into the setup mode on the remote and make sure the subwoofer is turned on,it might be turned off .You can view the setings right on the front of the reciever as your scrolling thru speaker setting options.
Feb 08, 2011 | Sony STR-DH500 A/V Receiver
Cannot get test pattern to run. I select Menu->setup-> 5.1 Pattern...then press enter....and nothing happens... Have easy setup set to yes....I remember there was a static pattern that would...
press the tes ttone button on your remote control for the test signal. it will sequence thru each speaker clockwise starting with the right front. watch the unit display to see which speaker it sending the signal to as it goes thru it paces.
Dec 22, 2010 | Sony STR-DE897 Receiver
No Center Channel on STR-DA5200ES
Da 5200es. Workiig only two Chanel i need five chanel. ihave no remot
Aug 04, 2009 | Sony STR-DA5200ES Receiver
The sound on the 2 front speakers and the sub woofer on my Sony STR-DE597 turned off and I can't figure out to turn them back on. I've lost my manuel. When I use the test tone on the remote, only the rear...
First, you can find your manual here:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=STRDE597
You may have accidentally pressed the speaker select button and disabled speaker A (main) and enabled Speaker B or disabled both A and B. Start with page 40 in the manual to select Speaker A.
On the remote, press the "Speakers" button (Off/A/B/A+B) repeatedly until you hear some noise.
May 02, 2009 | Sony STR-DE597 Receiver
Sony str de545 5.1
Make sure the subwoofer is set to On in the setup menu. Should be able to access this setting from the front panel, using the click wheel and the left/right buttons above the wheel. Push the setup button to get to the right menu. Set subwoofer to 'on' and speaker size to 'small'. This receiver has a fixed crossover, so make sure to turn the crossover setting on the subwoofer to the maximum setting (highest frequency) to ensure no signal is lost.
Oct 22, 2008 | Sony STR-DE545 Receiver
Speaker Channels? STR-DE505
Hi There,
Maybe can clarify the reasons you have different output configurations.
I worked for Dolby in London for ten years and cinema processing was an area close to me.
To cut a long story short;
The number of factors and different combinations possible for a fully equipped cinema offering Dolby and / or other protocols to the guest is large to say the least even within the Dolby formats.
For Sony to try to offer a range of home units (recievers or tuner/amps/decoders in this case) was to say the least ambitious .but hey!..........who else can give the public what they think they need.,,,good old Sony
I have looked at this unit and it seems the "amplifier section" is used for various configourations
and power output ratings vary depending on the configuration you choose.
Stereo 2 ch L+R is 2 x 75w
Surround requires more channels (centre and mono rear) and of course new signal routing to and from these blocks which of course will draw from the modest power supply.
So 4 channel surround will deliver 4 x 50w.
etc. etc.............what you hear are the relays which are reconfiguring and re - routing the signals.
Basically you cant have all the sections working all the time due to cost /design restraints
So speakers A OR B can be used but not BOTH when in surround mode....where the centre and surround are needed. .you cant have A and B at any time....push both buttons an NEITHER will work ....release one button and there you go.............it saves "letting the smoke out of the box".........which you should never do...........cos they never work without it. :)
Sorry for boring you ...............but I think you will find the unit is working just fine.............you could read the manual but that's not too informative.
Right...off to get a life now
Nik
Aug 01, 2008 | Sony STR-DE505 Receiver
STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
Jul 06, 2008 | Sony STR-DG800 Receiver
2.1 speaker setup sony str-dg510
please explain in better detail.
Dec 15, 2007 | Sony STR-DG510 Receiver
112 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
