Question about Fujitsu Desktop MPC3043AT 4.32 GB ATA-33 Hard Drive
I have hard disk model MPC3043AT with capacity of 4 GB. The card (located exactly opposite in direction to 40 pin interface connection, with one end connected to PCB and other end is going down in disk section) is broken. Hard disk is not detected in Bios. Is that card/connector chip repairable and available in market? Thanks and regards
  • 55 Answers
You can't repair it, but you can change it with an identical one. Find a similar hdd and look at PCB it's a serial, if it's identical you can swap them after you resolder ROM chip from the damaged PCB to the new one. But this method it's use for recovery data and could be expensive.
Posted on Mar 18, 2011
Hard drive capacity
It's 10.2 GB
Maxtor 10.2 GB UDMA/66 7200 RPM IDE Hard Drive
General Features:
10.2 GB formatted capacity
UDMA/66
7200 RPM spindle speed
2 MB buffer
9.0 ms average access time
4.17 ms average latency
E-IDE/ATAPI interface
3.5-inch form factor
Notes:
Drive only
Maxtor model #: 51024U2
Additional Information:
Product Requirements
IDE controller
IDE cable
Available 3.5-inch drive bay
Available 4-pin power connector
Jun 28, 2012 | Maxtor Computers & Internet
Code da620000 what is capacity
It's 10.2 GB
General Features:
UDMA/66
2 MB buffer
Notes:
Drive only
Product Requirements...
IDE controller
IDE cable
I have a USB key of 8 gig. Today i fill the capacity at 7.8 gig and ...wow.... the capacity is at 7.8 gig but nothing appear on it, even after check in 3 different PC !!! What the heck ?
Has to do with the definition of a GB. Here is a good explaination. from http://www.brettbits.com/Text/MissingHardDriveSpace/
The Answer
It turns out that the answer has to do with your electronic devices and their operating systems using a different definition of "gigabyte" ("GB") than that of the manufacturer's of storage devices such as memory cards and hard drives. When manufacturers of such devices say "GB", they mean what is called a "decimal gigabyte", which equals exactly 1,000,000,000 (one billion) bytes (a byte is a fairly basic unit of storage in computers). When your device's operating system describes the capacity of the storage medium, they typically use what is called a "binary gigabyte", which equals exactly 1,073,741,824 bytes. Because of this discrepancy, a device has less binary gigabytes than decimal gigabytes.
It turns out that a decimal gigabyte is approximately 93% the size of a binary gigabyte, so if your hard drive is 40 decimal gigabytes, your operating system will report that it is approximately:
40 decimal gigabytes * 93% = 40 * 0.93 = 37.2 binary gigabytes
Which is exactly the hard disk capacity that is reported by operating systems such as Windows XP. Likewise, a 1 decimal terabyte hard drive is 1000 decimal gigabytes. Windows will report that hard disk's capacity as approximately:
1000 decimal gigabytes * 93% = 1000 * 0.93 = 930 binary gigabytes (this is very close to what Windows reports; however, the multiplication factor isn't exactly 0.93, as we'll see below)
So simply put, when you purchase a digital storage medium, you can expect your operating system to identify it as being about 93% the size that you expect it to be. You're not being ripped off; it's just that the word "gigabyte" is used to mean two different things.
Aug 17, 2011 | Computers & Internet
Installing Hitachi Deskstar 40 GB drive as slave. Where do the connectors go. It says model IC35L060AVV207-0. Installing drive in Dell 4600
Look at the "connectors" end of the disk-drive.
There will be a set of thin pins for the "data" cable,
and thicker pins for the "power" connector,
and a smaller grid of small pins.
It's these pins that will be labelled/engraved on the casing:
MA(ster), SL(ave), C(able)S(elect).
Move the jumper to the "slave" setting.
Connect to the power connector.
Connect to a "data" cable.
When you add power to your computer, it should recognize the drive.
Dec 26, 2010 | Hitachi (HTS424040M9AT00) 40 GB Hard Drive
I want to upgrade my Fujitsu MHV2040AH 40 GB Hard Drive what is the biggest/fastes one i can replace with? i though i found another one but it doesnt have the right connectors. the fujitsu/toshiba site...
Your Fujitsu MHV2040AH is an IDE 2.5" 5400 rpm 40 GB hard drive.
Most Notebooks nowadays will use 2.5" SATA hard drive which is not compatible with IDE.
New IDE are getting harder to find and are therefore in general more expensive to buy than the equivalent SATA
You should be able to update the drive with most 2.5" HDD with either 5400rpm or 7200rpm (faster) with an IDE interface. Common 2.5 IDE capacity would be 120Gb and 250Gb (320GB and 500GB are also available but could be a bit expensive). The important factors are physical size to fit in your notebook/casing and IDE interface. The BIOS support for larger drive can also be a factor but as a rule, worst case situation, a larger capacity drive can always be used at a lower capacity
Hope it helps.
Dec 15, 2010 | Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard...
Can the MK4026GAX @5400 rrm be used to replace my deceased Toshiba MK3021GAS @4200 which fits into my dell inspiron 8500 using a adaptor directly into the recepticle (slide in from side & screw on...
Yes, all IDE 2.5-inch disk-drives use the same pin-out. SATA-interface disk-drives have quite-different interfaces than IDE drives, but all SATA devices share a common interface.
Nov 06, 2010 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
Can you let me know what is the maximum installable HDD capacity 0f Lenovo laptop 3000 C100.Can i upgrade present capcity of 40GB to 320GB ?
If you have windows xp with service pack 3, there is no limit. There is no limit if you run Vistaor Windows 7. If you don't have service pack 3, you are limited to 137 gb.
Dec 20, 2009 | Lenovo 3000 C100 Notebook
I need to know what kind of sound card i have for my hp note book Model number: KR346AV
Processor Processor Class: AMD Turion 64 X2 Mobile Processor Speed: 2 GHz Cache Size: 1 MB Bus Speed: 800 MHz Memory Installed Memory: 2 GB Maximum Memory: 4 GB Memory Technology: DDR2 System Input Devices: Keyboard|Touchpad Interface Connection: Audio - Line In (1/8" Mini)|Audio - Line Out (1/8" Mini)|Audio - S/PDIF (1/8" Mini)|Bluetooth|Ethernet - RJ45 Twisted-Pair (XBaseT)|FireWire 400/IEEE 1394 - 4 pin|Infrared - iRDA Wireless (iRDA-SIR)|Port Replicator/Docking Station|Serial - RJ11 Modular (Phone/Telco)|USB - Universal Serial Bus 2.0|Video - S-Video|Video - 15 pin High-Density D-shell (VGA) Slots: Express Card 34|Express Card 54|Memory Stick PRO|MultiMedia Card (MMC)|SD Card|Sony Memory Stick|xD-Picture Card Display Display Size: 15.4 in Aspect Ratio: 16:10 Display Type: LCD Display w/ Glossy Screen Max Resolution: 1280 x 800 Video Chipset: NVIDIA GeForce 7150M Storage Included Drives: DVD+-RW DL Hard Drive Capacity: 250 GB Number of Storage Drives Included: 1 Features Included Network Card: Ethernet (10/100 Mbps)|Wireless Ethernet - 11 Mbps IEEE802.11b|Wireless Ethernet - 54 Mbps IEEE802.11g Included Devices: Built-In Microphone|Built-In Webcam|Headphones|Modem|Remote Control Software Operating System: Microsoft Windows Vista Home Premium Dimensions Height: 1.56 in Width: 14.05 in Depth: 10.12 in Weight: 6.06 lbs Warranty Warranty Information: 1 Year Limited Warranty More Info URL: URL General normalized-Cache Size: 1 normalized-Display Size: 15.4 normalized-Installed Memory: 2000
Sep 26, 2009 | HP (400745-001) Sound Card
I need to upgrade my internal hard drive, what exactly do I need to get the most storage for my Toshiba Notebook Satellite A135-S4666? I would like to have 500gb or more of storage.
There are two kinds of hard drives and you must learn which one your computer has. To do this, Turn the computer off, diconnect the power chord and remove the battery. Locate and remove your present hard drive.
If the connection end of the drive has two plastic covered connection locations, you have a SATA drive.
If the connection end has more than 40 pins, you have an IDE drive. There is no way you can confuse the two types.
Go to your favourite computer parts source (ebay, web store or real store) and buy the largest drive that they have and that you can afford. Install the drive and install your favourite Operating System.
The largest IDE drive is 320 GB and the largest SATA drives I've seen are 500 GB. Best of good computing with your new drive.
Jun 23, 2009 | Toshiba Satellite A135-S4666 Notebook
Hard drive replacement
SATA drives are the latest hard drives available nowadays. You could try going online and checking other sites that could still have an IDE hard available for sale.
Jan 02, 2008 | Samsung SpinPoint SP8004H 80 GB Hard Drive
Fujitsu Desktop MPC3043AT 4.32 GB ATA-33 Hard Drive Logo
89 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
