SOURCE: Hi , We're trying to print
the only thing I see missing is the ":" after lpt1
ie - command should be copy test.txt lpt1:
you could also try using print test.txt
or type test.txt > lpt1:
1. Save your text file (.txt).
2. On the command prompt navigate to that directory
3.Type "Lpr -S 192.168.1.200 -P lp text.txt"
Substitute 192.168.1.200 for your copier's ip
Substitute text.txt to filename.
Or you can: to print from MS-DOS apps.
1. Share the printer on a networked windows computer. Make sure you make the name MS-DOS compatible.
2. At a DOS prompt, type the following command:
"net use lpt1: \\servername\printer_share/persistent:yes"
NOTE Servername=computer name
printer_share=printers share name
