Question about Vaultz VZ01002 Locking Cash Box
I purchased 2 Vaultz locking cash boxes for my kids. They are locked with out setting a comination. Is there a way to open the cash box? Can we reset password?
Why can't i open lift gate on Suzuki grand vitra. not with keys nor automatic door lock.
read the glove box guide?
what year, we cant guess them
1999?
is this a , I dont have keys for my car post? or
what? what do you have that works, nothing?
inside car
or from outside?
these cars have a kids lock. that the driver can set to keep kids from opening doors.
its covered in the operators guide, but no year no joy.
Jun 11, 2016 | Suzuki Grand Vitara Cars & Trucks
I lost the combination and I need to know how to open it without the combination. Help!!!
man I hate this when it happens . to destroy a perfectly good case . saw or grind the lock off .
Dec 09, 2015 | Vaultz Locking VZ01353 SLR Camera Case
Combination for an Office Depot(?) combo lock cash box long forgotten; how can I open this? Model No. 538-793.
Best take it to a locksmith, he may be able to dismantle the lock and reset the tumblers, and give you the new combination.
Aug 03, 2015 | Locks & Locksmithing
Vaultz cash box combination
If it's open you move the handler to the left and move the numbers to whatever combination you decide, as you finish just release the handler! Try it fist before you lock it! Good luck!
Jul 10, 2013 | Office Equipment & Supplies
Vaultz VZ01002 locking cash box, lost combination
I Lost the combination to the vaultz lock box (vz01002). I followed the instructions on how to open it using a flashlight and small screw driver. it worked like a charm. only difference was i had to push each dial to the right instead of the left. and the grove to look for is a little tricky. inside you can see a white piece of plastic which turns with the dial. and you need to look close because the groove is on that white plastic and is kind of hard to see as the groove is white as well. so its very easy to miss it. once you find one you know exactly what to look for. good luck. this site is great for tips, tricks, and solutions to just about anything.
Jan 10, 2012 | Vaultz VZ01002 Locking Cash Box
Misplaced instructions on how to reset combo on Vaultz cash box with 3 digit combo & latch
Directions for setting combination locks
1. With the lock open, push button (to the left, yes opposite of the arrow) and hold until the second operation has been performed.
2. Set number wheels to the desired combination (numbers roll down)
Do not forget the combination you have set!
3. Now release button. Press the button again as a check.
Apr 15, 2011 | Office Equipment & Supplies
Harldline safe not opening
Sure blame the poor kid.
Think about it, what good would a safe be if by pressing a few keys the combination was changed?
As with any combination safe you need to clear the combination by turning one, two or three times in the opposite direction before entering the combination.
Now say your sorry to your kid.
Jul 24, 2009 | Safe International Digital Electronic Safe...
How do I change the combination code for the glove box if there is not a way how would I find out what the combination is
I assume you know the current combination and can open it. To set the combination to a number code of your choice you must first remove the red plastic guard over the yellow tab next to the combination dials. Push the glove box release lever to the right to open the glove box. To change the combination:
1. With the glovebox open, hold the release to the right and slide the yellow tab up. This locks the release open and permits you to reset the code.
2.After resetting the code, write it down in case you forget it.
3. Slide the yellow tab down and the release will return to the closed position.
4. Close the glove box and move the dials off the code you set to lock it.
This is all from the 89 Pontiac Owners Manual. Good luck, hope it works.
Jun 15, 2009 | 1989 Pontiac Grand Prix
My voicemail on my nortel platinum is locked
You need to reset the password .
Feature 983
enter 1020000 as the password if you have a 3 digit extension number or enter 120000 if you have a 2 digit extension
next press the button under the screen with the heading of m box or mail box
next your options are add delete or change
press change .
next enter mail box number
the next step will be to press the reset button
after re-setting the password press the release button . Now open your mail box and enter the default password 0000
Jun 05, 2009 | Nortel T7316E 2-Line Corded Phone
Vaultz VZ01002 Locking Cash Box Logo
271 people viewed this question
Top Vaultz Office Equipment & Supplies Experts
k24674
Are you a Vaultz Office Equipment and Supply Expert? Answer questions, earn points and help others
