Question about JVC TH-A30 System
How to convert the my jvc dvd player to ntsc to pal or vise versa, coz i used old tv so i need to change it . tnx my jvc model is xv-tha30 dvd cinema system
  • 635 Answers
You have to use an external device to convert NTSC to PAL or vis versa. The device cost between 175 to 250 $. I think you can buy a small new generation multi system TV for that price !!!!.
If you still want to buy click on the below link.
http://www.converters.tv/signals/ntsc_to_pal.html
Posted on Mar 18, 2011
Everything works but it plays in black and white how do i make it back in color
change the settings from pal ntsc or secam, depending on what system you are using. I.e. if it is in pal then change it to ntsc and vise versa
Mar 10, 2011 | GPX PDL705
PAL to NTSC output
How are you hooking it up to yur TV for the output?
Apr 01, 2008 | Televison & Video
NTSC to PAL question
yes system conversion is you need just change the crystals! buy a palsecam crystal then replace the old crystal.
Dec 24, 2007 | Hitachi M2 Digital Camera
When you insert a dvd it says PAL DISK
PAL is the format of the dvd and there are two main formats for a dvd and they are PAL or NTSC. The NTSC format is mostly used for the United States, and the PAL format is used more in Europe and Asia. An older dvd player will have the format options in the setup menu for the dvd player, and from the setup menu on the tv screen the dvd player can be set to play the PAL dvd's. However if that is not the problem and the dvd player no longer can tell a PAL from a NTSC format then the dvd player either needs a serious lens cleaning or it has a malfunction. Also, the back of the cover for the dvd should say if it is PAL or NTSC.
Jun 16, 2010 | JVC TH-A9 System
Unable to play DVD as it states "PAL" on the screen
If you dont have the original remote it is impossible. Go to the menu, then on the system choose "ntsc" that is the system used in the united states.
Jun 27, 2009 | JVC XV-S42 DVD Player
How to convert Pal to NTSC Magic sing Model 5.91
  • How can I Convert NTSC to PAL mode or vice-versa?
  1. Press the [PWR] button while pressing [8] button for PAL TV mode.
  2. Press the [PWR] button while pressing [9] button for NTSC TV mode.
Apr 13, 2009 | Magic Sing Along Consumer Microphone
The display screen is rolling and is in black and white.
Hi
You switched to PAL mode from NTSC or vice versa. Most DVDs will only output PAL or NTSC, not both. So even if the disc is region ffree, the fact that it's encoded in PAL (50hz) makes it appear like you describe - no vertical hold / black and white.
Some set top players [Apex, Phillips] will convert PAL to NTSC on the fly or vice versa.
Remember, PAL/NTSC is not the same as Region.
Here's some detailed info:
http://www.michaeldvd.com.au/Articles/PALvsNTSC/PALvsNTSC.asp
http://www.sjbproductions.com/web_pages/tip_video/ntsc_pal.htm
http://www.dvdcity.com/codefree/codefree-ntsc-info.html
You can convert the DVD to NTSC, and strip the region code by following http://www.videohelp.com/guides/how-to-convert-interlaced-pal-dvd-to-ntsc-dvd-id1107#1107
-or-
http://forum.videohelp.com/topic221928.html
[This is very time consuming.]
You
What DVD
Most players are either NTSC or PAL, however increasingly DVD players from the Far East (Apex, Phillips etc)
, which is 50hz instead of 60hz, hence the lack of vertical hold
Mar 23, 2009 | Televison & Video
Black & white resolution
good day,
Possible reason would be Video system compatability. In PHI most of the screen are NTSC compliant for video sytem and for Qatar im not sure if its PAL or PAL SECAM system. But no worries, the only thing you need to do is change the video setting of your DVD player. do you have the owner manual of your player? if do so, check for the part reffering to video system. access that menu and one part of that selection would be the video out system, there should be a selection to choose from PAL/NTSC and auto. just select "Auto" or "NTSC"
cheers,
mark
Jan 31, 2009 | JVC XV-N652
Jvc xv-s332 dvd player won't play
on the back is a seitch labelled ntsc/pal. flick it the other way might fix it
Jan 25, 2008 | JVC XV-N322
Jvc xv-s302 only plays black and white
Look at the back of the DVD player it should have a NTSC & PAL switch ,but remember to switch off the dvd player after you change it over to NTSC or PAL
i hope this will help you
craig:)
Jul 01, 2007 | JVC XV-S302 DVD Player
JVC TH-A30 System Logo
90 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
