Question about Boss Mt 2 Metal Zone Effects Pedal
Whenever i push the the pedal down the distrotion comes on for 10 seconds and then turns off and the light doesnt turn on either help me!!!
  • Boss Master
  • 5,603 Answers
If you are running on battery, replace the battery. The batteries tend to recover a bit and will operate the unit for a brief period
Posted on Mar 18, 2011
Unit powers on, is unresponsive
It sounds like you need to take it in for repair.
May 07, 2015 | Behringer US600 Ultra Shifter/Harmonist...
Sustain pedal does not work
Yamaha FC4 and FC5 sustain pedals are normally closed, sorry Fred. Roland is opposite. I suspect the P120 just needs to be reinitialized. Hold down top white key (C) while turning on power. Wait 3 seconds and then release white key. Should now be reset to factory spec. Always plug the pedal in before you turn it on. If it still doesn't work check it with a meter.
Mar 17, 2012 | Yamaha CP300 Stage Digital Piano...
I have purchased 2 Ibanez TS8DX Tube screamers. Both are broken right out of the box. I plugged a cable into the out jack and into my amp. I then pluggen my guitar cable into the IN jack. Pushed the pedal,...
The input cable MUST be a TS (unbalanced cable) to turn the unit on. The sleeve of the input cable is what connects the battery. If you use a TRS cable at the input it likely will not turn on. A TRS cable has a tip, ring AND sleeve like many 1/4 inch stereo cables.
Sep 15, 2011 | Ibanez Ts9dx Turbo Tube Screamer Overdrive...
I have the Roland Boss Rc-20xl Loop Station, and I'm running off of batteries I have been since I got the pedal. In the middle of recording a phrase the pedal shut off and started resetting itself...
Hello!
I am not positive on this but I would try to clear all of the loops. Try holding the right pedal for about 5 seconds.
If that does not work, hold the right pedal for about seconds while you turn off the unit. Release the right pedal then turn the unit back on.
Hope that helps!
May 11, 2011 | Roland Boss RC20XL Phrase Recorder Pedal
Hi :) I have a problem with my Boss mt-2 pedal. Whenever I insert the jack plug in the input, the adapter switches off automatically. The pedal works fine with battery and no problem is created. This only...
Make sure you are NOT using a TRS (stereo or three conductor cable) type cable. PLugging into the input should turn the pedal ON, not off. The switch on the jack may be broken or soldering to the circuit board may be broken OR worst case, there is a crack in the circuit board.
Mar 16, 2011 | Boss Mt 2 Metal Zone Effects Pedal
There is a constant loud hum/buzz whenever I turn the pedal on. With my Boss Mt 2 Metal Zone effects pedal. It happens whether or not the power supply is plugged in. Ive tried switching cables and...
First and foremost , check your signal chain. By that, i mean put the pedal aside, ...just unhook it and take it out of your signal path. Using the same cables , guitar , amp, other pedals - borrow a friends MT-2 if you can get one , and try THAT to see if THAT works , OR any other kind of distortion pedal. If another one works ok , it's YOUR MT-2. Boss pedals are pretty rugged , but sometimes the little actuator (on/off switch) underneath the treadle (where you push your foot down) will become faulty. That's a high-gain pedal - are you using a basic Strat or other single-coil pickup guitar? If so , are you playing close to any flourescent lights? SIngle coils are noisy around those lights. Will cause a hum / buzz if using a heavy dist. pedal. You can check that by moving around as you play.
Nov 02, 2009 | Boss Mt 2 Metal Zone Effects Pedal
Problem with the sound? Or is it?
I have this exact pedal. The sound should change as soon as you start pressing it down. With a wah, the frequencies are low at the heel down position and steadily change to a treble higher sound when in the toe-down position. Does the LED on the right side of the pedal come on when you press down? Are you using a fresh battery or a power supply with enough current? Is the "loudness" knob effecting the tone when turned up? If the answer to all of these questions is yes...then I would return it for a new one or send it to Morley for repair. They are nice sounding pedals. The problem could ultimately lie in the optical sensor that controls the wah effect.
Jul 29, 2009 | Morley George Lynch Dragon Wah Guitar...
Pedal Malfunction RP250
You will have to recalibrate your pedal. If you don't have your manual anymore try going to www.digitech.com. The procedure for the RP350 so that you don't lose your presets is : 1. Press and hold the UP/DOWN Footswitches until PDLCAL appears in the display (BYPASS,TUNER and EXIT will be displayed before PDLCAL is accessed after about 5 seconds). 2. When the display prompts you with TOEDN, rock the EXPESSION PEDAL forward (toe down) and press either FOOTSWITCH.
3. When the Display prompts you with TOE UP, rock the EXPRESSION PEDAL back (toe up ) and press either FOOTSWITCH.
4. The Display now prompts you to calibrate the V-Switch sensitivity (VSWxxx), where xxx is the current V-switch threshold. Rock the EXPRESSION PEDAL forward and press firmly on the toe once to turn the V-switch on (WAH ON) and again to turn the V-switch off (WAH OFF).
5. If the V-switch is too sensitive, press the right UP FOOTSWITCH to raise the threshold (range is 0-2000. Keep testing the V-switch sensitivity and adjust the threshold until it only engages when you want it to ( too sensitive a setting will lead to the V-switch falsely triggering on or off when using the Expression Pedal).
6.When the V-switch sensitivity is set to your satisfaction, press both UP/DOWN FOOTSWITCHES simultaneously to exit. NOTE: IF the DISPLAY shows ERROR, an error has occurred and steps 2 through 5 should be repeated. Sorry fo the caps but thats how the instructions appear in my sons manual. You can also dowload the manual and an editor librarian (for the 350 at least) at their site. They might even have an update for your pedal. Hope this helps. Keep playing.
Jul 09, 2009 | Music
Boss Mt 2 Metal Zone Effects Pedal Logo
118 people viewed this question
Top Boss Music Experts
Matthew Spark
Matthew Spark
shaun taylor
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Boss Music Expert? Answer questions, earn points and help others
