Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
I have a burning smell coming from inside my kitchenaid superba side by side fridge. It smells like a burning plastic. The fridge still turns on and keeps things cool, but it started to kick out that burning smell yesterday and I can't find out what it might be. Any help?
  • KitchenAid Master
  • 17,130 Answers
Remove the power plug and move your fridge forward. Now look at the rear bottom side of the fridge to see if there are any parts that heats up. You can trace this to the smell emitting from the heated part and confirm. It can be the motor, contactor or the defrost timer.
Posted on Mar 18, 2011
Frgidaire Side By Side Burning Smell
Most burning smells in refrigerators comes from the compressor overheating due to the overload relay going out . Unplug the fridge before the compressor burns out and take the model number to appliance store for a new relay. The relay is located in the back of the fridge inside the lower back panel.
Aug 03, 2012 | Frigidaire FRS3R5EMB Side by Side...
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Apr 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
Burned plastic part on refrigerator compressor
side by side refrigerator freezer, smelled melting plastic, found a plastic box connected to the compressor burned. What is this and how much does it cost to replace?
Dec 13, 2009 | KitchenAid Refrigerators
Need to have a foul smell removed in kitchen
bleach spray in a squirt bottle
1part bleach
10 parts water
pull the pan out from under the fridge, clean it
lift stove top, clean underneath
if dishwasher present, spray it and cycle
if garbage disposal present, spray and cycle
if A/C ducts in floor, open and clean
also, replace air filter, turn on blower, and spray solution into return
use your nose and try to find the source
Jun 27, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Odor coming from back of fridge
This is very unusual, most of the time when I get complaints about odor it's form the inside of the cabinet. This should be easy enough to solve though. The odor is likely from dust accumulated underneath, or from something in the drain pan. If the unit has visible fiberglass insulation underneath you should replace it with new because, even if the source of the odor has been removed, the insulation can still contain it.
Unplug the refrigerator, take off the kick plate and rear cover. Clean and vacuum the entire under- carriage, condenser, fan, and condensation evaporator tray.
Be gentle with the components though, especially the capillary tube ( a pipe about the size of a 14 gauge copper wire )
Jan 06, 2009 | KitchenAid Superba Architect KSCS25INSS...
Smoke from bottom of superba fridge
Dear customer,
Plz perform the following checks..
  • Remove spoiled food
  • Clean refrigerator interior with a solution of hot water and baking soda
  • Clean the door seals
  • Remove breaker strips and check for wet insulation
  • Please rate this,Thank u
    Dec 17, 2008 | KitchenAid Superba Architect KSCS25INSS...
    Very bad tasting/smelling water and ice cubes - Superba KSRS27QAAL05
    Since I found that the water itself being fed to the trays and being dispensed was bad. I replace the nylon, reinforced plastice icemaker hose with 1/4" copper supply line. That, along with purging the hopper (getting rid of) any old ice as well as washing the hopper out real good and giving the freezer a general cleaning - seemed to do the trick. No repugnant odor or taste. (I didn't even replace the filter- the cycle is every 6 mos.)
    Hope this helps others who may be experiencing this same prob with this type of side by side appliance.
    Lou
    Jul 30, 2008 | KitchenAid Superba Architect KSCS25INSS...
    KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
    962 people viewed this question
    Top KitchenAid Refrigerators Experts
    John Tripp
    John Tripp
    vince
    geob91
    Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
