Question about Dell OptiPlex GX280 PC Desktop
High speed fan with no display how can i solvce this problem
    Novelist:
  • 66 Answers
The GX280 line is notorious for having blown capacitors with odd symptoms like those you present here. There are also a couple simpler solutions that might get you going.
1) Verify that you are plugging your monitor into the proper video port, sometimes there is more than 1 and simply switching which port it is on will do it.
The problem with this is that you say that the fan is on high speed, which is an indication that the system is overheating. Generally the fan slows down after a few seconds after turning it on, right?
If that sounds like the issue you can verify it by opening up the tower using the 2 buttons on the short ends of the tower and pulling the top up from the base, it will open like a clamshell. You might need to take the leg/stand holder off which is attached with a thumbscrew on the bottom first.
Once inside, look at the capacitors, the image below will show you what they look like. The top of them, where the K is stamped, should be very flat. If they are bulged or exploded at all this is definitely your issue. If it is, the only real option is the replace the motherboard and given the age of these towers is probably more cost effective to replace the tower as a whole.
Hope this helps!
Posted on Mar 18, 2011
Fan is not working on 2001 Chevy Silverado 2500 truck radiator fan motor?
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan s/p relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the high speed fan relay and the cooling fan s/p relay through the high speed cooling fan relay control circuit. This energizes the cooling fan s/p relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Your best bet would be to take your vehicle to a qualified repair shop !
Relay Driven Dual Cooling Fan Diagnostics
Aug 19, 2016 | 2001 Chevrolet Silverado 2500
3 speed fan barely changes speed
You are talking about your blower fan for the air conditioner and heater right? More information will be needed to solve the problem.
When you say it barely changes speeds, does that mean it doesnt speed up, or doesnt slow down? By that I mean, is it "stuck" on low, or high?
Most blower fans run at different speeds through the use of a multi-stage resistor built into the fan switch circuit. Low speed is a high value resistor, medium speed is a low value one, and high speed is the fan running without any resistance.
If your fan is running on high and doesnt seem to want to run on lower speeds, the resistor pack may be failing. If the fan is running on low speed only, it may be that the fan itself is beginning to fail, or that the lubricant in it has gotten gummy.
Dec 07, 2015 | Cars & Trucks
My ac is not working I have a Chevy Tahoe 2005 the fans won't turn on either .
Hi Maria , The A/C system wouldn't keep the fans from running but none working cooling fans will keep the A/C from working ! This is a fairly complex system if your not familiar with this sort of thing ! I will add the description from the factory service manual.
Cooling Fan Control - Two Fan System
Do you have a check engine light lit ? The thing to do would have it check at the dealer or a ASE certified repair facility ! They could hook up a advanced scan tool an diagnose fairly quick ! Or you could find a wiring diagram an try testing with a volt meter yourself ! But watch yourself so you don't short out the PCM - engine computer !
May 01, 2015 | AC Cars & Trucks
Dell inspiron 2020 all in one fan problems
I have found that if the room temperature near the computer is too high creates a problem. If the processor is being used at a high rate that will influence the temp sensors and cause the fan to run at the "speed" you hear. (It is on all the time, just different speeds). Other heat producers may not have clean fans or fins, for example display adaptor or power supply. or but unlikely, the
cpu fan interface is not well seated or no heat transfer grease. You didn't change the processor did you?
Apr 05, 2015 | Dell Inspiron One 2020 Desktop Intel Core...
No video output. fan speed fast
sounds like a faulty GPU . your graphic chip or card could be burned out which explains the no display and high speed fan.it can also be it cant boot to BIOS.
Nov 11, 2013 | Intel Corporation Network Servers...
CLP-600N: Will not print. Fan error.
Just need to replace the fan, #jc31-00012c
Jul 24, 2009 | Samsung Office Equipment & Supplies
98 Dodge Intrepid Blower stuck on high and no display.
Yes you car has something like a resistor but its called an ATC BLOWER CONTROL MODULE.Its under the dash on the pass side close to the firewall.
Feb 16, 2009 | 1998 Dodge Intrepid
Ac controls quit working blower fan is running on high all thetime. compressor is not working.
fan elays are under hood in black box by battery. 3 of them. 2 for high speed, 1 for low speed. Default is high speed when there is a probem.
Suspect maybe they shorted something out when fixing dent. Did they do any welding on the van? Connecting the cables to the body can sometimes send voltage where it's not wanted.
Nov 06, 2008 | 2000 Nissan Quest
Dell OptiPlex GX280 PC Desktop Logo
171 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
