Question about Panasonic NN-C980 Convection/Microwave Oven
Microwave working but grill and convection not workin? hi i have a onida microwave +grill +convection most of the time microwave is used, now grill and convection are not working. thank god microwave is working coz its out of warranty. I am thinking of opening the microwave and rectify the visible problem like blown fuse or dust inside working as a conductor of elec. thank you in advance. any help will be very help full.
SOURCE: Panasonic NN 9850 wall micro/convection oven
PLEASE CHANGE MEMBRANE SWITCH
Posted on Oct 05, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Dimension 4 microwave model
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
Posted on Aug 03, 2008
SOURCE: Panasonic NN-CS596S Convection Combi Steam Oven
Thanks for this. Thats exactly what I did. It didn't work at first, however, I think it was my impatience! After selecting the Microwave, you MUST wait until you are told via the screen to input the time. It now works fine. Thanks again. Just needed perseverance! Mike
Posted on Aug 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: panasonic inverter dimension 4 microwave
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 06, 2008
WhIzAtIt
  • 136 Answers
SOURCE: Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Posted on Sep 24, 2008
Do I keep the glass plate in the microwave when on convection oven mode
If it came with the oven a definite yes as it will be able to withstand the heat during the convection setting. If a ordinary plate is used it must be rated for use in ovens as it will become very hot on convection oven mode. So, if it can withstand use in a ordinary oven it will work just as good in a convection oven.
Mar 14, 2016 | Sanyo Microwave Oven with Convection and...
Panasonic Inverter combination microwave/convection unit. Microwave barely working, convection ok, problem part?
your issue sounds like low output from the magnetron, if this is the case replacement of the magnetron is the only solution, Here's a link for magnetrons on Amazon to give you an idea of the expense involved:
Amazon co uk magnetron microwave
you may decide to replace the microwave instead of repairing.
Jan 17, 2016 | Panasonic Microwave Ovens
Microwave trips and switches off within 2 seconds
We regret reading about your microwave. At this time we recommend you have the unit evaluated by an authorized service center.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-S254BF Microwave Oven
I need instructions on how to use Sharp Convection microwave Grill 2?
Best way short of Sharp is Google the model number of the unit with "manual" to try to locate free one online.
Nov 04, 2012 | Sharp R-930AK Convection/Microwave Oven
My LG MICROWAVE OVEN IS MODEL MC-7836M CONVECTION MICRO GRILL IT IS RUNNING BUT NOT HEATING and GRILL ALSO NOT WORKING
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 27, 2010 | LG LRM1230W Microwave Oven
Manual for sharp grill 2 convection oven
where is the fuse at on the sharp grill 2 convection
Jun 13, 2009 | Sharp R-820B Convection/Microwave Oven
Smeg fmc24x oven and grill work turntable and microwave dont
I have a simular model and I found that the circuit board has three black relays, one for the grill one for the convection and one for the microwave. I found that the microwave one wasnt working so by swaping the microwave one with the convection one I got it to work and then replaced the faulty one with a new one at a later date.
Dec 03, 2008 | Microwave Ovens
Panasonic NN-C980 Convection/Microwave Oven Logo
50 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
