Question about Boating
I have a 2003 mariner 200 efi it is autolube feed from a large tank when i start very smokey so i left the leg down for 2 doays trimmed it up and oil dripping from g/box i smelt it and 2 stroke must be coming from exhaust is there a small valve that should shut off whilst not running but now jammed open so floods because of the presure from the autolube tank
  • greggilbe338 Mar 19, 2011
    no this is 2 stroke oil not gearbox oil,this comes from outside the engine not g/box from the barrels down the exhaust which leeds to the prop which is housed in the g/box i am fully competaint to strip down engines or pumps as obviously this is coming from the 2 stroke pump.i hope this isnt gonna cost me any more money for an answer.
    President:
  • 1,654 Answers
My guess is the diaphram on the oil pump is bad. THE OIL IS INTRODUCED THROUGH A DIAPHRAM STLYE FUEL PUMP MOUNTED ON THE PORT SIDE OF YOUR MOTOR. You can disconnec the oill tank and run the motor for a few seconds to clear the pump then try connecting it again. There might have been a siphon started from a weak diaphram. Too much pressure from the tank can riun the diaphram causing it to leak into the motor. You should disconnect the oil tank when the boat is stored to keep pressure of this. You can replace the pump which is expensive or disconnect it and mix the oil in the tank. Most people do this after they burn the motor up from a bad oil injector. When I get this for rebuild 9 out of ten disconnect the pump. When the oil is mixed there is no doubt your getting the correct oil at all times.
Posted on Mar 19, 2011
    Guru:
  • 1,833 Answers
You have to open gear box and reassemble it. There is a alignment problem of gearbox with fly wheel. Please call a mechanic. You will not be able to do it yourself.
Posted on Mar 18, 2011
Alarm warning system on '02 Mercury Mariner 150HP E.F.I.-
Engine tank should be plumb full tight. The engine supplies about 2 lbs pressure through one of the 2 lines going to the boat tank. The other line takes the oil to the engine tank. If that line gets kinked or pinched, the engine tank won't get oil, a check valve lets a little air into it, and the oil pump keeps getting oil. When it goes down just a little, the alarm goes off telling you something is wrong.
Sludge in the boat tank could plug up the pickup screen. I've also seen them plugged up by a foil oil bottle seal carelessly dropped into the tank.
Once you find out why the oil couldn't get there, start the engine with the cowl off and loosen the cap on the engine oil tank until it leaks, then tighten it down and clean up the mess. That tank is normally plumb full tight.
If when the engine is running, you crack the cap on the boat tank, you should hear pressure let off. If the cap leaks, it won't build up pressure. If there is pressure, the oil line is plugged or kinked.
If pressure isn't supplied, the problem would be the crankcase check valve on the engine, lower forward starboard side, with the hose going to it.
hope it helps
Jul 05, 2008 | 2002 Mercury Mariner
Just started my suzuki 4 hp out board after long lay up engine starts and runs but only if choke left out is a bit smokey and oil in water drum
before you go ant further it will need a new impeller in the water pump---long periods of inactivity allows the blades to perish in a position and when started they tend to break of followed by the rest at a critical time
next the main jets are corroded up and blocked
there is a product sold by marine shops that you can soak the carby in that helps remove the corrosion --other than that it is a carby rebuild
as the exhaust is normally near the propeller and I assume that it is a 2 stroke then the oil in the fuel mixture will be exhausting with the gas and leaving a residue in the drum
other items that will need replacing are fuel hoses ( deteriorate from the inside , hand pump in the fuel line and the diaphragm in the engine pump
Jun 30, 2015 | Suzuki Motorcycles
I have a yamaha dt 200 1996 that will oil up terribly when left to sit for over a day. Starting isn't too much of a problem except for when the bike has been sitting. Any thoughts on how to fix?
Not familiar with that bike...is the oil tank higher than the carb? I have seen 2 strokes weep past the injection pump into the carb if the tank was high. a simple fix to that is to get a longer line and put a loop in it. I have also seen vents on the oil tank get clogged with dirt, then expansion of the oil in the tank forces it into the carb...check to make sure the tank is venting. If it is venting...then I would loop the oil feed line,,,don't even really have to loop it...just at some point the line needs to be lower than the carb, how much lower is trial and error, but oil generally doesn't weep upwards very easily.
Mar 22, 2014 | 2005 Yamaha DT 125 X
Mercury Verado 300's smoke on initial start when left for more than 5 days. What causes this and how do I fix this?
Hi, do you store your boat with the motors trimmed down? If so leave them stored at the upper trim position as when left down oil off the cylinder walls by passes the rings to the combustion chambers, hence the smoke on start up. Regards Phil.
Sep 09, 2012 | Boating
The bike has had the autolube system capped off & change to petrol & oil mixing in the tank. it was starting but i think the air-fuel ratio may be wrong or the carburetter needles sticking & what rati
Hi Anonymous, for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix/test or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day. DOWNLOAD 2008 Aprilia Rx 125
Dec 04, 2011 | 2008 Aprilia RX 125
My soft top is not letting down completely and the retractors are not shutting. I hold the button for a long time and the alarm chimes that the top is not completely down. mine is a 2003
This top is electric/ hydraulic, there could be a bad motor or a hydraulic problem,start by check the top oil level, remove left luggage trim cover, there you will see resivior,next open the top all the way. remove cap and check level.heres a picture to help you.you will see pump when you remove the trim cover, use vw top oil only.the next thing is to check all the fuses.there are a few motor also. start here.
Feb 27, 2010 | 2003 Volkswagen New Beetle Convertible
I want to change my big foot 60hp from power tilt to power trim how do i do that??? 90850260 that is my serial number what is the year model?
I dont knowthe year ,that should be stamped on the id plate. As for tilt and trim----- in the lowest position the leg will only move slowly out and up that is when it is in the trim mode, after that it goes into the tilt mode and the leg travels considerably faster, this works going up and down,putting the leg down, it will travel faster until the last foot or so then it goes into the trim mode automaticaly and travels slower but with more power---you cant split them.It needs the extra power to be able to"trim"" the boat whilst it has the water pressure against it at ,say 25 knots. To test what i am saying ,puthe leg down as far as it will go ,stand on the anti cavitation plate and push the button to raise the leg .You will see it will only traveh ashort way out and up be fore stopping because it doesnt have the extra power to lift you as it did in the first foot and a half.thatis the system and you cant change it if that is unclear take it to a dealer ,he may explain it better---------"youdoit"
Sep 20, 2009 | 2000 Mercury Mariner
How do I bleed and change the hydraulic trim fliud in my 75 hs Mariner outboard? I believe that I had an airlock, I opened the pit screws, and the motor was able to go back down. It appeared that there...
you need to find your drain- fill screw get trim oil with a pointed tip cut tip to fit tight fill oil with trim up once filled turn bleed screww and lower motor fast once down tight bleed screw fast use trim switch to raise motor and bleed again do this 2-3 times and u should remove all the air comment me back if you have any ?s
May 18, 2009 | Boating
Boating Logo
550 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
