Question about Tally 6312 Matrix Printer
GIVEN TO AGAIN AND AGAIN PAPER OUT PROBLEM - Tally 6312 Matrix Printer
    President:
  • 261 Answers
Hi
need service
then test the sensor that chek the paper is not jam or broken
Posted on Nov 13, 2011
I GETTING PROBLEM IN PRITING EVERY TIME WHEN THE PRINT COMMAND IS GIVEN THE PRINTER IS ASKING FOR THE PAPER TO INSERT IN MANNUAL PAPER SLOT WHERE AS I HAVE ALREADY DONE THE PAPER SOURING FROM CASSETE ONLY....
a piece of paper might have been stucked within the papers better check it. or it also could be the misplace of the wheels on the paper detector. check it too.
Ifthis solution helpful/useful for you please rate my solution. THANKS FOR USINGFIXYA.
May 17, 2011 | Canon LASER SHOT LBP 3300 Printer
I have a Ativa DQ60M Paper Shredder and it is very clogged with paper and it looks like some of the blades are slightly bent. Can it be sent in for repair or warranty?
Take away info: 3-year warranty on cutter.
Office Depot item #405935: Ativa DQ83M Diamond-Cut Shredder (mine show model ...Mn. It has a 1-year warranty for product, BUT ALSO a 3-year warranty for the "cutting cylinders". Call 1-877-777-HELP; www.ativaproducts.com .
I called 12-29-2010. Rep had difficulty finding product, put me on hold, found it. Said prod only has 1-yr w (per Office Depot online, this is all that is given as to info); but I said, no, 3-yr on cutter. I held again, rep researched and agreed. I took a case number and tried rep's troubleshooting suggestion: I put 3-in-1 oil (veg oil suggested by rep too) on the jammed shredded paper (machine still would go in reverse BTW); I let it soak 5 mins, removed paper, tried shredding, and paper jammed again. No replacement parts are avl. I called again, gave case number. Rep suggested I oil the cutter now that paper was removed. I said cutters are oiled from removing paper. I was put on hold, only a short while.
Good outcome thus far: I was given fax number and instructions to receive gift card in 6-8 weeks upon their receipt of my fax (to 1-888-561-0785) of case number, name (first and last), mailing address, and copy of the receipt.
What I learned: Do the maintenance oiling monthly or more if needed! Try to buy a shredder that is beyond my shred needs, e.g., a 10-sheet cutter but use it only up to 8 pages. Try to buy a shredder that has replacement parts.
The price of the Ativa in 2008 was $40 ($30 instant savings taken at the register), and it didn't get daily or regular use.
Good product support on this Ativa product. Glad I saved my manual and receipt!!
Dec 22, 2010 | Office Depot Ativa DQ60M Shredder
Is it possible that my Epson R2400 will just consistently reject specific types of paper? That is do 1 or 2 prints, but then run the paper through without printing and then not take the paper at all (media...
I have the same problem, my printer has been sitting unused for over a year now because I cannot afford to keep getting it serviced just to make 3 prints before it malfunctions again. I beleive it is paper dust getting on a sensor somewhere - I wish I knew how to service the printer myself! So if a solution is given to you I will be very interested in it!
Nov 02, 2010 | Epson Stylus Photo R2400 InkJet Printer
I CLEARED A PAPER JAM ON T8024 AND RESTARTED THE MACHINE. IT STARTED SHOWING REGISTRATION JAM. HELP ME TO SOLVE THSI PROBLEM
Hi
Check the following possibilities that may causing the error message.
1. Some times more paper may be taken in the paper feed area, check for any other paper jam in other area of the printer.
2. Remove all the printer drives, ports and uninstall the printer software and once again reinstall it by following steps given below
Start - Control Panel - Add and Remove Programs - Remove the program in the list called Tally Laser printer.
By now you have uninstall the software and now reinstall the software with the available cd given at the time of printer purchase and start printing.
Thank you
May 11, 2010 | Tally T8024 Laser Printer
Did something???? How do I cancel printing? Unplugging, Info I've been given will not stop printing, even when I press Delete or Cancel. It just wants to keep printing...
there is worm virus that will make a printer print until it runs out of paper and if you add more paper it will keep printing till it runs out again i would take the paper out of the machine and run an antivirus scan on your computer usually the print is not legible with this virus
Oct 04, 2009 | Office Equipment & Supplies
My 1310 prints a test page each time I turn it on. I don't need one. The alignment is very good. I don't want to waste paper if possible. I use hp all in one paper to print from my laptop. How do I...
thats not the test page my friend that is the allignment page what you are getting out again n again.you just place that printed side of the paper on the scanner glassand then press the scan button in your printer the-- on --light will blink for sometime and then stops that means the allignment is complete.and it will never come again till you replace that particular cartridges.
it is also given on that page which comes out what to press with proper diagrams also see that for proper idea.do not do any thing in your computer till that period.it should only be done with the printer.
Aug 11, 2008 | HP Office Equipment & Supplies
Problem with C3100 Printer
Hi Jakebum,
Please click on the web link given below and perform the steps given in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=us&lc=en&dlc=en&product=1146331
Have a great day!
Mar 24, 2008 | HP Photosmart C3180 All-In-One InkJet...
Tally 6312 Matrix Printer Logo
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
