Question about Ridgid SP500P Black 12 Horsepower Pedestal Pump
I have a SP 300 Pedestal Sump Pump that isn't pumping out the water in my crawlspace and the motor is constantly running.
    Novelist:
  • 185 Answers
I would check the input of the pump, exit and the hoses for being plugged up. The shaft of the motor may also not be connected to the pump impeller for some reason. Sometimes the impeller gets clogged with junk. Take the pump out, and clean it out first and see if that solves your problem. you can test it in a 5 gallon pail filled with water.
Posted on Mar 18, 2011
Watchdog sump pump want stop beeping
if you have a home entertainment system just turn it on and up kidding the sump pump for our home is always running i have never heard in beep just whines constantly Is the pump still working? I have had pumps go bad before but they never beeped they didn't do anything after burning up the motor i wonder if its a battery maybe 9v
Sep 10, 2012 | RTO Basement Watchdog Sump Pump
My sump pump wont kick off. There is no water in the sump and the float is fine, but the motor won't shut off. I unplugged the pump as to not burn up the motor, and thinking it may reset itself, but when...
Hello, the pump motor is controlled by the float switch. If your motor is running constantly even when you move the float switch around, then I would say that either the switch is shorted internally, or the wires going to the switch are shorted, thusly causing the motor to run. Is the float on a separate adapter to the pump, or is it wired into the pump?
joe
Jan 09, 2011 | Flotec Automatic Sump Pump Float Switch
Just purchased a home with water ace sump pump.
That's the idea; if you lift the float the water starts pumping because it works off of that float. That type of pump is usually meant for water that is in a tub or bucket, so that when the water reaches a certain height and causes the float to rise allowing the pump to kick on. I use a pump like that to pump our the drained water from my washing machine in my basement, i let the water go into a big 50 gallon drum and then once the drum is half full i have it set so the float rises and pumps out the water. That being said, if you are putting this in your basement at floor level, you would need to get a 10 gallon bucket meant for sump pumps (you can get one at your local home store) and rent a jackhammer if your basement is concrete and put the bucket in the floor and the sump pump in the bucket, this is called a sump pit. Another option is to get whats often called a "floor ******" pump. Its a pump that sucks the water out when it reaches around a half inch of depth and it can be used in several feet of water (I've used these as well, there is no float involved), and it can be set on level ground there is no sump pit needed. The one thing with my pump you may not want, is that it's constantly running because its constantly monitoring for water so that a lot of water will not build up (especially if water can damage some thing in the surrounding area) . You can check out all the types at your local home store.
May 27, 2010 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Sp-500 I noticed the pump was running for 2 seconds and plenty of gurgling after. I then played with the float and it started to run a full cycle with no more gurgling. What causes that?
The "gurgling" is the sound that the water makes as it flows back down the hose and out of the pick-up point. You say that after playing with the float the pump started to operate properly, which would indicate that the float was either stuck, or not working like it should.
Oct 23, 2009 | Ridgid 85937 SP-500 1/2 HP Submersible...
No information on Wayne 55701-RP1
This isn't a valid Wayne pump model number according to Wayne's website. Please double check your pump and visit:
http://www.waynepumps.com/producttype.aspx?pt_producttypeid=8
May 23, 2009 | Wayne Water Systems Wayne RECONDITIONED...
I have an Simer pedestal pump and the part that connects to the impeller from the motor is broken. I can not find a repair part or part #. Can you help me? THX
there is no repair parts all you can do is change the pump,, go with a submersable zoeller pump best on the market for the price aprox 100,
Mar 15, 2009 | Flotec 1/3 Horsepower Economy Pedestal...
1/3 hp wayne pedistal sump stoped working
yes there are brushes,, but there is also a shaft that goes thru the tube make sure it is not broke or bent,, it happens,, suggest to get a zoeller submersable pump its the best cast iron, float is attached to the unit, will fit in small pits, only 1 plug needed,, cost for pump 100
Dec 31, 2008 | SPV Wayne Pumps Spv500 1/3hp Cast Iron...
Ridgid SP500P Black 12 Horsepower Pedestal Pump Logo
126 people viewed this question
Top Ridgid Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Ridgid Plumbing Expert? Answer questions, earn points and help others
