HOW DO YOU CANCEL A PROGRAM ONCE SELECTED AND THE MACHINE IS RUNNING?
    Brigadier General:
  • 6,277 Answers
Suspect you could do with a manual ;-0)
Different makes, models, different ways of cancelling.
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Mar 18, 2011
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
How can i set program time when power failure during dishwasher is running ?
There should be a "cancel and drain" or similar to drain the machine and so you can restart your choice of wash cycle when power comes back on again. I don't believe it's possible to have the machine resume from where it was in the wash program if the power fails.
Sep 26, 2015 | Samsung Dishwashers
Beko washing machine faults
press and hold start for 3 seconds or more to cancel
Feb 05, 2014 | Washing Machines
Dishwasher
It could be you opened the door before it had fully completed a program, and then turned it off. My Hotpoint machine has to be reset in these circumstances otherwise the next time it is turned on, it appears to let you select a different program but when you close the door resumes the program it was running when it was interrupted.
You don't say which model you have, so I cant give you a definitive answer, but you could try the following sequence which works on my Hotpoint:
1. Open door and switch machine on.2. Press and hold down the P button for several seconds until it gives a series of beeps (mine = 3 beeps).3. Release P button.4. Select the program you want in the usual way using the P button.5. Close door, and the machine should then run the selected program.
Hope this helps.
Sep 18, 2012 | Hotpoint Dishwashers
Hi there, I have a Euromaid WM5 and suspect it was overloaded as it stopped near the end of the cycle. We turned it off at the power as it wouldn't reset and couldn't get clothes out. It has been off...
I think, that if you want to cancel the program, you have to select correct program on selector knob. When turning the knob observe the display. When correct program is selected, it will show spin speed and temperature.
I have also managed to reset the machine by entering service mode. Turn it off, select Cotton program. While keeping Start/Cancel button pressed, turn it on. It showed E 05, then whole display started blinking. Using the same button it started spinning. After turning it off and on again, the machine was reseted.
Feb 21, 2011 | Washing Machines
Can you cancel a program once you have pressed start/reset if you have selected the wrong program?
press the stop button until you hear a beep or read out changes, select your new program, then push start
Jan 22, 2011 | Black & Decker B1561 Bread Maker
Need a manual for my kenmore elite he3t front load washer
My Kenmore Elite HE3 has been great for many years, and now I have a little problem for the first time.
I can usually press cancel to change the program. This morning, after I selected one program and press cancel, it won't cancel. Lights just blinked. So, I press Start to wash with selected program, but it won't start. It won't start nor cancel no matter what I do.
Should I unplug the unit?
Thank you so much!
Apr 03, 2009 | Kenmore Washing Machines
Vu-Me photo ball error message Photo Viewer Data Synchronize failed
Wicked! Got it working.
I had the same issue as described by the other posts. I run Windows Vista. I suspect the others are experiencing the same error message and are also running Vista.
Short Version of the Solution: You must run the Photo Viewer program as an administrator.
To do this:
  1. Close the program if it is open
  2. Right click on the program icon
  3. Select "Run as Administrator" - Yes you have to do this even if you are already logged into the PC with administrator privledges.
  4. You will be prompted to Cancel or Allow - Select "Allow"
It will now work.
Note: You may be asked for the administrator password if you are not logged into the machine as an an adminstrator already.
Hope this helps someone out there!
Nov 09, 2008 | Cameras
IPAQ turns itself on
Go to the ActiveSync options of your pocket pc and to go to Mobile Schedule and choose "Manually". I think it's set to sync automatically in a few minutes that's why it turns itself on.
Sep 11, 2005 | HP iPAQ HX2100 Pocket PC
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
