Question about Sharp AL-1000 Laser Printer
Paper jams and error P shows up on my sharp al1000 printer
  • Sharp Master
  • 17,130 Answers
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism thus showing the error signal.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Posted on Mar 18, 2011
    Scholar:
  • 114 Answers
Dear Friend
the paper jam in the machine is due to the rubber feeders present in the tray bin that pick the paper up and forward them.
so i suggest them to take a cloth and dip it in water and then (just like moisturized cloth) resin it completely that it do not form droplets that gets into the copier.
now switch OFF the machine and try wiping the rubber feeders with the cloth.
you will see a lot of darkness on the rubber feeders.
clean all the runner feeders with it and close the machine.
now your problem will be solved for paper jams.
thankyou
Gagan Gupta
Is that Useful?
My SHarp calculator shows a "P E" message and quits working. Can this be shut off so I can use the calculator?
From a Sharp Printing Calculator manual
When the paper jams, the printer stops and the error symbol
"P.E" appears. Turn off the calculator. Tear off the paper tape
and then pull the remaining part of the paper forward and
completely out of the printer
http://www.sharp.se/cps/rde/xbcr/documents/documents/om/30_cal/EL1611P_OM_GB.pdf
Feb 14, 2017 | Sharp Office Equipment & Supplies
What is mean by call sevices code H5-01 in sharp mx printer
H5-01 means repeated paper jams on the Sharp photocopiers.
Once the paper jam is cleared properly, you need to clear the error condition.
Put it in 'Copy' mode
Press on the keypad:
P * C * 14
Click execute and press 'Yes'
Then press the 'Copy' tab.
This will reset the menu and jam condition.
May 21, 2015 | Sharp Office Equipment & Supplies
Machine diplays "paper jammed" with no paper in
Hello
This the method to clear paper jam, follow these steps:-
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the ink cartridge. 5 If necessary, remove the ink cartridge. Place it in a bag or away from light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Replace the ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Good Luck
Dec 18, 2010 | Sharp UX-B20 Plain Paper Inkjet Fax
I have a xerox xd 100 work center laser printer...i have a constant paper jam problem...the paper feeds and it does not go into the black gadget in the machine that gets hot....i have blown out the machine...
I have seen this more times than I can count. The problem you have is definately a broken fuser drive gear. The fuser unit is the black unit you refer to that gets hot. It has 2 fuser rollers that heat up and fix the toner onto the paper. One of the rollers has a drive gear on it that goes bad and breaks after a time. You just need to have someone replace the gear. I have included a link to the part that has a picture of the part. Also keep in mind that your machine is made by Sharp and is nearly identicle to a Sharp AL1000 model which may make it easier to find a local person that can install the part.
http://www.precisionroller.com/search.php?q=al1000+fuser+gear
Good Luck and Thank You for using Fixya.
WheatlandServices
Sep 29, 2010 | Xerox Office Equipment & Supplies
SHARP AR5516 PAPER JAM ERROR MESSAGE
when you open side door in the up you see a black unit check if sesor not broken. also open cassete and see inside no paper jam there
May 27, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp MX 3100n showing code H5-01 , what is it,how do I fix
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
Feb 19, 2010 | Sharp MX-3501N All-In-One Printer
SHARP AR5316 SHOWING PAPER WHILE NO PAPER JAM
try to chek if the actuator of the exit sensor is ok you will find it when you open the side door exactly attached to the heater try to check the end is it in plase or not if not use sim 30 sub1 to check all sensors you wil solve your problem
Mar 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Sharp 5316 showing paper jam sign at right door but no paper
Shut it off, wait 30 seconds, turn it back on. If the path IS clear, the error will be gone.
Feb 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL-1000 Laser Printer Logo
248 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
