Question about Hotpoint First Edition WMA22 Front Load Washer
WMA22- Machine has started making lot of noise.
Hi Experts, This machine is 6months old. When we started using it everything was perfect, steadily in 3 months of use it has started making lots of noise especially during its NON-HIGH SPIN stages.
  • jwalsh036 Aug 27, 2008
    Mine is the same but the wate is not draining and it is not spinning please can someone help me
  • Hotpoint Master
  • 3,463 Answers
Sounds lika main drum bearing problem
As it is only 6 months old, then you should contact service agent.as it will still be under guarantee.
Posted on Dec 18, 2008
Makes a lot of noise when brakes are put on AFTER the spin cycle , is this worth fixing ?
Put more baby powder on the friction surface. When the brakes get wet, the baby powder washes off and they make incredibly strange noises.
Mar 16, 2015 | Washing Machines
When not in use Miele washing machine tapping noise
Hi.
I need more info from you.
What model is this machine? How old is it?
It is possible that the sound comes from the water dispenser valve selector. If you could give me more info about your Miele machine, it would be helpfull.
/ Geir
Miele Technical Engineer
Sep 27, 2014 | Miele Washing Machines
Why does Miele w2515 makes loud banging noise when it is about to spin?
See if you can level out the unit. Sound like the case is responding to un-even pressures.
May 23, 2014 | Washing Machines
I have a Westpoint Frontloader washing machine. Everything goes well untill it starts spinning. Then is starts shaking and there's a lot of noice. We did make sure that it is level. What else
It is so common that the washing machine can maketerrible noise in many ways and is a common fault. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that machine isvibrating when it is running then the motor /drum suspension has to beinspected. Since these fittings are located on the underside of the machine itis important that you look for the noise with a good inspection lamp. Manuallyturn the motor and drum and listen for the noise, if so the motor bearings, thedrum agitator shaft and fittings must be checked. Also the suspensions whichinclude the shock absorbers and springs, the body clamps must be checked to bein correct alignment and not changed in position. Tightening of themounting is also very important. Finallyin most cases a drop of OIL or smear of grease on the moving parts cane solvemost issues.Check this link :http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlFor replacement of bearings check for tips on thisvisual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jul 05, 2012 | LG Washing Machines
Fgq332eso
If it comes on and runs I would keep it, I would just take the machine part and check everything that I could to make sure that it was safe to use. As far as the noise you mentioned, check the blower wheel, felt and glides and bearing kit.
May 30, 2012 | Frigidaire Dryers
Hi,i have probleme in ekg bionet 2000, when i test it without electrods and start printing,,at first it print signal normal but after a few seconds he show a huge and large line with lot of noises in...
We are experts in fixing the Bionet 2000 ekg machines.
1) Is the machine plugged in to the wall when you are getting interference? If so, unplug it
2) Your patient cables may be malfunctioning, do they look damaged?
3) Are the electrodes expired?
4) make sure and prep the patient
If you are still having issues, send the machine to us at Discount Cardiology. We will look at it for free and let you know what is wrong with it. You then would have the option of fixing the machine or having it sent back to you.
Discount Cardiology
www.cardiologyforless.com
Jan 30, 2012 | Life Science Bionet Cardiocare 2000 12...
It makes a lot off noise when brewing and filling and does not put out as much as it use to its only 6months old
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jun 28, 2011 | Keurig Elite B40 Coffee Maker
Found lots of fluff from a previous wash. Next wash the machine failed to empty. Did persist & a trickle of water arrived, machine is now almost empty of water, least enough open the door. Possible...
To clean pump you will need to unplug machine, at rear using screwdriver remove the panel at bottom of machine. depending on fitting of clip holding pipe onto your pump, use suitable tool to remove the clip. You can now remove the pipe from the pump. check inside the pump also.If you need to remove the tub end of this pipe there is what is like a ping pong ball within the pipe. Make sure you refit this as it acts as a non return for the water.
Mar 15, 2010 | Hotpoint First Edition WMA22 Front Load...
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Hotpoint First Edition WMA22 Front Load Washer Logo
196 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
