Question about Belling Dishwashers
The hinges to my belling dishwasher bid602 door are not working ie the door drops to the ground when i open it. how do i fix this
  • 833 Answers
SOURCE: WHEN OPENING THE DISHWASHER DOOR, IT DROPS QUICKLY.
Yes.  Generally, there are two springs on the bottom of the door-oneon each side- inside the motor housing that have broken.  Get them from any supplier.  Remove the kick plate, locate the spring locations and install them.  There is usually a hook on the door assembly and a hole in the frame where they go.  Illustrations of this are available on line at parts suppliers if you need them.  The parts are just a few dollars.
Posted on Dec 04, 2008
reddyanantha
  • 205 Answers
SOURCE: Thor PLS 602 door hinge broken - who can fix in
please visit the manufacturers website. there you will get the answer or find out any home appliance service center nearby and take the help from them.
Posted on Nov 06, 2009
  • 574 Answers
SOURCE: I have a KitchenAid dishwasher. The door drops
either the door springs are broke,worn out or possibly the door balancers need replacing
Posted on Jan 11, 2010
  • 457 Answers
SOURCE: leaking door on Bosch dishwasher
I DONT THINK THERE IS A ASSEMBLY MANUAL BUT THE DOOR HINGES IS LOCATED UNDER THE LEFT AND RIGHT SIDE OF THE MACHINE. YOU HAVE TO CHECK THE HINGE PULLEY THEN CHECK THE LOCK.
Posted on Apr 19, 2010
Macmarkus
  • 2605 Answers
SOURCE: A spring or something has
Hello, Welcome to FixYa.
While I don`t have diagram or illustration I can give some insight because this is actually very common.
It is a fairly minor procedure to replace it/them. Slide the entire unit out from the cabinet a couple or three inches and you`ll see the plastic roller assembly and rope ( except yours is likey broke...at least one by the sounds of your description ) attached to the side.
**You`ll need to insure your connections will allow you to pull the unit out however, otherwise they - water, power, drain hose - must be disconnected to prevent any damage.**
If you have any reservation to performing this repair on your own please call in a qualified appliance technician.
The parts ( # 1059756 @ repairclinic ) come in a kit as I alluded to and will look like what I attached below...
These are available at most brick & mortar appliance part locations or on-line vendors such as "repairclinic.com" "searspartsdirect.com" or "apwagner.com" to name a few.
They range in price for around $20, or you can just purchase the rope/link seperately for about $4 part # 1159210 @ repairclinic.
I recommend replacing the entire kit and checking the spring itself, if it looks ok and not stretched or broke it is likely ok...they are seperate from the kit ( # 830967 door spring @ repairclinic as well )
Hope that helps move you forward. Thank you for visiting "fixya" today.
Please take a moment and rate the solution provided here or a testimonial if you feel warranted.
Let me know if you require further assistance and good luck.
macmarkus :)
Posted on Aug 18, 2010
How do i fix a broken spring on a dishwasher door
You will need to pull the dishwasher out about 12" to 18" to be able to get to the springs & rope links. Many dishwashers use a "rope link" to connect between the spring and the door hinge; and in others, the door springs connect directly to the door hinges. Once you pull the dishwasher out, you will easily see what broke and what you need to fixe it.
Jan 20, 2015 | Frigidaire Dishwashers
The door on my beko dishwasher now just drops open ,how can I fix this please
The spring or nylon cord attached to door hinge has probably snapped. take side off both sides for simple fix. if not then the plastic catch at top of door is probably not engageing correctly. good luck
Apr 13, 2011 | Beko 24 in. D3421F Free-standing...
I have a dishlex 300 and when i open the door it just drops down could this be something with the spring or hinges in the door
tHE DOOR SPRINGS ARE BROKEN. IF YOU HAVE DROPPED THE DOOR TOO MANY TIMES THE HINGES MIGHT BE BENT TOO. yOU WILL PROBABLY NEED HINGES AND SPRINGS....A bit of a job for a novice....like my capitals sorry about that.......
Mar 01, 2011 | Dishwashers
I want to fit a wooden door to a intagrated dishwasher stoves
If your dishwashermag-glass_10x10.gif door is not closing properly or has developed a leak, it may be time to replace the entire door assembly. Some other signs of a defective door include sagging, difficulty pulling the door back up into a closed position and a door that feels heavier as it drops open. Replacing a dishwasher door is not that hard, but includes several springs and hinges that must be aligned correctly or the door will not fit correctly in the opening.
  1. tep 1 Unplug the dishwasher and shut off the water before attempting to remove any parts. If you cannot reach the electrical outlet, you can turn off the breaker switch that controls the electricity for the kitchen. Remove the drain hose that runs from the dishwasher unit to the sink drain.
  2. Step 2 Pull the dishwasher out from the cabinet until you have clear access to the side of the unit. Ask a friend for help with this part if the unit is too heavy for you to slide out without straining your back.
  3. Step 3 Check your dishwasher's owner's manual to find out exactly how the outer door panels are removed. Some models have a two-panel door where the control panel must be removed before the lower panel will come off. Otherwise, the door panel should be one solid piece or a two-piece assembly that allows the lower section to be removed separately to access the springs and hinges.
  4. Step 4 Remove the springs at the bottom of the door. Depending on the type of dishwasher you have, there may be a tension adjustment dial or simply a series of holes at different distances from the edge of the unit. If you have a tension controller, adjust it to a loose setting to make it easier to remove the door springs. Unhook the door springs from the hinge plate. Some dishwashersmag-glass_10x10.gif may have a cable and pulley system attached to the door springs. Check your owner's manual for removal instructions if this is the case with your model.
  5. Step 5 Use pliers to gently pull back on the door hinge plate's tab until the slot opens for the hinge pin to come out. Take out the screws holding the door hinge plate onto the front of the door panel. Hold onto the door assembly while gradually opening the door. Once the door drops down, you should be able to remove it by sliding the door off the hinge pinAlways wear safety glasses when working with the springs and hinges involved with a dishwasher door assembly. These items can fly off at high speed and cause serious injury to the eye.
Nov 15, 2009 | Stoves 27 in. DW60 Built-in Dishwasher
Main wash door won't open on whirlpool model du810swkqo recently bought new home with new (?) dishwasher but it looks like the main wash door (where the soap goes) doesn't have room to open. any...
the cover is spring loaded. manually open the cover and pour some really hot water by the hinge, manually open and close few time, onec it is loose, put few drop of machine oil and work it again.
May 15, 2009 | Dishwashers
LD-14AW2 door hinge support broken
They are at the sides and back 2 slots to the levers . Vitally
May 12, 2009 | LG 24 in. LDF 7811 Built-in Dishwasher
Door spring does not work.
bryan,
I do not have a place to order parts for a Neff dishwasher, but I know these dishwashers have springs in each hinge that will wear out/break over the years.
Replacing those springs will stop the door from drooping open.
Good Luck!
Apr 05, 2009 | Neff 24 in. S5409X0 Built-in Dishwasher
Belling integrated dishwasher not working properly
are you sure it is the board at fault, not justv the door catch? (as the door wont open). If the dishwasher believes it has just finished a cycle and the door has not yet been opened it will not let you change the program.
I had this same problem so I hooked an allen key around the back of the white door catch and pulled it into the unlocked position with a pair of pliers. Has worked fine since but every now and then the catch will pop back into the locked position when the door is opened.
Nov 25, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Idw 603
Right hand hinge completely severed in two. replaced same.
Oct 07, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Door noise
Common issue with this dishwasher. Easy fix though!! KitchenAid uses a nylon string that connects the hinges to the springs located along the bottom edges of the dishwasher. I had to pull mine out to perform this service. The nylon string seems to dry out and vibrates as the door opens and closes. All that needs to be done is put some Vaseline or other appropriate lubrication all over the nylon string. Especially where it passes through the roller and stationary guide. That will take care of any squeeking or grinding when opening or closing the door. Be careful as your door will now open just like it did when it was new. Now if I can only figure out how to keep my door from popping open during wash cycles!!!
Apr 02, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Dishwashers Logo
37 people viewed this question
Top Belling Dishwashers Experts
Kamil Owsianiecki
Level 1 Expert
Oloyede Monsuru
Are you a Belling Dishwasher Expert? Answer questions, earn points and help others
