Question about RIM BlackBerry Bold 9700 Smartphone
I couldn't start the camera even i close the applications. i tried to hard restart my bb by opening the battery so many times, wiping handheld and upgrading OS but still doesn't work. what should i do? please help. thank you.
SOURCE: could not start the camera. Close other
Very gently take the back off of the Blackberry, slightly push in on the camera itself, reboot and the camera should work.
I found out the hard way selling my phone on eBay only to have it returned because the camera didn't work. It's a hardware issue and not a software issue.
If it's still under warranty, try and get a new phone, otherwise --problem solved.
Posted on Jun 30, 2009
  • 88 Answers
SOURCE: My BB doesn t reconnect automaticly I have to
Does this help?
http://www.blackberry.com/newsletters/connection/business/i508/tips-tricks.shtml
Posted on Aug 04, 2009
SOURCE: my blackberry storm camera quit working. it says
if you hold down the blackberry button....(dots).....a menu will pop up ....those are all the apps the you still have open...go into all of them and make sure you manually close them out....choosing the close selection on the menu....and ur camera should come right back on...the same happened to me......
Posted on Dec 27, 2009
kachi_1
  • 677 Answers
SOURCE: whenever i open up my
Hi, when a camera says could not open the camera close other application and try again ,means that either to much application where opened at a tie or the camera is corrupted.
First, scan through phone and see if unnecessary applications where open,If not, that means the camera is faulty and will eeed to be replayed.
Posted on Aug 07, 2010
caroldon
  • 17129 Answers
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Posted on Feb 12, 2011
I am not able to receive calls the next day after charging my Blackberry 9530 storm, then i have to remove the battery and put it back again to receive calls. Any permanent solution for it?
Yes, there is a solution and I hope this also works for you. My 9550 would freeze and I couldn't answer a call, or it will just freeze on it's own at least once or twice a day. I also had to remove the battery then replace it and it will be fine again. After emailing the store where I bought the phone. One of the solutions was to wipe the memory as stated here. (To try to "wipe handheld":
1. In the device Options, click Security.
If you are using BlackBerry Device Software 4.1, click Security Options > General Security.
2. Click the trackwheel and select Wipe Handheld.
3. Click Continue.
4. Type blackberry and All the data on the BlackBerry device is erased.)
Then restart the phone and it should work.
Better yet. If you have the BlackBerry Desktop Software Application on your computer. If you don't go here https://swdownloads.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=A2C0D61EB187AB3AFD247A852FAD3647 It's a 114mb file. Connect your BB with your data usb cable. Then back up the phone and do a software update (Which is what I did). The software will back up your data, then wipe your BB clean. Then it reinstalls the software. The process takes between 30 minutes to one hour to complete. You should be ok after the update. My BB 9550 works fine now since the update four days ago. No more issues.
Jul 09, 2011 | RIM BlackBerry Storm 9530 Smartphone
It give me error523
Hi,to do the following, I hope you have a quick finger like the guy in Fantastic Four since you will have to use your finger speed to beat the soon-to-appear white screen and JVM error.
Ready? Go!
  1. First, turn off your phone as I suggested before. To open the back cover and take out the battery. Then wait 2 minutes (well, even longer to have bathroom break), and put the battery back. The Blackberry device will come back by itself.
  2. As soon as you see the desktop appear, you should quickly scroll down to " Turn wireless off" or " Turn radio off". This has to be completed quickly before the phone connects to the network that you are using. Hint: you can use ALT+scroll to jump items by row instead of one item by one.
  3. After you turn the wireless radio off, then go into your your BB browser (the globe on the screen for most). And DELETE BROWSER CHANNELS. To do so, just expand the section and then delete all the channels. Mine was only the Weather Push Channel on it.
  4. Now you can turn the radio back on, you should have a full functional blackberry device back. Is it a great thing not to wipe your OS instead?
Well, I know, sometime weird thing happens. If this does not work you will still need to consider to back up your blackberry and then reload the software from RIM website using your usb cable.
Here are the directions for these un-lucky ones:
  • Please go to the blackberry handheld software download page at http://www.uscc.com/uscellular/SilverStream/Pages/x_page.html?p=bb_software
  • Install both desktop manager, and the newly download handheld software
  • Restart your PC, with the battery out the back of the handheld and cable unplugged
  • Start desktop manager
  • Run the application loader software
  • During the connection screen, please plug in your device (keeping the battery out)
  • Choose the USB *XXXXXXX* or USB "Unknown"
  • Do no choose any additional applications for install
  • Click Next, then Finish
  • Handheld will be restarting, and installing the applications.
Hope that helped.
Oct 10, 2010 | RIM BlackBerry Curve 8520 Smartphone
Camera phone won't load. "close all apps and then restart." Tired soft reset, hard reset and update.
Make backup on your PC.
Wipe the BB, options - Security -General Settings - drop down menu - WIPE
Restore the backup from your PC.
This will solve camera corruption.
Nov 30, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
My camera application on my blackberry is not working.
This is the initial sign of the camera coming loose from the socket on the main board.
If it still in warranty then send it out for repair.
If it's out of the warranty then you can put a foam or plastic spacer to under the battery cover.
Just like the battery foam pad under the battery cord to give it firm support.
Place few tab of supporting material under the battery cover. Make sure they does not cover the lense or the flash.
Next time the camera give you the error message again or ghost like image.
Take the battery out and press the camera and flash area firmly until you hear a soft plastic snap sound.
YOU MAKE HAVE TO DO THIS MANY TIMES
Once the camera contacts snap back in place then your are back in business.
Aug 07, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry curve 8320 camera
Take the battery cover off. Take your finger and press on the lens area (below the flash) you should hear a "snap". Don;t over do it though.
Jul 07, 2009 | AT&T Blackberry Curve 8300 Smartphone
BB 7250 won't switch on
Something you can try. Open up Desktop Manager (with the BlackBerry unconnected) open up the Application Loader. Before hitting next, pull the battery out of the 7750 for 5 to 10 seconds, then quickly put the battery back in, connect the BlackBerry, and hit next on the application loader. This should kickstart Application Loader to find the BlackBerry and allow you to reload the handheld software. So, make sure you have the handheld software installed on your comptuer (which you already do)
Jun 21, 2009 | RIM BlackBerry 7250
I need to remove yahoo mail from my blackberry
The smart thing to do before you return the phone is to do a wipe handheld. You can find the wipe handheld option if you go to your menu -> options -> security options -> general settings. Here you can press the blackberry key and choos wipe handheld. When you do a wipe handheld all data on the phone is erased and the phone is ready for the new user. Make sure that you choose delete 3rd party applications also.
best regards
Mar 16, 2009 | RIM BlackBerry 8700c Cellular Phone
Blackberry camera
turn off ur bb mobile by disconnection the battery from mobile phone and put the battery after 1 min and start the hand set
Nov 16, 2008 | AT&T Blackberry Curve 8300 Smartphone
Blackberry Curve 8300 Camera Problems
After reading many posts, I removed the back and and pulled out the battery, then removed the memory card and blew air all over it, put it back together in reverse order, and works like new.
Oct 07, 2008 | AT&T Blackberry Curve 8300 Smartphone
RIM BlackBerry Bold 9700 Smartphone Logo
74 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
