Question about Microsoft Computers & Internet
Local area connection status - Microsoft Computers & Internet
    President:
  • 1,768 Answers
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Please give detailed information as to your issue to better assist you in your resolution of the problem you are having.The more information given will help determine the resolution and guide you to the proper fix for you Problem
Thank you.
Posted on Mar 18, 2011
3 Suggested Answers
  • 70 Answers
SOURCE: finding a local area connection
Is this a wireless connection?
If yes than most of the times the problem is that the signal is weak, try to put your Router/AP to a better place and see if you can connect, netstumbler can give you a hand in this, not sure if it's working under vista or not, but under xp it's perfect. My experience ist that what you need to have at least is 15 For SNR for your Router from the place where you are trying to connect. If it goes under 10 it will drop you down.
Better SNR means stronger signal and that's all that matters with a simple wireless connection.
Regards
Imre
Posted on Nov 26, 2008
  • 57 Answers
SOURCE: I can not connect to the local area connection.
1. check your network adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 justcheck the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
hope this will help you
Posted on Nov 27, 2008
My laptop wont connect to hub when wireless, says ip address wrong
Try manually locating ip address to your laptop Right click on the local area connection icon and then click on Status, click on the properties this will help you to be able to Change the Local Area Connection Properties, Click on the Internet Protocol(TCP/IP) Click the properties button under then click on use this IP address provide the required IP address, Subnet mask and Default gateway and also click on use this DNS server address and then fill the field as necessary after try repairing the Local Area Connection.
Mar 18, 2011 | Computers & Internet
I have a wireless router, my vista laptop is upstairs in my room, my wireless network connection is working. but the "local area connection" says that there is a network cable unplugged. but i have...
"local area connection" is the wired connection, which in your case is "unplugged" If you go to control panel and look in connections, you will see that you are connected with the wireless, if you right click on the wireless there is a checkbox to display the status on your toolbar along side of the "Local Area Connection" Hope that clears it up a little
Aug 29, 2010 | Computers & Internet
Connected but no access in internet
By connected do you mean ie local area connection says connected but when you try
to open any page in your browser it wont load.
Right click on local area connection icon in taskbar (right hand corner) select status
you should see packet activity with a steady stream on sent and recieved.
At the top you will see a support tab click this and you will see details of your IP which
should start with 192.168.?? etc click the repair tab this could fix it, also make sure IP does not
start 169.??? etc.
Hope this helps if not let me know.
Jun 11, 2009 | Microsoft Windows XP Professional
Why can't I access the Url http://192.168.0.30
check your IP address and see if the computer you are using is on the same subnet. your IP must be 192.168.0.xx where xx is any number. if you get a different IP address, use a static IP address between 192.168.0.31 to 192.168.0.40
how to check IP:
click Start - Control Panel - Network Connections - right click Local Area Connections - click Status - Details.
how to use static IP:
click Start - Control Panel - Network Connections - right click Local Area Connections - click Status - Properties - TCP/IP - choose Static - use any IP address in the range above.
click apply and try to access your repeater again. I am assuming that you have given the correct IP of your repeater.
Apr 17, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
Cannot access the URL addres http://192.168.0.30 (page cannot be displayed) any suggestions?
how to check IP:
Intermittent NIC connection
of you have the driver Cd, try reinstalling the driver.
Jan 20, 2009 | Abit : KV7 Socket A KT600 Motherboard
Finding a local area connection
Regards
Imre
Nov 26, 2008 | Linksys Wireless-G Broadband Router
Hiii sir
some softer drivers are included under windows, some are not, like for example your network drivers arent. u will have to install them manually from the CD that came with the motherboard.
Hope it helps
Z33m
Dec 10, 2007 | Mercury P4VM800M7 Motherboard
Computers & Internet Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
