Question about IBM (09N5424) Motherboard
MOTHER BOARD HARD BOOTING PRBLUM AND DEVICE DETECTING PROBLUM
  • IBM Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 18, 2011
No boot hd disk error
HDD not Detecting only Some region, if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
More Technical Help TechSupportMart
Feb 05, 2014 | Seagate Barracuda 7200.7 40 GB Hard Drive
PC not detecting HD
HDD not Detecting only if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
Thanks..
More Tech Support Contact
http://www.techsupportmart.co.uk/
Feb 05, 2014 | Transcend StoreJet Computers & Internet
My mother board DG41RQ is not detecting any hard disk drive
Here are two locations in delhi;
Upper Ground Fl, Block E
Int'l Trade Tower, Nehru Place
New Delhi
Delhi 110 019
India
21 Nehru Place, Suite 311
Paharpur Business Centre
New Delhi
Delhi 110 019
India
Jan 27, 2010 | Intel DG41RQ Motherboard CPU Bundle - ...
My laptop kept on writing operating system not found after trying to boot it,what do I do?
may be it is not detecting the hard disk go to bios setting and check the booting device setting and it is detecting the hard drive..if it is not detecting then you need to replace the hard disk.
Jan 12, 2010 | Computers & Internet
Hard disk Not Detecting (Media Problem)
may be comming steps you solve your problem
check your bios settings on first bootable devices
check your ide or sata cable interfacing mother board correctly
check the power connections
also you want check this one is your os faulty,now you make master &sleve and boot anther hard drive
Jun 12, 2009 | Kanguru - 500GB Disk (Black)...
Hardware Detection problem with ASUS K8VMX Mother Board
Firstly, Put a new battery on your motherboard(usually a cr2032).
Unplug everything except the ram and try to boot up.
Switch off and gradually attach one component at a time and reboot.
Remember to turn off every time you add a component.
This happens because your bios chip is getting mixed up because you are changing the configuration all the time.
Hope this helps
Jan 19, 2009 | ASUS K8V-MX Motherboard
When booting from XP 'operating system missing'.Not booting from harddisk but booting from CD
plz check in bios your hard disk is detecting, then put the first boot device as hard disk.save and exit.
If the problem is not solved then you try with another hard disk cable.if the problem is not solved then you have to buy a new hard disk
Aug 08, 2008 | Computers & Internet
Linux Not installing and Not detecting Harddisk
what version of linux are you using, suse, mandriva, fedora etc...
and which release is it (eg. suse 10.1... or whatever)
Dec 30, 2007 | Seagate Barracuda 7200.10 500 GB SATA Hard...
System not detecting hard disk
Check the position of the master/slave jumper on the drive.
Oct 06, 2007 | Excelstor Technology J880 Hard Drive
IBM (09N5424) Motherboard Logo
35 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
