Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
I am currently operating a MSYD36NA / MUYD36NA Mitsubishi Mr. Slim 34,600 BTU 15.1 SEER Single Zone Ductless Mini Split Air Conditioner. Has been operating for the past 2 months with no issues. It was installed by a profession on a dedicated 30amp circuit (i should note that the breakers are approximately 25 years old) Today while the unit was operating the circuit breaker popped. I went to the fuse box and reset it and within 1 minute had popped again. I reset it once more and the breaker stayed on. After returning to the unit it was obvious that the outside unit was not functioning but the indoor unit was. I turned the breaker off for 1 hour and turned it back on and it was still the same thing. Indoor unit was running (not cold) outdoor unit was dead. I opened up the electrical panel on the outdoor unit and could hear a faint buzz (not sure if this is normal or not). I turned off the breaker so that I could examine. I figured that it was possible that a fuse inside the unit had failed. Sure enough I found a burned out fuse labeled T2A /250 V. The fuse looked smokey on the inside. I have removed the fuse and plan to replace it. The unit is less than one year ago from acwholesalers.com and has only been installed for approximately 6 weeks. Was functioning perfectly up until now for about 10 hour per day. ***UPDATE: I have replaced the 30amp circuit breaker with a new one and replaced the fuse with an F2A/250 V (old one was T2A/250 V) and the outdoor unit will still not function Looking for advice on how to fix this. Thank you Service manual can be located here: https://www.acwholesalers.com/v/vspfiles/assets/images/MUY-D36NA%20Service%20Manual.pdf
burzerko
  • 254 Answers
SOURCE: mr slim 12,000 btu 110 volt
Sounds to me like yo have dirty condenser coils (outside unit) After this runs and gets hot it loads the compressor because it can not release heat out of the condenser coil it also may have a restriction somewhere on the high side that could cause this maybe in a txv or in a line filter.
Hope this helps Ya
please rate me
Posted on Jul 20, 2008
  • 958 Answers
SOURCE: Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
james3751
  • 614 Answers
SOURCE: Mitsubishi Mini Split sytems fails to operature
I will contact you later today with diagnostic data. Russ
Posted on Aug 01, 2009
hvac1960
  • 2133 Answers
SOURCE: I have a Mitsubishi electric
Please check your indoor motor's mechanism is faulty. Or capacitor(condenser) of fan motor is weak. Replace it.
Posted on Dec 17, 2010
User manual. Where can I get a copy
Pioneer Mini Split AC - Wholesale Prices, Open to Public‎
Adwww.highseer.com/Pioneer-HVACInformation & Support
Download Manuals, Parts Diagrams
Sales, Technical Brochures & More
Nov 08, 2015 | Pioneer Ductless Mini Split INVERTER Air...
What kind unit is
This type of unit is called a Mini Split Air Conditioner.
Hope that helps you check us out at Air Duct Cleaning
Nov 02, 2015 | Samsung AQV36JA Classic 36000 BTU Single...
Ice hitting outside fan
It sounds like your system might be low on coolant. Check the pressure of the main line and check it against the specs. You may have a leak in the system.
Mar 02, 2015 | Rheem 12,000 BTU Mitsubishi 13 SEER R-410A...
What is error E5 on pioneer mini split air conditioner?
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in.
Try cleaning it (them if inside one too), with dishwashing liquid and spray outside hose.
Jun 03, 2014 | Pioneer Ductless Mini Split INVERTER Air...
Why is my Mitsubishi mr slim is blowing black particles into room?
Area where "fresh" air is being pulled in is dirty, filter needs replacement, heat exchanger is old, a seal is old/torn, or mold is shooting out!
http://www.ehow.com/info_12016541_particles-blow-out-fan-air-conditioner.html
May 27, 2014 | MR SLIM Split-ductless: Mitsubishi...
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
Mr slim ductless ac choices
Try this Air Conditioner Sizing Worksheet from Consumer's Reports. It will help you.
I hope you find this information to be very helpful to you moving forward.
Please leave a rating. :-)
May 09, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
95 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
