Question about Mitsubishi WD 65837 65 in. HDTV
My 65 inch mitsubishi tv turns on but has no picture. It will turn it self off after a minute or two and the red lamp light comes on
ladywinn
  • 5138 Answers
SOURCE: my 60" dlp mitsubishi tv
Sound /No picture- Have you replaced the Lamp?
If Not, First make sure fans are running when Tv is Turned on .Then if fans are OK ,Most common reason is the Lamp.
What is the Model # that is printed on back of TV?
Posted on Feb 20, 2011
mommifriedt
  • 6 Answers
SOURCE: iI HAVE A 65" MITSUBISHI TV MODLE WD-62530 JUST
move all other electronics away from the screen mine did it too
Posted on Feb 22, 2011
  • 1039 Answers
SOURCE: Someone has pushed something on
Check device menu and select input till you get apicture. You could lookjto see what input you have a source connected to and switch to that input. May just have button marked input.
Posted on Aug 31, 2011
SOURCE: Tv turned off by itself,
TV turns off by itself with either an amber colored flashing light or a red flashing light. Lamp changed about six months ago.
Posted on Oct 29, 2012
  • 395 Answers
SOURCE: DLP TV turning on and off automatically - Mitsubishi WD-52327
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
Posted on Feb 21, 2008
THE TV WONT TURN OFF THE POWER LIGHT IS RED
Red usually means it wont turn on, suspect the Lamp.
The unit does have a self check, done that?
Dec 23, 2012 | Mitsubishi WD65737 65" DLP TV
Mitsubishi startted flickering, then screen went black and red light on
If it is the lamp light blinking it may mean the lamp is bad--did you do the self check as suggested?
Jun 03, 2012 | Mitsubishi WD65737 65" DLP TV
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Problem with 65 in tv
probably needs a new lamp. It is consumer replacable.
Aug 16, 2009 | Televison & Video
My 2 1/2 yr old Mitsubishi 65 inch DLP will not turn on.E code 12
let it start up you will here things happening, engine will start first then a buzz to start the lamp if you here all of this you have a bad lamp.You should have a error code let the tv try to start leave it alone and see if you have an error. As soon as you reset the tv you loose the error.
May 01, 2009 | Mitsubishi WD-65732 65" Projection HDTV
Mitsubishi 65" DLP HDTV, Status light is red, no picture
Check your lamp; it may have blown. Sound, no picture and a red light are classis signs a lamp has failed.
Feb 02, 2009 | Mitsubishi WD-62528 62 in. LCD Television
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Mitsubishi WD 65837 65 in. HDTV Logo
611 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
