The touchpad of my laptop dont work i think that i press something from putton but i dont know what can you help me ?
    Problem Solver:
  • 18 Answers
There is combination of ( Fn key + Function keys) which can be used to disable and enable touchpad and other shortcuts. you need to check it on the keyboard of your laptop. it is printed on function keys.
Posted on Mar 18, 2011
  • 356 Answers
A lot of laptops have a key to toggle the touch pad, usually right above it. Other models will have a function key (Hold Fn + press that key). Both are typically labeled with an image of a touch pad and then a second one with a line through.
Please post your laptop model if this doesn't solve your problem and leave feedback if it does.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 70 Answers
Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return."
Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touchpad to become unresponsive. But if any of these steps fail to remedy the problem, then the touchpad may need to be repaired or replaced.Or simpily buy a cheap mouse
Hoped this helped :)
Touch Pas/Mouse no working
again try it without batterie it must be the batterie try only with the cable direct if its than still than you know it something with your pad which i dont think
Apr 17, 2012 | Lenovo 3000 C100 Notebook
Describe your HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook Problem my internal mouse is locked, I dont know why and dont know how to fix it (I dont use an external mouse or keyboard). ...
Hi melissamhahn..
Try this solution to your problem
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
D. Sony Vaio Users: Start>Settings>Control Panel>Double click the Mouse icon.
Look at the top left hand side of the page, at the top and make sure that the "Tapping" box is unchecked, if it is checked then, you will uncheck it.
Please take time to rate me thumbs up
Sep 17, 2011 | HP Pavilion dv9000z Notebook
Hi, I need help with my acer aspire 5750, the Multi-Touch Touchpad has stopped working. It works as in its moves the cursor on screen but the secondary touch control that controls; Circular-motion...
Hi
can you please check that the touchpad has not been locked i dont think it has but worth a try
by pressing FN+F7 or FN+F9
also check that the nulock has not been ingaged by mistake
also the scroll lock
or go to
start
all programs
acer
acer management
contents
scroll down to find the touchpad/pointing device
go over to the right by the green icon and hit the install tab
and let windows re install the touchpad
may be this will help
many thanks
Jul 07, 2011 | Acer Aspire One PC Notebook
Touch pad doesn't work AT ALL!!!!
Hello there, Kasie!
Hopefully I can help. On laptops, there will *usually* be a "function button" one can press to disable the touchpad in the even that one wishes to use an actual mouse instead of the touchpad. -- This would be in the interest of not accidentally triggering clicks, or mouse movement when typing, etc.
Without knowing the make and model of your laptop, I can't tell you the precise button to press to re-activate your touchpad. On most laptops, you'll need to hold down the "Fn" key (usually at the bottom left or right of the keyboard) and then find the function key (top row of keys... F1, F2, F3, F4 and so-forth)... Look at your function key row. See if there is perhaps a key with a little "drawing on it" that looks like a touchpad.. like a horizontal rectangle with 2 smaller squares under the rectangle, representing the rectangular shape of the touchpad and the two "mouse buttons" beneath it... if you find something like this, it will likely be the one you'll need to press.
However, on some laptops, the button will be just above your touchpad... you'll be able to press it, and some sort of indicator light will either light up in red to let you know it's been deactivated, or white / green to let you know that it's currently activated.
One of my laptops which is an HP has the button at the top left corner of my touchpad.. I have to "double-tap" it to deactivate / reactivate the touchpad; while my Toshiba laptop has a button directly above the touchpad which I only have to press once. -- Both laptops have an indicator light as well. The HP's "double-tap button" will turn red / dark orange to let me know that I've deactivated it... With the Toshiba laptop, there is a light just below the touchpad area which is always lit up as a "bright white light bar" when active and simply not lit up when deactivated.
I wish you the best of luck with this, and hope I've helped you!
Apr 24, 2017 | Dell F3534 Touchpad
Left mouse click quit working
Hi
If this a laptop touchpad mouse button, I've had a similiar problem with a older laptop, the button was not getting touched properly, I had to press it harder a few times and it eventually started to work again.
There maybe something in between case and the button that is perventing it from being pressed completely.
If this doesn't help, try using a external usb mouse for example.
The laptop might need to be taken apart and the touchpad buttons looked at and possibly cleaned or the buttons / whole touchpad replaced to sort out the problem.
Thanks and good luck, let me know if you need further assistance.
Ekse
Aug 14, 2009 | Computers & Internet
Touchpad problem
go to techbuddies.org.... they will help you out..
Jul 10, 2009 | Lenovo IdeaPad Y510 Notebook
Quickplay touchpad above keyboard
The following illustration and table describe the computer TouchPad.
(6)
TouchPad on/off button Enables/disables the TouchPad.
Component Description
(1)
TouchPad light Blue: TouchPad is enabled.
Amber: TouchPad is disabled.
(2) TouchPad* Moves the pointer and selects or activates items on the screen.
(3) Left TouchPad button* Functions like the left button on an external mouse.
(4) Right TouchPad button* Functions like the right button on an external mouse.
(5) TouchPad scroll zone* Allows you to scroll up or down.
(6) TouchPad on/off button Enables/disables the TouchPad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 08, 2009 | HP Pavilion dv9000z Notebook
My sony laptop touchpad not working properly
i have two solutions for you. the touch pad can be disabled on the motherboard so plz hold-down the fn key and press the function key that has the sign of a hand pointing something and the second is that ur drivers that enables thae touch pad to work has been courrupted so plz try reinstalling for the touchpad or try repairing ur operating system.
Apr 07, 2009 | Sony VAIO VGN-FZ240E/B Laptop
HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE PRO M15-S405
Press the Fn and F9 keys, that should turn it back on. Let us know if that solve your issue and please dont' forget to rate this posting.
Feb 09, 2007 | Toshiba Satellite Pro M15-S405 Notebook
Computers & Internet Logo
David Payne
David Payne
