Question about Intermec EasyCoder PF8t Thermal Barcode Label PN PF8TA03101000 Printer
Pf8t Intermec printer turns on but once you print a label the red error light comes on.
2 Suggested Answers
RCtech
  • 55 Answers
SOURCE: I have an Intermec PF8t
depending on what version of office your using you will find a label tab under mailings (in office 07) or under tools (previous versions) you should be able to specifiy a label type or build a custom label.
Posted on Dec 10, 2008
My printer is intermec PF8T i have i SAP program to print patient information but it cannot print the error is orange ligths was the error.
There are a few things to figure out here from a SAP basis administrator perspective these steps are common. Also I am just trying to help and with SAP there could be multiple solutions. Good luck.
Check SAP MarketPlace for SAP note: 1557674
Here are the steps taken from the SAP Community Network which might help. I would suggest reading the entire link as its informative. http://scn.sap.com/thread/1975158
Step:
run SPAD
to create an output device, choose Output Devices on the Devices/Server Tab
click on Display now you will be in Spool Administration window
click on Change button then Create tab will be appear, now you have to put the following information.
Under DeviceAttributees
put the Output Device name with shortname
Device Type: SAPWIN
Device class: Standards printer
you can put Model/Location/Message as per concern.
Under Access Method
Access Method: G
Host Printer: __default
save
for more information about
Device Type
http://help.sap.com/saphelp_nwmobile711/helpdata/en/d9/4a910f51ea11d189570000e829fbbd/content.htm
Access Method
http://help.sap.com/saphelp_nw70/helpdata/en/4f/9c033cff903105e10000000a114084/content.htm
(1) Choose "S: Print Using SAP Protocol" if a print server with SAPlpd or SAPsprint is used to print barcodes.
(2) Choose "F: Printing on Frontend Computer" if SAPlpd and SAP GUI are used together to print barcodes, SAP GUI sends print job to SAPlpd, SAPlpd is started automatically and forwards the print data stream to the Windows print manager.
(3) Choose "G: Frontend Printing with Control Tech", only SAP GUI is involved in printing barcodes, SAPlpd is not used.
Here are the Intermec drivers:
http://www.intermec.com/support/downloads/index.aspx
Understanding the LED Indicators
LED Meaning
Green (blinking) Auto-Sensing mode
Green (blinking) Downloading font, form, or graphic
Green (solid) Dump mode
Green (solid) Ready mode
Green (solid) Print mode
Orange (solid) Boot mode
Red (blinking) Media jam, overheated print head or stepper
motor
Red (blinking) Downloading firmware
Red (solid) Error mode
Good luck
Dec 27, 2013 | Intermec Office Equipment & Supplies
PM4i print error "out of paper...." How can I
When printing start take and keep with fingers label,pull sametime label when start,after that some sensor?? work again and next printing session come out ok.
May 12, 2011 | Intermec EasyCoder PM4i Printer
REQUIRED DRIVER FOR INTERMEC PF8t BARCODE PRINTER
here is the download site we use for intermec downloads its safe fast and free good luck
please remember to rank this advice
sonic boom electronics
Dec 28, 2010 | Intermec Cable (USB Adapter) for Keyboard...
I have an Intermec PF8t printer with InterDriver Windows Driver -- How can I get my labels created in Microsoft Office to print? How do I specify label size?
Dec 10, 2008 | Intermec Office Equipment & Supplies
I have an Label Printer Intermec Easycoder 3400 which is kind of old (more than 8 years), and since 2 days now i cannot print anything on it (the "Empty/Pause light is always On, even if it has or not a...
the empt ause light is related to the loading of the label
turn off printer open side door and release print head feed label stock so that it stays up against the back side of the machine(left side as youface front)
Teh print head pops up like a **** shell also make sure the label stock goes under the photo eye which senses the gap between labels
There are a series of dip switches which put the printer in manual mode which is required to install labels and make sure the machine advances properly
the switch settings ar locatd on the inside for the side cover or on the very back I think manual mode is 1onat top bank and 1 on at bottom bank
Once you do this turn machine on and it shuld advance two labels and stop and green light should come on
Now you can switch the machine to compter mode ( not sure of switch setting)
If you need help yoan contact Scan Source technical support they are distributor
Good luck these are good printers and will give good service once you are familiar with them
Nov 18, 2008 | Intermec EasyCoder 3400 Thermal Label...
Intermec 3400 label printer - Connected but no printing...
your com setting must be 9600baud 7 data bits even parity
you may need to drop back to win 98
here is the syntax you need to send to the printer STX ESC E5 CAN DATA CR DATA CR ETB ETX PRINT
Oct 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
Intermec PC4 label printer
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Aug 14, 2008 | Intermec EasyCoder PC4 Label Printer
Will not print labels
you have connected two printers on a data switch.right.
1. Print test page through Printer driver.
2. If you are using command for printing on Intermec printer, you should not use generic printer.
3. Interchange the cable connected to printers
May 01, 2008 | Intermec EasyCoder PC4 Label Printer
C4 intermec printer
If you're using this printer on a print server then do the following
Turn Printer Off
Disconnect Data Cable
Press & Hold Feed button whilst switching on
Keep Holding Feed Button until test label is complete and light has gone red
Switch Printer off
Reset your Print Server
Plug Data Cable back into printer
Switch Printer on
This should start it printing (unless there are jobs inthe print queue, if there are then they will need to be deleted before printing will commence)
Mar 28, 2008 | Intermec EasyCoder PC4 Label Printer
Error Message
Clean the paper sensor located at the centre of the mechanism .
Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
Try feeding labels, only one label should advance at a time.
This is the calibration procedure.
Feb 13, 2008 | Intermec EasyCoder PC4 Label Printer
Intermec EasyCoder PF8t Thermal Barcode Label  PN PF8TA03101000 Printer Logo
528 people viewed this question
Top Intermec Office Equipment & Supplies Experts
pkwc
donjackson
Level 1 Expert
Paul Bade
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
