Question about HP LaserJet P2055d Printer
When hp laserjet p2055d printer says remove paper from bin
  • HP Master
  • 1,915 Answers
This happens, usually when a user is not carefull about removing paper from the exit bin. Normally what I find is that the flag that detects paper exits is stuck. There should be a small set of fingers that pop up as the paper exits. If the do not move up and down smoothly then this is where your problem is. Most times if you wiggles them around and push down they should reingage properly.
Posted on Mar 18, 2011
Jam in cartridge area
Hi, remove the toner cartridge out of the printer then remove the jammed paper.
Jul 07, 2014 | HP LaserJet P2055d Printer
REMOVE ALL PAPER FROM BIN ,OUT PUT BIN IS FULL Hi
Does not sound like a paper jam problem but a sensor problem sensor acurator is broken or out of place or the sensor is bad worse case the control that the sensors reports to is bad. Check you Output Bin Sensor acurator.
Sep 06, 2013 | Minolta QMS PagePro 9100 Laser Printer
Hp laserjet printer p2055d print blank pages what is the problem?
Probably a bad ink cartridge. Remove the cartridge and clean the face of it with alcohol to remove dried or clotted ink.
Dave W.
Sep 14, 2012 | HP LaserJet P2055d Laser Printer
Output bin full problem what should i do to solve this?
As the output bin accumulates
paper, the output bin delivery flap
rises until a flag blocks the
photosensor (PS911). When the
photosensor is blocked, this
message appears.
Rotate the output bin
delivery flap up and down.
The flap must move freely. If
the top cover has been
replaced, make sure that it
has been installed correctly.
Sep 05, 2011 | HP LaserJet P2055d Printer
Problem of output bin full
Hi
This is the problem with the out bin sensor.
Do you want a quick and easy remedy? then just bang on the printer where the paper comes out. The sensor flag will trip and it will start working again.
DO RATE MY SOLUTION.
Thanks
Saleem
Jun 29, 2011 | HP LaserJet P2055d Printer
When issue a print command, instead of print as expected it gives out this note: Output bin is full, Remove all paper from bin. what can I do?
Check out the arm that rides on the paper as it comes out. It may be stuck so that the sensor is covered. Or it may be that the sensor has some dust on it, so that it reports bin full. Check the arm and also as a precaution use some canned air and blow out the area where the sensor is located. Be careful with the air and don't let it move anything out of place.
Feb 26, 2011 | HP LaserJet P2055d Printer
Hi all in the house. Please, I need the
the sensor from the outpus (pages) from the printer is skipped
Feb 25, 2011 | HP Office Equipment & Supplies
Out put bin is full remove all paper to bin
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 05, 2011 | HP LaserJet P2055d Printer
I AM USING HP laserjet P2055d printer and its giving me an error saying "jam in output bin" What should i do because I cant see any jammed paper?
Hi
the last sensor on your printer it is stuck
check fro paper on it or if it is broken
Pls vote me to keep me alive
Nov 23, 2010 | HP LaserJet P2055d Printer
Paper Jam at HP LaserJet P2055d
There is output sensor where the papers come out, make sure its lowered down, be VERY CAREFUL not to break it.
Jun 11, 2010 | HP LaserJet P2055d Printer
HP LaserJet P2055d Printer Logo
513 people viewed this question
Seeker5211
Seeker5211
