I login to may paltalk messenger ,and i have a problem messe say that's i have to check my internet connection or modifr you firewall settings to allow a paltalk connection and try again. but my connection is good. i have no problem with my connection, i thing that a modify firewall setting is block ,but i cant fined it to fix.ineed help please.what can i do to fix the problem.how to settings a firewall to allow to usesing a paltalk connection
  • Computers & ... Master
  • 1,830 Answers
Go to control panel and check your security settings.
Posted on Jun 26, 2017
3 Suggested Answers
SOURCE: paltalk program
i want to unblock yahoo im on cisco asa 5510
Posted on Jul 16, 2009
SOURCE: Paltalk tells me I have a connection failure, and to check my internet connection or modify firewall protection to allow a connection to paltalk
then by all means take that good advice
solution based on available data
Posted on Jun 20, 2012
I cant open my ym account....
I suggest you to check whether your email address and password is correct or not, by logging in at the www.yahoomail.com website, If you are able to login then your account exists and the email address and password is correct.
If it shows wrong password, try forgot password.
If you are able to login to your account in website, only you cannot login in yahoo messenger, There might be some problem in yahoo messenger, I suggest you to download the recent version of yahoo messenger and try logging in, if problem persists check your internet connectivity, Sometimes we couldn't login if there is a problem in internet connection.
There may also be problem with windows firewall settings.
And also check whether the yahoo messenger is added as exception in the windows firewall or not, If not add the yahoo messenger to exception list.
May 24, 2010 | Yahoo Messenger
Messenger error 81003005
here are some causes: Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren?t grayed out. Click OK and login again using the new settings. If this option doesn?t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code?81003005? when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful!
Thanks.
Jun 16, 2009 | Yahoo Messenger
Login error 81003004fo yahoo
You might have some options to fix it: firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Or other way, open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.thirdly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003004” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful and it works to solve your problems.. Please kindly support me.. Thank You!
Jun 10, 2009 | Yahoo Messenger
When I try to sign into Yahoo Messenger 9.0 I get this error message "Messenger encountered a connection problem. Please check the network connection and then click try again. (81003004)" I've changed my...
Plese solve messenger connection problem/81003004
Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful!
Jun 09, 2009 | Yahoo Messenger
Login error 81003004 from Yahoo Messenger
Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version.Hope it was helpful!
Jun 05, 2009 | Yahoo Messenger
as far as wat i did to my YM.
i simply checked the connection preferences and turned
"Connect via a proxy server."
then select
"HTTP proxy"
after that take a look at your internet connection dropdown list..
some mistakes are seen here.. instead of having the "broadband" connection selected the "dial-up" connection was chosen by YM itself..
hope that helps ya ^^
Dec 16, 2008 | Yahoo Messenger
Paltalk
check if you have firewall software and disable it temporarily then try again
Dec 25, 2007 | Computers & Internet
Computers & Internet Logo
194 people viewed this question
David Payne
David Payne
