Question about ASUS G53JW-3DE 3D Gaming 15.6" Notebook PC Video Card
I'm using Asus G53J . the sound control is not working when i press Fn+F11/F12 . but Fn+other key is alright .. no use when i try to press Fn with arrow key too. where/how can i download or install the drivers supplied
  • 43 Answers
Hi!
Go to the official ASUS support site, enter G53 to the search bar on the left, and select you Operating System. Select utilities from the list and download the ASUS Configuration utility or anything else you need.
Greetings
Posted on Mar 18, 2011
  • 43 Answers
You don't have it on mute Fn+F10, right?
You also need to make certain that you have the correct playback device set as default (right click on the speaker icon >playback devices and click on "Speakers" and set it as "Default Device". When you use headphones sometimes it messes up the settings.
2 Suggested Answers
gaganddun
  • 114 Answers
SOURCE: I'm using Asus G53J .
dear evelyn
for this you have to install the drivers supplied with your lappi. try installing the setup mentioned as shortcut menus or keyboard drivers.
Thanks
Gagan Gupta
Is that Helpful?
Help with d2d recovery for gateway Lt 20 notebook
Try tapping the Del key. Also try F11, if neither of those work, then try these combos below:
Fn+F2
Fn+F8
Fn+F10
Fn+F11
Fn+F12
Shift+F2
Shift+F8
Shift+F10
Shift+F11
Shift+F12
Remember to hit these key combos before Vista loads, only when you sure the keys were pressed, cross it off the list on move on. When you do determine the correct key combo, please post back here, it will help others with the same question.
Oct 30, 2014 | Computers & Internet
Fn+num lk not working
There is no standard meaning to any Fn +Fx key combinations. It depends on the manufacturer and the laptop model.
Usually the Fn key works in combination with the Function (Fn) keys F1-F12, and maybe ESC.
In my Toshiba, there is an overlaid numeric pad that can be activated by pressing Fn +F11. Once the sequence is pressed the F11 key led remains lit, and the overlay active. Pressing the F11 key restores the normal keyboard. Fn+Num Lock does not do anything.
Please check you laptop's manual to familiarize yourself with the uses of the Fn key on YOUR computer.
Dec 19, 2013 | ASUS Eee PC 1000H Laptop
How to turn off the fn key
1 - Function Keys f1 through f122 - Configurable Function key fnDisable fn in the BIOSTo disable, or enable, the function key (fn) in the BIOS, do the following steps.
  1. Press the power button to turn on the computer.
  2. Press the f10 key to open the BIOS setup window.
  3. Use the right-arrow or left-arrow keys to navigate to the System Configuration option.c02035200.jpg
  4. Use the up-arrow or down-arrow keys to navigate to the Action Keys Mode option, and then press the enterkey to display the Enable / Disable menu.
  5. Select the desired mode:
    • Disabled : Requires pressing fn key + f1 through f12 to use the action as indicated on the action key.For example, if Disabled , pressing fn + f11 will mute the sound as indicated on the key on this model PC. Alternatively, pressing f11 only will minimize and maximize a web browser if open.The action keys may vary depending on the model of notebook.
    • Enabled : Requires pressing only f1 through f12 to use the action as indicated on the action keys.For example, if Enabled , pressing f11 only will mute the sound as indicated on the key on this model PC. Alternatively, pressing fn + f11 will minimize and maximize a web browser if open.The action keys may vary depending on the model of notebook.
  6. Press f10 key to save the selection and restart the computer.
The function key (fn) option can be reset at any time.
May 22, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
My F2 fn key is not working neither is f10,f11,f12 and the seperate blutooth key
The laptop keyboard needs to be replaced, go to www.ebay.com Type: make and model of laptop and refine search to keyboard.
Apr 26, 2012 | ASUS Eee PC 1015PE
How do I use the F9, F10, F11 and F12 keys?
Some Gateway (desktop) computers do not have the dedicated F9, F10, F11 and F12 keys, but for a Gateway laptop, those four keys have dual functions for media control (which is the default use) or as Function keys. However, to use F-9 through F12 as Function keys, you must first press the Fn Key and then press the desired F-key. The Fn key is the second key to the right of the spacebar. To launch the Gateway Recovery process during start-up, you must press Alt+Fn+F10.
Aug 19, 2011 | Gateway Computers & Internet
I have a asus laptop and the sound button is f10 and the sound is bleu but i dont know how to turn it op or ndown ???
Many notebooks require a driver / support software to be installed in order to use hotkeys on the keyboard to control hardware - like a sound card. Go to the ASUS "Drivers & Downloads" site and download and install the latest drivers for the notebook. Once installed, you may find that pressing the Fn key AND the F10 (opr F11 or F12) keys at the same time like this: <Fn> + <F10> or <Fn> + <F11> or <Fn> + <F12> key combinations will control your speaker and volume up and down.
Aug 14, 2011 | Computers & Internet
dear evelyn
Thanks
Gagan Gupta
Is that Helpful?
Mar 18, 2011 | ASUS G53JW-3DE 3D Gaming 15.6" Notebook PC...
The sound control is not working when i press Fn+F11/F12 . but Fn+other key is alright ..
Try pressing Fn with the arrow keys , if not go into Control pannel and change the Volume and sound control from there
Hoped i helped :)
Mar 18, 2011 | Computers & Internet
Volume control on Asus laptop. I need to turn up the volume!
Try the Fn key and F11 or F12 - that should turn up/down the volume on your Acer, depending on the model
Hope this helps - good luck!
Sep 17, 2009 | Computers & Internet
Volume = either completely off or on quietly
HI,
You might have to install the fn keys drivers once again.
Aug 11, 2009 | ASUS Computers & Internet
ASUS G53JW-3DE 3D Gaming 15.6" Notebook PC Video Card Logo
587 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
