Question about Car Audio & Video
Hi, im selling my JVC CS DA 111 subwoofer , I dont know much about it, can you please tell me the tech info about it. and what its worth brand new or second hand, its in good condition. Thankyou
edo333
  • 55 Answers
SOURCE: How much is it worth?
While this isn't really a technical question I'll try my best.
This particular model is a good example of a dual 10" sub with enclosure. I have seen these marked down as clearance (not this particular model) for $100 usually at these electronics stores when they are marked down like that they are sitting at about 40% of it's retail value. Used good tend to carry a value of about 25-50% of their normal retail value depending on condition age and demand. Car audio - at least around here - is not in as much demand as say 5 years ago, so I'd roughly estimate in a private sale you could get about $75 for them. Realise of course that your market may be different.
Posted on May 02, 2008
SOURCE: tell me what jenn-air model sve47600 10 year old stove is worth
Not sure, but I would be interested in parts if you have any extra. I need a double burner for mine. I have a burner for one side and a grill and steamer for the other. I do not use the steamer but would love additional burners.
Posted on May 04, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: JVC AV-27CM3
There is no specific "remote code" as such for a TV. A universal remote control will come with a set of codes for you to try, and the control manufacturer makes up these codes. If none of the listed codes work for a particular brand, the remote normally will have a code-search feature so you can hunt for the one you need. If the trouble is that you have a universal remote and no instruction sheet, you can try to find it online, or just buy a new control. They are inexpensive.
Posted on Dec 07, 2008
brianself73
  • 4 Answers
SOURCE: Sub woofer its on for 3 sec..
your cooling fan is not engaging and coming on like its suppose to. One, the fan is probably burned out, which sucks because its low voltage and the only thing on the board that is low voltage. Two, there is a thermostat type component that tells the fan to start which HAS burned out and doesnt start the fan accordingly. If you look at the back fan and turn everything on you will see the fan either doesnt start or starts right as the relay trips turning the sound components off. If it starts at all your fans good.The thermostat component will need to be replace and I cant recommend a source. Just trying to explain the problem so you can look for the right repair. Hope it helps. I have one of these and have found this is the problem, but cant find the solution.
Posted on Dec 07, 2009
dunnbiker
  • 8546 Answers
SOURCE: digital Optical port to 8-pin din
Optical digital cables can't be magically wired to copper inputs. NO digital signal can be magically connected to an analog interface and work.
Even if you could do what you propose, how would you control volume?
Why don't you just connect the BluRay to the JVC system and let IT handle the audio to the sub and satellites?
Run an optical cable to the JVC TH-C60's Optical In port. Make sure there are no tight bends in the optical cable as that will degrade its ability to transmit a signal.
Posted on Jan 31, 2010
I am looking for an audio cable that i am missing for a logitech z-340 subwoofer. i have been looking high and low and cant find info on how to get another.... please help.
  • Consumer Sales
    6505 Kaiser Dr.
    Fremont, CA 94555 USA
    +1 800-231-7717
    Monday - Friday, 6:00am - 6:00pm PST
call them and tell them your delema and im sure they will sell you a new one :D
Jan 29, 2011 | Logitech Z-340 Computer Speakers
CAN ANYONE HELP IM TRYING TO WIRE UP A CLARION AB213R RADIO CASSETTE BUT I DONT KNOW WHICH WIRE IS WHICH. I HAVE A BLACK CONNECTION WITH FOUR WIRES. RED..WHITE..ORANGE..PURPLE..ALSO A WHITE CONNECTION WITH...
if you go on google enter clarion ab213r wiring diagram
and it should tell you what every wire is.
also enter your vehicles info and look up the wiring diagram for that also
it should be easy from there
Mar 17, 2010 | Car Audio & Video
JVC TH-C5 Solder 8 pin to sub circuit board
The best solution I could give would be to go on E-Bay and type "8 pin DIN" into the search, and just buy one. I just did. The price is higher with longer lengths, but it's worth NOT messing up the subs built-in amp by getting the pins wrong.
Sep 01, 2009 | JVC TH-C5 System
I need to know what oem subwoofer goes in the 1999 ford explorer limited. i blew mine and i want to replace it but dont know what size or brand the woofer is please help me!!
Any Ford dealer could tell you this info over the phone. Or, you could hit up a salvage yard and just buy one from a 1999 Explorer.
Jun 08, 2009 | 1999 Ford Explorer
Rb26 knock in da engine
could be detonation if the cylinders run a diagnostic on the ecu. the rb26 is sophisticated enough to give very detailed info about it. if its a big problem ill buy the engine... just tossin that out there....
Apr 04, 2009 | 1991 Nissan 240SX
What is better?
If I had to pick based on specs and pictures, I might go for the Sony's over the JVCs. But listening to each of them is really the only way to know for sure.
Keep in mind, neither Sony nor JVC are really known for their car speakers. You might be able to find something a bit better for a similar price from Infinity, Boston Acoustics, Polk, or Pioneer.
Mar 14, 2008 | Car Audio & Video
Lamp out - 2nd time in Five years
umm this is very common with progresive scan hd tvs with the lamp. i had a panasonic 52' for 6 years and mines just never turned on. i figured it ws da lamo but we also got fixed before and since these tvs are outdated i suggest u throw it out and sont sell it or fix it its not worth fixing. i suggest you buy a flat screeen lcd because thats all they sell and lcd is better than plasma. they last longer and fixing that JVC you have will cost $$$$ because of labor, bulb replacement and tax.
Jan 08, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC THP7
you need an optical lead, connect the optical lead from the back of the ps3 and connect it into the dvd players optical in.
I am looking at this one too but dont know whether it has an optical in, could you let me know on, mathewsellar@hotmail.com
thanks bud
May 04, 2007 | JVC SX-XD33 Speaker
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
