Question about Sony Handycam DCR-HC20 Mini DV Digital Camcorder
Computer not recognizing camera
I've installed USB driver, but when I connected the camera with USB, the camputer couldn't find it.
  • huajun Aug 02, 2008
    Yes, I set USB Stream line on.
Use firewire cable and it will work
Posted on Aug 11, 2008
  • 10,594 Answers
Go to camera Menu and enable USB Streaming option. PC will recognize it.
Posted on Aug 02, 2008
  • Shahid Electronics
    Shahid Electronics Aug 02, 2008
    Let me know out come....and rate the solution properly.
I have plugged it in and it my computer will not recognize that the USB is even plugged in, but it does charge the camera.
Try all the different USB Ports on your computer, sometimes certain ports can 'glitch' and not recognize the device that you've plugged in. If you've tried plugging it in all the ports and your computer still hasn't recognized the camera, re-install the driver software for the Olympus SP800UZ.
If all else fails, you can also contact Olympus customer service, they're quite prompt and helpful.
May 17, 2011 | Olympus SP800UZ Digital Camera
The memory card is not showing my pictures when i plug my camera into my laptop
Please follow the steps below for connecting the Camera to the Computer for transferring the images.
Turn the Camera ON.
Turn the Computer ON.
Make sure to Insert the Memory Stick in the Camera.
Set the USB CONNECT option in the Setup 2 Menu of the Camera to PTP. [Set the Mode dial of the Camera to Camera, press the Menu button, select SETUP-->SETUP2-->USB CONNECT-->PTP-->OK.]
Connect the Camera to the Computer using the supplied USB cable.
The Computer will automatically install the USB Driver for the Camera.
When the installation completes, an AutoPlay window will appear.
In the AutoPlay window, click the Import Pictures option.
In the Importing Pictures and Videos window, click the Import button.
If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat changing the USB CONNECT option to PictBridge, Mass Storage or Auto.
If the issue persists, try connecting to a different USB port on the Computer.
Try re-installing the USB Driver from the Device Manager.
Good Luck!
KenSolutions
Nov 23, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Cannot transfer movies from camera to my computer. have new computer
Check whether the Camera has any settings that has to be selected in order to connect it to the Computer.
If the Computer is not recognizing the Camera/Camcorder, check whether the USB Driver is installed in the Computer or not. Also, the Computer will not recognize the Camera/Camcorder if the USB Driver is corrupted. In this case you may un-install and install the USB Driver is the Computer.
After the Computer recognizes as Removable device, you can double-click on it to view the video files stored in the Memory of the Camera. Then, you can copy and paste the video files to the desired location on the Hard drive of the Computer.
If un-installing and installing the USB Driver does not work then you may transfer the files using Memory Card Reader.
If the Computer has the Memory Stick slot, then you can transfer the video files without using the Card Reader.
Jul 17, 2010 | Cameras
Camera will not upload photos to computer
Depending on the method you're using, this can usually be remedied in one of two ways:
  1. USB Cable: make sure your camera is turned off before connecting to the computer, and that the drivers for your camera have been loaded prior to connecting.
  2. Memory Card: SD or MMC card readers are becoming more std. on computers, or inexpensive card readers are available to connect via USB.
If you are experiencing difficulties with either of these, this may involve a problem with your USB port or the drivers your computer is using. Sometimes it's as simple as removing the driver which isn't working properly and re-installing it again. In most cases, you will need to install the driver without the USB device connected, so that after you have successfully loaded the driver, the computer will recognize your USB device properly.
Once again, make sure your camera is turned OFF when you connect it to your computer with the USB cable (of course, your computer needs to be turned on). Then, turn the camera on, and you should see the computer recognize the device.
Apr 01, 2010 | Kodak EasyShare Z760 Digital Camera
EasyShare DX6440 "USB Device not recognized"
What operating system are you using?
If you have xp or vista, you can uninstall the software and transfer the pictures since these operating system has built in drivers.
Jun 23, 2009 | Kodak EasyShare DX6440 Digital Camera
USB connection dosen't work properly in PC
FORMAT MEMORY STICK IN CAMERA AND LOAD SONY SOFTWARE FOR YOUR MODEL CAMERA. IF YOU DONT HAVE CD GO TO SONY.COM THEY HAVE TROUBLE SHOOTING TO.
Apr 28, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
I HAVE A SONY DIGI CAM MODEL DSC W-5. MY PC IS NOW UPGRADED WITH WINDOWS VISTA AND SINCE THEN IT IS NOT POSSIBLE TO DOWNLOAD THE PICTURE TO PC. THE INSTALLATION CD ISSUED WITH CAMERA DOES NOT COMPITABLE...
  1. Turn on the camera.
  2. Insert the recording media containing the pictures into the camera.
  3. Depending on your camera, set the USB Connection or Transfer mode setting in the menu to the Mass Storage , Normal , or PTP .
  4. Use the USB cable supplied with the camera to connect the camera to the computer. IMPORTANT:
    • Connection through a USB hub or other USB device -- such as a printer or keyboard -- is not supported and cannot be guaranteed. Connect the camera directly to a USB port on the computer.
    • If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat steps 4 and 5 using a different USB Connection or Transfer mode setting. If the connection is still not recognized, further troubleshooting is available.
    NOTES:
    • The computer will automatically install the USB driver for the camera.
    • When the camera connection is established, an AutoPlay window will appear.
  5. In the AutoPlay window, click Import pictures .
  6. In the Importing Pictures and Videos window, click the Import button. NOTE: After the pictures have been imported, the Windows Photo Gallery window will appear and display thumbnails of the imported images.
If this doesn't work there is an updated driver available
Here
(from Sony Website)
Mar 19, 2009 | Sony Cameras
Windows doesn's recognize camera, device manager says no driver
Hi -
Have you tried another USB port? Sometimes, they can act goofy.
Also be sure your anti-virus isn't blocking any part of the installation.
Here is a link to the Samsung troubleshooting guide for your camera.
You can probably download the most recent driver from that website as well.
Perhaps they have a better or newer version than what came prepackaged
with the camera (just because a camera is a new purchase does not mean
the software it came with is the most updated).
http://tinyurl.com/5zsvwd
I run WinXP home edition, so I am not familiar if there are any differences in the professional version regarding software installation....
Dec 17, 2008 | Samsung L100 Digital Camera
Usb not recognizing camera
you have to install drivers on your computer before it will recognize it.
go to
http://www.fujifilmusa.com/JSP/fuji/epartners/
ServiceSupportProduct.jsp?prodcat=710738
and install the usb drivers for your operating system ie windows xp
Your computer will recognize it after that whenever you plug it in:)
Feb 23, 2008 | Fuji FinePix A330 Digital Camera
Sony Handycam DCR-HC20 Mini DV Digital Camcorder Logo
417 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
sonic boom...
sonic boom...
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
