Question about Xerox DocuColor 12 Printer
For fuji xerox 1250, how to change the Cyan toner dispenser.
    Top Expert:
  • Xerox Master
  • 11,573 Answers
Posted on Jun 26, 2016
Sir ihave dc12 with x15 fiery in printing from coputer getting dark back ground
Posted on Mar 26, 2011
Cannot get new cyan toner for 7435 to be recognized.. may of been changed before asked for by machine... not sure what to do next
Call Xerox. The Corporation needs to take responsibility for selling a machine that has toner available. //They should tell you where to get the toner or provide some for you. Start out nice but don't let the push you around; insist if you need to. Xerox can't sell a machine with no toner.
May 23, 2014 | Xerox Workcentre 7435 Color Multifunction...
How to refill fuji xerox docuprint p205b toner cartridge
Need to know how to refill the cartridge for xerox p205b , please email to me : myprinterwork@gmail.com . toner and chip also i got
Sep 05, 2012 | Fuji Office Equipment & Supplies
Instead of Bule print DC12 prints Violet
Hi there! The blue color is becoming violet because the Cyan and the Magenta toners are not getting mixed in the proper 100:100 ratio (100% Magenta and 100% Cyan make CMYK Blue). Since the print is violet, the culprit is the Cyan toner. Now, first, get the Cyan Developer Assy checked if there is enough developer in it. If no, get it refilled by a proper tech and manually mix about 50 grams of the Cyan Toner with the developer. Also get the tech to check the trimmer gap on the Developer Assy with a metering gauge. If yes, next check the Cyan dispenser motor located on the backside of the Toner Housing Assy. It is probably broken and not dispensing any toner to the Cyan Developer Assy . Additionally, check for the Cyan Dispenser Auger blockage or jam. It is located under the Cyan Toner Cartridge in the Toner Housing Assy and also check the auger under the Cyan Developer Assy. After sorting these out, you should get proper CMYK blue from the 10th or 12th page once you resume printing.Let me know. Regards
May 26, 2011 | Xerox DocuColor 12 Color Copier
Checked in Diagnostic cyan dispense motor and Cartridge motor working fine with cyan toner cartridge out, but when observed carefully by removing the cyan cartridge motor and coupling I could see that the D cut of cyan coupling was worn out as compared to other coupling of magenta , yellow, black. I put a packing of transparency in the D cut slot of the coupling so that the gear gives proper drive to the cyan toner cartridge and doesn't slip. The packing worked fine and the problem of customer was resolved.
Feb 05, 2011 | Xerox DocuColor 12 Printer
Steady yellow light on toner
May be problem on mother board or toner unite.
If it self change toner .
Feb 12, 2010 | Fuji Xerox® DocuPrint C3055DX Laser...
Error code 9-356
That is an issue with the cyan toner dispenser. Blue toner is not getting through the dispenser into the system.
You can try vacuuming out the cyan dispenser, but most likely the auger or gear is broken.
Slight chance the IOT board is bad, but not likely.
Jan 07, 2010 | Xerox DocuColor 12 Printer
Copier printer doesn't start. It says failure system, please turn off and then turn on again. 9-356 Please, if you have any solution for me, I'll apreciate it.
The low toner sensor detects that is not cyan toner for a period of 8 minutes. Probably the augers are blocked disasembly and clean the augers or change the toner dispenser motor
Jun 05, 2009 | Xerox DocuColor 12 Printer
Cyan is not working or printed over pages
Hi, Have you checked your cyan imaging unit?
R
Jun 18, 2008 | Xerox Phaser 7760/YDX Laser Printer
Xerox phaser 7760 streaking
to fined out what the problem could be you need to open a word doc and sent a blank page to the printer. from this it will show where the problem is in the printer
if u still get streaking it couls be a faulty toner and it may not be the cyan toner either. i would give the fuser unit in the printer a check. if there marks on tthis unit i can cause this problem as well
Nov 22, 2007 | Xerox Phaser 7700 Laser Printer
Xerox DocuColor 12 Printer Logo
99 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
