Question about Sony VAIO PCG-SRX51P/A PCG-SRX51P/B PCG-SRX55TC PCG-SRX55TH P... Hard Drive
I have a sony vaio pcg-srx51p/a, and i want to format it b'coz of viruses. but it doesn't boot from cd, although i have a IDE to USB cable and a internal cd rom drive. how can i format it by using a internal cd rom drive with IDE to USB cable??? or any posible way??
    President:
  • 1,768 Answers
1. you can download an run this program to clean your hard drive.
It is call Dban.
Here is the site:
http://www.dban.org/download
Then reload Windows to the clean drive and incorporate an Anti-virus after installation.
2. You can also download (Windows Security Essentials) from Microsoft if you have a legitimate copy of Windows XP,Vista, or Windows 7.
Here is the the download site:
http://www.microsoft.com/security_essentials/?mkt=en-us
Posted on Mar 18, 2011
  • 979 Answers
Hello sir, Hi, unless we find a replacement cd drive for your laptop. I don't see how this goes. you see, the laptop you have does not support boot from USB drives, (see setup on the bios first boot, hopefully theres a usb boot option, if not you may opt for a WINME install.) so its useless to use the internal CD rom drive.
  • Jerry Umali Mar 22, 2011
    this trick may help. format the drive to two partition, c: and D:, setup your windows ME on drive C:, after ME is installed, run a virtual drive software, and load windows XP on it. mount windows XP and run setup from there.
Format hard dirve
you would either format or delete all of the data from this drive if it has an operating system on it you would format it
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps you
Oct 12, 2011 | Sony VAIO PCG-505 PCG-671L PCG-700...
Hello. I have Sony Vaio PCG-5426. And I can't reinstall windows on that machine. I have out CD-ROM "II FreeCom" and i try to reinstall with that. In BIOS menu I acces for first boot drive...
you shouldn't need to have to press f9 to boot from cd rom if you have it set in the bios as the first boot device , are you sure the copy of windows on cd that you have is bootable. Try booting from the disc on another laptop or pc and see if you can start it
Another option to try is to boot from a usb drive
instructions on how to do that are here
http://www.xtremesystems.org/forums/showthread.php?t=118576
once you have booted to usb you should be able to access the cd rom
depending on what version of windows you are trying to install you will need to run different programs.
you could also install vista or windows 7 to usb drive and install it from that, it is much quicker than installing from cd/dvd you would need to be able to boot from usb to start with though
how to install vista or windows 7 from usb instructions can be found here
http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
please vote for me if you found any of this useful
Feb 20, 2011 | Sony VAIO PCG-5212 PCG-5426 PCG-551L...
Sony vaio operating system not found when computer is first turned on... what can I do to fix this and have I lost all info on my comp? I have a Sony Vaio PCG-394L notebook with Windows Vista operating...
You can try running the installation/recovery disc that came with the computer or the built-in recovery system (if it has one) to try and repair the windows installation. The problem is if the computer is saying that the operating system is not found then critical files got deleted from something like a virus or the hard disc drive has stopped working. You may have to do a format and re-install of the windows OS.
Nov 14, 2009 | Sony VAIO PCG-K23 Notebook
How to format sony vaio pcg-4 series
Boot from the "System Restore" CD-ROM.
One of the "setup" options for XP (or for Vista) is to "format" the entire disk-space, before continuing with the re-install.
Oct 09, 2009 | Sony VAIO PCG-K35 Notebook
I have a Sony PCG-FRV37 ''error loading operating system''
Look at the bios and see if the hard drive is detected
if not suspect a virus , faulty hard disk or motherboard
Aug 26, 2009 | Sony VAIO FRV37 Notebook
My computer is dead?
With the old drive in the computer you should be able to do a recovery with the disks furnished with the computer when you got it.
What you have to do with the new disk installed is go into the BIOS and set the disk to AUTO, then srrow net to Boot and set the boot priority to CD as first boot. Then hit F10 or go toe EXIT and say YES. Then with your Windows disk in the ROM drive start the computer and when the window asks whether to BOOT from disk or CD ROM, hit any key and follow the instructions. Including format the disk when it asks.
Hope this helps. Bud
Jan 10, 2009 | Sony VAIO PCG-K33 Notebook
Need ethernet controller driver for sony vaio pcg-srx51p/a
Did your sony vaio came with a cd installer? If it has one, you can use that to reinstall the ethernet controller.
May 05, 2008 | Computers & Internet
Sony Vaio not Booting
Have you tried booting with a windows cd, and then running a disk check?
Dec 18, 2007 | Sony VAIO PCG-K25 Notebook
Sony VAIO PCG-SRX51P/A PCG-SRX51P/B PCG-SRX55TC PCG-SRX55TH P... Hard Drive Logo
377 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
