Question about Compaq Presario Notebook
Power problem have you ever had trouble plugging your power supply and the batterycharge indicator not coming on. I first thought the charge sensor in mybattery was shot, that my battery was old and in need of replacement.It would hold a 1.5 to 2 hour charge but if I didn't plug in the powersupply, hold it in firmly for a second, then stablize the cord, thecharge battery indicator would flicker off... I think now that I have ashort in the connector but when I get inside, the connector wires areon the underside and not visible for inspection or repair.
  • ayitey Aug 02, 2008
    power problem
  • Steve Si
    Steve Si May 11, 2010
    Do you think the problem is with the adaptor or the notebook?
    What conector did you get inside of? Ac adaptor mains plug, AC adaptor mains input, AC Adaptor DC output, notebook DC input?
  • 38 Answers
I would suggest you replace the power supply. Most likely there is a broken wire in the supply.
Posted on Aug 20, 2008
I have the Gateway m2414u notebook. I'm having trouble turning it on. I plugged my charger on it and the light comes on indicating it's charging. But when I go to turn it on it only blinks once and it...
Try removing the power supply and battery. Remove the hard drive and RAM. Power it up from the power supply alone. If it goes to BIOS, that has checked the system board. If not, you have a main board issue.
Dec 01, 2013 | Computers & Internet
I have the Gateway m2414u and I'm having trouble turning it on. I plug in the charger and the light comes on indicating it's charging but I press the power on button but it flashes once and it doesn't turn...
Try this.
My ibm laptop's mother board cannot power on, please help me solve it
The most likely problem is that the onboard power supply has failed, usually a capacitor has burned out. Or it could be a loose DC supply socket (they only need to have one loose pin on the motherboard.)
Nov 01, 2012 | IBM Computers & Internet
Unplugged tv and when plugged back in doesn't come on
Hello
If you have unpluged the TV from wall socket and it doesn't come On when you plug in back, either its power supply system or its stored memory has the trouble. Look whether the power indicator light coms on. Ensure that the main power ON/OFF switch at the front panel of the TV is ON. If the front panel power switch, control switch of your wall socket, and all the other electrical connections are OK, and still the TV doesn't come ON, surely the power inverter baord has the trouble and must be either repaired or replaced. if the power indicator light comes on, and your TV doesn't come ON by remote POWER ON button, the settigs that were stored has vanished, and resetting it to its original setting is necessary. Follow its manual for 'initial setup" and so all the recomended setting there. OK.
Apr 11, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Power supply cords is ok but the power indicator lamp is not working.
If you have tested your power supply cord with say a voltage meter, and it is working, then the problem lies with your motherboard. Do you have a charged laptop battery? If it powers on with the battery, then the problem is isolated to the power plug port on the motherboard.
Mar 21, 2011 | LG Computers & Internet
Won't start - battery critically low
You should have a light on the notebook indicating that the power supply is plugged in (this should come on with or without the laptop being turned on). My acer has a green light for power, and the battery indicator shows amber for charging and green for full. If you are not seeing the power or charging indicators, you either have a damaged power jack, or a damaged power supply. Power supplies can be purchased usually for fairly cheap online, but if your power jack is damaged, the laptop will have to be serviced by a service center, or by someone who is skilled with a soldering iron and the disassembly and reassembly of laptops.
Feb 28, 2010 | Acer TravelMate 2413LCi Notebook
My ibm thinkpad laptop stopped working and I thought it was the power supply but I got a new power supply and it still doesn't work.
Please clarify - "doesnt Work".
Does anything happen at all when you press the power button?
Are there lights indicating charging when it's plugged in the wall??
Is the battery in the laptop???
Please use the "continue with this expert" option and reply with a bit more information about your problem.
Thanks!!
Apr 25, 2009 | IBM ThinkPad R40 2897 Notebook
Power indicatoror
From the manual:
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
Compaq Presario Notebook Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
