Question about Sony KP-53V90 53" Rear Projection Television
My red and blue projector kinda **** like the tv is sucking the picture in
  • 147 Answers
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Posted on Mar 19, 2011
Dlp tv color goes fuzzy and green
Its probably unrelated to lamp, take the lamp out, try it again and look into the lens, if its still very green the projectors electronics are failing. The projector generates pictures as 3 streams of info Red Green and Blue. It looks like the projectors red and blue electronics are failing, but the green is working.
Dec 14, 2013 | Samsung Televison & Video
Picture is pale, yet reds are bright. checked color, brightness, and conversion settings. TV seems unresponsive to the color, tint, and brightness adjustments.
open the back and look into the projectors red blue and green should be clear picture if its blurry need to change the coolant if its not on need to replace the projectors
Aug 22, 2009 | Philips 50P8341 50" Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
Same problem w yellow on viewsonic pj550
Yellow is the mixture of 100% red and 100% green. what you may have here is a blue LCD failure in the machine. Try this to check. Open up PAINT and double click one of the colors on the bottom. now click add custom color. then in the RGB section put 0 for red 0 for green and 255 for blue. ok out of everything and fill the background w/ the blue. it should be a VERY intense blue, if its white or or kinda blue, you have an LCD issue
Apr 13, 2009 | ViewSonic PJ550 Multimedia Projector
Have a model 43A10 toshiba tv, has a purple color at very bottom of screen about inch tall. When i go into the menu, looks like writing is not lined up on the lower options of the menu. and partly up...
you either have a color purity problem or a convergence problem. purity can be effected by electro magnets in power supplys of audio amps and subwoofers too close to the tv
Convergence is the ability of the red green blue to drop on top of each other. can usally be adjusted via remote control. Please claify and repost.
Apr 03, 2009 | Toshiba 43A10 43" Rear Projection...
Sony kp-46wt500 with no red projector
all three guns red blue and green should be replaced and the flote.
cost could be from $400 to 680 in parts depending on wer you buy them. I would but the parts my self then pay the repairmen to do the install this way you dont get priced up to high in parts cost.
regards,
daniel.
Jan 13, 2009 | Sony KP-46WT500 46" Rear Projection...
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Jan 07, 2008 | Samsung PCL5415R TV
Sony KF-42WE610
Sound but no picture, tv will not turn off. Light goes red but a dim overall blue screen remains and fan is still running.
Nov 15, 2007 | Sony XL-2100U Projector Lamp for...
Distorted Color and geometry of Picture
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Nov 03, 2005 | Panasonic PT-47WX49 47" Rear Projection...
Sony KP-53V90 53" Rear Projection Television Logo
52 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
