Question about Bosch Axxis WFL 2060 Front Load Washer
Showing F18 and smelling like the motor is over heated. Doesn't matter which cycle I put it on. It wont drain or spin.
    Brigadier General:
  • 6,277 Answers
F18 is probably 'pump/ drain out'. I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 18, 2011
Whirlpool Cabrio WTW6600SB2 won't spin or agitate. We bought it used and they swore it worked. It goes from 45min and drops down to 3mins. It never completes it's load. And after it beeps with a OL on
Hi.
Most spin troubles are caused by drain or pressure switch problems, but it does not look like that is your case. Check for blockage in drain system and clean the hose connected to pressure switch. As said I do not think that this is the problem but the drain system must be checked as part of troubleshooting.
OL code in fact is not related to drain problems, but to motor and mechanical problem. OL is returned when the washer is overloaded and the motor cannot turn the basket properly.
The first step to diagnose the problem is removing the basket and looking for problems under the basket (e.g. broken part or clothes stuck under the tub). Here a document showing how to.
If parts under the basket are OK the next step will consist in testing the motor. The motor can be tested reading impedance at its phase terminal and across the stator winding. The Cabrio's motor should read about 30/32 Ohms across its phase contacts.
If the motor and the rest are OK the problem is usually the RPS sensor that detects the rotational speed of the motor.
Regards.
Ginko
Dec 15, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code F18
F18 error code means that the filter is blocked.
Look around for a propeller shaped part, it should be able to spin freely. If not, remove the debris so that it is unblocked.
Hope this helps (remember to rate and comment this answer).
May 14, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch Clasixx 6 wash machine wont spin or drain and filter is clear. Keeps showing F18 on clock. whats wrong?
'F18' for Bosch normally indicates a draining problem. As you say the filter is clear, have you been able to check that something is not jamming the drain pump/motor?
So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If both the filter and pump are definitely clear, it COULD be the control board OR the main motor. Motors will show weaknesses when commanded to spin.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 12, 2011 | Bosch Washing Machines
MY BOSCH WAE244SOZA WAS SHOWING F18 FAULT YESTERDAY. I SWITCHED OFF AND RAN SUOER QUICK CYCLE. NOW MACHINE IS FULL OF WATER AND DID NOT STOP AFTER 15 MINUTES
Bosch 'F18' indicates a problem with draining. I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
John C
May 12, 2011 | Washing Machines
Bosch Exxcel did not spin an F18 display
Sorry but I do not have the decode for F18 for your particular machine but for similar models F18 indicates a 'pump/drain out time'. I would therefore suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
John C
Mar 23, 2011 | Bosch Exxcel WFO 2465 Front Load Washer
Set machine to wash; Came home to discover machine flashing F18, with water still inside drum, smelling 'burning', and nothing seems to rectify.
Bosch F18 can indicate a drain filter/drain pump problem so I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside. The smell COULD be coming from a jammed drain motor.
John C
Mar 18, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
MOTOR SMELLS OF BURNT MOTOR WINDINGS. iS IT NORMAL
No, the pump works while spinning. The burnt smell is probably the belt, especially if your wife saw smoke. Did she put a big load in it at the time?
The belt will slip until the tub catches up with the motor. If there is a heavy load, it can burn the belt up. I would replace it. Make sure the idler pulley on the motor moves freely also.
http://www.partselect.com/MultiModels.aspx?ModelNum=ALW480DA&searchTerm=&RefineSearch=0
Jan 22, 2010 | Amana ALW480DA Top Load Washer
Wont drain burning smell
if it smells electrical then it is the motor and just because you replaced it months a go that dont meen anything i have seen them come off the shelf and be bad not saying ddty that this is your issue but it sounds like it a bad solinoid chances are very slim I would look towards the motor to find out when machine quits lean machine back on the wall so it dont fall on you and put your hand on the motor if it is hot then it is over heating and needs to be changedplease let me know what you guys find and if i can help you in any way
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch Axxis WFL 2060 Front Load Washer Logo
103 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
