Question about Bose Lifestyle SA-2 2-Channel Amplifier
I have installed a Bose V25 Entertainment System, and linked it to an SA-2 amplifier and a pair of 151 se pseakers. The Entertainment System works fine. The SA-2 amplifier has power, but the LED on the back blinks once every 3 seconds indicating it is not switched on. There is no sound from the 151 speakers, although the Entertainment System is producing sound. The installation guide for the SA-2 amplifier does not contain instruction specifically for a V25 Entertainment System, so I have simply plugged a Bose Link into the Entertainment System (out) and the SA-2 amplifier (in). I do not have a secondary remote. I can't find any additional section to set up via the 'Setup' mode for the V25 Entertainment System. Any idea how to switch the SA-2 amplifier on?
4 Suggested Answers
  • 263 Answers
SOURCE: bose terminal block connector
http://www.4electronicwarehouse.com/products/bose/ta2-adapter.html
Posted on Aug 02, 2009
  • 3 Answers
SOURCE: we have just installed a Bose lifestyle system,
Make sure you unplug your sa 2 and sa3 amplifiers after setting the codes. Wait at least 60 seconds, then plug back in. I would also unplug the in and out boselink cables as well. Once youve waited for a minute, then plug everything back in. Should work. If not, call Bose technical support. They are really great. I have 15 SA 3 amplifiers throughout my home. They are great.
Posted on Apr 18, 2010
  • 6771 Answers
SOURCE: Will a Bose SA-3 Amplifier work well with Bose 151 SE Speakers?
yes! the specs look good, in fact the amplifier output matches the speakers, plus the ohms ratio is fine.
Posted on Jul 07, 2012
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier
https://worldwide.bose.com/.../en/owg_en_sa2_sa3.PDF Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
worldwide.bose.com/axa/assets/pdf/owner.../og_sa1.pdf
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
[PDF]BOSE® Link AL8
Dec 29, 2015 | Bose Lifestyle SA-2 2-Channel Amplifier
Why pairing remote with console not working?
Try going to the BOSE website where you can look at manuals or use their videos or Contact Us tab.
Lifestyle 235 Home Entertainment System Bose Product Support
Sep 03, 2015 | Bose Lifestyle 235 Home Entertainment...
My Bose lifestyle amplifier (SA-2, SA-3) suddenly stopped working while playing stored music. It has worked flawlessly for over 3 years until now. I replaced the batteries in the remote and checked all...
Check your settings on the main system setup mode and make sure the amp is enabled. If you still have an issue, post a comment and I can help you further.
May 30, 2011 | Audio Players & Recorders
Which amplifier that match 2 of JBL CM52 speaker and 2 of Bose 151
If you want to run both the speakers at a time you will have to buy a professional amplifier like CROWN XLS202.
Because together the total impedance will drop below 3 Ohms. An average domestic amplifier is designed to run speakers between 4 to 8 Ohms.
If you are running only one pair at a time you can buy any of the following Amplifiers.
Marantz - PM 7003
NAD C356
Mar 31, 2011 | JBL CM52 Speaker
We have just installed a Bose lifestyle system, with SA 2 and SA 3 amplifyer, with a second set of speakers in another room. we cannot get sound to the second room. the second remote is not responding....
Mar 21, 2010 | Bose Lifestyle SA-2 2-Channel Amplifier
Expanding the BOSE 3.2.1 System to other rooms
I don't see any standard RCA Line Level audio outputs on it, do you?
Apr 19, 2009 | Bose 3 2 1 GS Series II DVD Home...
Bass/Treble balance on Bose Lifestyle 5
You need to go into your menu and set the "MOVIE EQ" to your liking. That is where your bass/treble balance is on a Lifestyle system.
Mar 01, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
Bose speaker 151
Hi
I checked in the specs of the manual here. page 6. They quote it as being suitable for 4-8 ohm AMPLIFIERS. but do not mention the actual impedance. I would expect from that that the speakers must be close to 8 ohms, as you they would not advise you to connect a 4 ohm speaker to an 8 ohm output stage, as likely damage could result. If you had a multi meter, you could do a DC resistance check of the speaker, this is generally very close to the impedance. happy to talk to you more about it.
regards
robotek
Nov 04, 2008 | Bose Lifestyle SA-2 2-Channel Amplifier
Bose Lifestyle SA-2 2-Channel Amplifier Logo
252 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
