Question about Broderbund PrintMaster Platinum 15 Full Version for PC (385502)
I get a black image covered with question marks and a message that says A picture is missing. Just before I get the message, I can see the picture for an instant. Can I fix this problem? This happens frequently. Thank you I have the Platinum and DVD Platinum 15
  • 197 Answers
How do I reset ms610 imaging unit?
When you get the error message "Replace imaging unit, 0 estimated pgs remain [84.3x]" This means the imaging unit has reached end of life and needs to be replaced. The device will not print, and this message will not be cleared, unless you replace it with part number 50F0Z00
(or 500z)
Vertical streaking. If the imaging unit is near end of life, or the device has had problems with non standard toner, vertical streaks may occur on the page. Replacing the imaging unit will resolve the problem.
Vertical streaks on page
Vertical band at top of page. This typically appears on printed images, but can also appear on text. The most likely cause is toner contamination on the charge roll, however if the band is still visible after printing 30-40 continuous pages this means the imaging unit needs to be replaced.
Vertical Banding on images
Seal failure on the imaging unit. Occasionally seal leaks have been seen from the Imaging Unit.
Toner will be seen on the main frame near the Imaging Unit sides.
If toner build up is excessive, it may even fall into the Tray below. Cleanup with a toner vacuum may be needed.
Replace the Imaging Unit to fix the problem.
Spots, scratches, marks on the page. If they are random, this indicates a problem with toner scatter.If they are repeating patterns, measure the distance between matching marks or spots. If the distance is one of 97mm, 47mm or 38mm, this indicates marks or dents on the imaging unit and it will need to be replaced.
You receive the message Replace defective imaging unit The imaging unit is defective and needs to be replaced. If you just installed it, it will be covered under warranty - contact Lexmark Australia on 1300 362 192
You receive the message Reinstall missing or unresponsive imaging unit and the below instructions don't resolve the problem. Try one or more of the following:
  • Check if the imaging unit is missing. If missing, install the imaging unit.For information on installing the imaging unit, see the "Replacing supplies" section of your device's User's Guide
  • If the imaging unit is installed, then remove the unresponsive imaging unit, and then reinstall it.
  • Note: If the message appears after reinstalling the supply, then the imaging unit is defective. Replace the imaging unit.
You receive the message Replace unsupported imaging unit The imaging unit you attempted to install was either non-genuine, or was from a different region. Buy a genuine Lexmark imaging unit from an authorised Lexmark supplier in your country/region.
You receive a 31.6x error One of the following errors is shown on the display:
31.60 Imaging unit smart chip error
31.61 Imaging unit I2C packet timeout
31.62 Imaging unit I2C packet has been sent but code timed-out on receiving the data (callback)
31.63 Imaging unit security error in the send challenge sequence
31.64 Imaging unit ROM signature error
31.65 Imaging unit stuck busy (status register and/or CRI Arbiter register report busy)
31.66 Toner failed to replenish into the imaging unit
In this case you need to ensure that the imaging unit is properly installed. If yes, check if the imaging unit is supported. Replace with a supported imaging unit if necessary.
If the problem remains, you will need to organise a Lexmark service call (Australia 1300 362 192)
You receive error message 32.11 Imaging unit smart chip compatibility error This could be caused by an unsupported imaging unit (non-genuine or incorrect region). Replace with correct imaging unit to clear this error. If your imaging unit is supported, you will need to organise a Lexmark service call (Australia 1300 362 192).
You receive error message 84 Imaging unit low If expected, replace the imaging unit. If unexpected, call Lexmark Support (Australia 1300 362 192)
Jan 23, 2017 | Office Equipment & Supplies
I have a HP Photosmart D7160 and it won't print 4 X 6. It has black marks on the wrong side when it comes out, but not picture
Try flipping the paper. Probably you need to resize the image for this size, sounds like it is compressed and squnched together into those black marks. See if you can use a preview function.
Jul 31, 2016 | HP Photosmart D7160 InkJet Printer
Black smudges & missing lines
replace the black image unit and the fuser
Apr 07, 2014 | Konica Minolta - Magicolor 1600 1600w...
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
Feb 24, 2014 | Sharp SF-2025/2030 Copier Toner Black...
How to transfer pics to computer FROM MY ZTE f866 OR TO ANOTHER PHONE
From the manual, you can send the pictures to another phone via a MMS message.
Page 51 at - http://mymobile.three.co.uk:8080/mymobile/ZTE/866/img/Manu_guide.pdf
Page 51 copy:
My pictures
This application enables you to view still
images. Image files can be store in different
folders: Photos, Wallpapers and Avatars.
Select the desired image and press key
to view the enlarged image. Press Right
soft key [Mark] to select an image, and
press Right soft key [Mark] again to
cancel the selection.
Press Left soft key [Options] to display
the following popup menu items:
Send via MMS: Attach the selected image
to a message.
Set as wallpaper: Set the picture as
wallpaper.
Rename: Change the name of the
selected image. (Appears when Photos
is selected)
New slide: Create a new slideshow and
attach the marked images.
Add to slide: Add the selected image to a
created slideshow.
Mark all: Mark all images in the list.
Unmark all: Unmark the marked images in
the list.
Delete: Delete marked images. (Appears
when Photos is selected)
File information: Shows information about
the selected image file.
New photo: Switch to camera interface.
(Appears when Photos is selected)
Oct 01, 2012 | ZTE Cell Phones
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Minolta Magicolor 3300 Imaging unit
I had the same problem. Check out page 3-308 of this document.
Take off the side cover and re-engage the gear. Should solve the problem.
ftp://ftp.qms.com/pub/cta/out_going/other/diagcd/mc3300sm.pdf
Oct 23, 2008 | Minolta magicolor 3300 Laser Printer
Black marks found on image
sir u contact ur near service center this is simple problum just clean ur camera CCD
Mar 02, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Photos
What is PIX Place? Pix Place is an online service that is included with each activation of Picture/Video Messaging. At the Pix Place web site you can:
  • Store your favorite picture/video messages from your picture/video messaging phone*.
  • Create and name your own online photo albums*.
  • Upload and send images from your computer's hard drive.
  • Invite friends and family to view albums*.
  • Create your own picture/video messages online with your own pictures/videos, sounds and text.
  • Enhance your picture with "Fun Effects" like brightness, crop, antique, black & white, soft focus, comic bubble, cartoon, and line drawing effects.
  • Choose images and sounds from the free "Gallery" to include in your messages.
*Pix Place registration required.
Note: Not all picture messaging phones have video messaging capability. However, all video messaging phones will have both picture/video messaging capability.
HAPPY NEW YEAR
Dec 24, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Display images missing on MP3, background black!
You can set one of your own pictures as the background by viewing it and holding down the center touch pad button. The bottom of the screen will say Set Wallpaper and you can let go of the button. now that picture will be set as your background image
Jan 16, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Broderbund PrintMaster Platinum 15 Full Version for PC (385502) Logo
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
