Question about Alpine CVA-1005 Car Video Player
When i tried connecting the unit to a car battery just to make sure it worked there was no power and wouldnt turn on. what could the problem be
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Alpine Master
  • 2,226 Answers
Did you connect both the red and yellow wires to positive?
Posted on Mar 18, 2011
1997 2500 chevy sububan 3/4 ton 454 engine . Ran fine battery died recharged . They replaced battery an start cause it wouldnt turn over . Now just dont start but turns over ..help please ..
Hi if the car has a ECU and a factory fitted alarm try disconnecting battery for at least 30 minnutes to reboot system also make sure all battery terminals and connecting wires are properly secured'. be sure that no fuses are blown.
Mar 25, 2015 | 1997 Chevrolet Suburban
2000 pontiac bonneville sle wont turn over
If the engine will not crank, you would need to check for power from the battery to the starter. Is the security light on ?
Will it crank in neutral ?
Feb 22, 2014 | 2004 Pontiac Grand Prix
Brand new battery and ignition still wont turn over
Measure voltage at battery and voltage at starter .Then try to jump starter by connecting the small terminal and the battery cable at starter.
or Security system is on. and small wire to ignition are cut and there is no starter and no injection pulse.
hope it help
Feb 22, 2014 | 2000 Pontiac Bonneville
Car wont start
check the battery cable for a good connection then make sure its in park move the gear shifter around and place back in park. check the head lights for full power. last thing is jump it with cables to make sure the battery is strong.
Jan 05, 2013 | 1998 Pontiac Sunfire
99 dyna wide glide. battery good but no power to anything
Make sure the terminal posts are clean on the battery, and the terminal connections should be so tight that you cant physically move with your hand, but tight is tight, and too tight is broke. So don't strip the terminal bolts.
Nov 20, 2011 | Motorcycles
I have a 94 cadillac deville. Recently my car wouldnt start. I figured it was the battery. I replaced this and the car did start. However the car will not turn over again. I then figured my alternator was...
The "clicking" noise may be the solenoid on top of the starter mot engaging. Are all connections to battery and solenoid tight? Hope this helps. Let me know. Thanks.
Dec 27, 2010 | 1994 Cadillac DeVille
My toshiba turned off about a month ago, it wouldnt work at all. the keys first got all sticky so i tried to clean the keys off. it wont turn on. it would show that it was charging, but then it wouldnt...
Please clear whether your computer is getting ON or not.
You can try to bypass your battery (Remove the battery and connect the Power cable). Make sure now your machine should be switch ON. If it is then Just wait for 5mins, Swithc OFF your laptop and connect the battery again. Now it should be working.
Sep 27, 2010 | Toshiba Satellite A60 Notebook
Starter
Oh now gotcha .. The Battery connections are either dirty or you have a bad ground . 1st take the battery cables off and clean them good inside and the battery posts then make sure battery is charged up and give it another try .. thanks again Jerry holler if you have more..
Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
Memory wont hold on AVIC-N2
Buy a cheap 12 volt tester pen from Radio Shack, and make sure your constant(yellow) always has power no matter  what position your ignition is and your accessory(red) only has power when the ignition is turned on. Some time those after market adapters are wrong(they are after market for a reason).
Aug 27, 2007 | Pioneer AVIC-N2 Car DVD Player
Alpine CVA-1005 Car Video Player Logo
50 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
