Question about Zebra TLP 2844-Z Thermal Label Printer
Hi , We're trying to print the file to TLP 2844 using DOS commend : copy test.txt LPT1 , but the printer does not response . We installed the out-box driver and make the driver pointed to LPT1, It works well when we try to print in Windows Notepad . Have no idea what's the problem would be ? Thanks Nick Zeng
  • 1,591 Answers
The only thing I see missing is the ":" after lpt1
ie - command should be copy test.txt lpt1:
you could also try using print test.txt
or type test.txt > lpt1:
Posted on Mar 18, 2011
How do I download driver for Mitsubishi P90 Printer?
You could try this page which appears to have a general driver installer download link: http://xpdrivers.com/printer/_1_18.cfm (Post 1994 Prtr)
However, it may be you can still print WITHOUT drivers if you just send PLAIN TEXT (*.txt) files IN THE DOS PROMPT windows environment. Eg "copy c:shopping.txt LPT1".
Good Luck
Jun 18, 2014 | Office Equipment & Supplies
Send a .txt file (zpl language to COM1) to theTLP 2824-Z.
Help!!! I can not print barcode with DOS-command "copy barcode.txt com1". DOS Version is 6.1.7600. The printer zebra TLP 2844 does not recognize the EPL commands.
j.zh
Jul 28, 2009 | Zebra TLP 2844-Z Thermal Label Printer
How Send EPL2 commands to USB
Use the Zebra ZUD driver. Latest version V5.5.7.25 (Download from Zebra website). When driver is installed, go to printer & Faxes folder and double-click on the installed printer icon.
Click Printer/properties/printer/advanced (+)/tools (Click on tools) This opens a text box. Type commands in here and send directly to printer. E.G type U click send and it will print a config sheet.
This definately works.
May 14, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844 problem "AUTOFR"
Comment est que voue envoyer des commandes?
Est que vous utiliser USB?
COPY file USB??? quelle est la syntax? pas de LPT1 sur ma machine...
donque COPY file LPT1 /A ne marche pas
Zebra printers & MS Word
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at Zebra.com
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
Sep 24, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Trying to setup a Zebra TLP 2844-Z on serial port
Two possibilities are the port configuration and the type of serial cable.
The printer has a feature that will try to match itself to the PC's configuration. Press and hold the feed button until the green status led flashes three times. While the led flashes send a ZPL format to the printer (hopefully you can do this through Design Pro by trying to adjust the printer or print labels, but the labels will not print). When the printer and PC are synchonized, the led changes to solid green.
If you can synchonize but still can't print, the problem might be the serial cable; not all serial cables will work. You should use a full null model cable (all pins connected except 1 and 8).
Sep 19, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Help me with Zebra TLP 2844
The printer only understands EPL code. (Eltron Programming Language) If you are trying to print text from DOS it wont understand (interpret) the txt codes.
To verify that the printer is working.
Open a DOS box, start the dos editor. Type Edit. Dos editor will open.
Type a single capital letter U. and print. Send to printer. The printer will print a configuration label.
EPL code to reset printer is
^default.
If you want to print a text file. use the Zebra Universal Driver. Zebra TLP2844. Open any windows application. E,G, Notepad. type text and send it to printer. Print as normal.
Jul 24, 2008 | Zebra LP 2844 Thermal Printer
USB printing through DOS mode
Google for DOS PRINT USB, and you'll find some utilities that do this.
Or, you can include some commands in your batch file.
First, get the device name:
In a DOS window, type NET VIEW ComputerName (or use 127.0.0.1)
Once you know the printer share name, you use it in a batch file.
NET USE lpt1: \\ComputerName\ShareName /Persistent:Y
This captures the print queue to the shared printer.
You must also go into Printer Properties/Advanced/Print Processor and set it to TEXT
Your copy, print and other commands will work.
Jul 12, 2008 | Computers & Internet
Zebra TLP 2844-Z Thermal Label Printer Logo
370 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
